  4. [gelöst]Homepilot JSON einlesen
8 Beiträge 4 Kommentatoren 3.5k Aufrufe
    pix
    ich steh irgendwie auf dem Schlauch. Nachdem der Node-Red Adapter bei mir zu Zeit spinnt, versuche ich einige der Flows direkt in JavaScript zu realisieren. Nach diesem Vorbild (http://forum.iobroker.net/viewtopic.php?f=21&t=880&sid=968c7f80b8566ec431d300d339231afc) habe ich vor, die JSON Datei meines Hompilot einzulesen. Es sind nur zwei Devices angelernt (zwei Rollläden), deren Position ich in Objekten speichern will.
    JSON Datei: http://homepilot.local/deviceajax.do?devices=1
    { "response" : "get_visible_devices", "status" : "ok", "devices" : [{"did":10000,"name":"Rollo SZ links","description":"Rollotron Standard Schlafzimmer linkes Fenster","initialized":1,"position":80,"productName":"RolloTron Standard","serial":"40","statusesMap":{"Position":80,"Manuellbetrieb":1},"status_changed":1435843704,"deviceGroup":2,"iconSet":{"name":"Rollladen 2","description":"Rollladen Icon-Set mit Streben","strMin":"Auf","strMax":"Zu","valMax":100,"valMin":0,"sprite":{ "imageUri" : "images/sets/rollladen2.png", "numTiles" : 5 },"k":"iconset15"},"iconSetInverted":0,"paired":0,"statusValid":true,"uid":"40 59 0A","visible":true,"groups" : [ ] ,"favoredId":5003,"properties":{"generic":3,"wind":3,"trigger":3,"closingContact":3,"dusk":3,"smoke":3,"sun":3,"temperature":3,"manual":3,"time":3,"dawn":3,"dust":3,"favored":0,"smartphone":3,"motion":3,"temperator":3,"warning":3,"rain":3,"states":[{"cfgKey":"setEveningAuto","cfgId":107,"state":0},{"cfgKey":"setSunAuto","cfgId":105,"state":0},{"cfgKey":"setTimeAuto","cfgId":101,"state":0},{"cfgKey":"setAutomationOverall","cfgId":99,"state":1},{"cfgKey":"setMorningAuto","cfgId":103,"state":0}]},"sortId":914,"sTypes":[],"version":"1.2","sync":-2147481675,"messages":[],"hasErrors":0,"autos":[3,2,0,1,4]},{"did":10001,"name":"Rollo SZ rechts","description":"Rollotron Standard Schlafzimmer rechtesFenster","initialized":1,"position":88,"productName":"RolloTron Standard","serial":"40","statusesMap":{"Position":88,"Manuellbetrieb":0},"status_changed":1435843708,"deviceGroup":2,"iconSet":{"name":"Rollladen 2","description":"Rollladen Icon-Set mit Streben","strMin":"Auf","strMax":"Zu","valMax":100,"valMin":0,"sprite":{ "imageUri" : "images/sets/rollladen2.png", "numTiles" : 5 },"k":"iconset15"},"iconSetInverted":0,"paired":0,"statusValid":true,"uid":"40 58 EA","visible":true,"groups" : [ ] ,"favoredId":5002,"properties":{"generic":3,"wind":3,"trigger":3,"closingContact":3,"dusk":3,"smoke":3,"sun":3,"temperature":3,"manual":3,"time":3,"dawn":3,"dust":3,"favored":0,"smartphone":3,"motion":3,"temperator":3,"warning":3,"rain":3,"states":[{"cfgKey":"setEveningAuto","cfgId":107,"state":0},{"cfgKey":"setSunAuto","cfgId":105,"state":0},{"cfgKey":"setTimeAuto","cfgId":101,"state":0},{"cfgKey":"setAutomationOverall","cfgId":99,"state":0},{"cfgKey":"setMorningAuto","cfgId":103,"state":0}]},"sortId":915,"sTypes":[],"version":"1.2","sync":-2147481767,"messages":[],"hasErrors":0,"autos":[3,2,0,1,4]}] }
    Dies ist mein kläglicher Versuch mt JSON.parse, der aber nicht läuft. Was ist falsch?
    /* Homepilot einlesen
    Homepilot Daten in JS Variablen schreiben
    erstellt: 02.07.2015 von Pix
    createState('Homepilot.json');
    createState('Homepilot.Rollladen.Schlafzimmer.links.Level');
    createState('Homepilot.Rollladen.Schlafzimmer.rechts.Level');
    var link = 'http://homepilot.local/deviceajax.do?devices=1';
    function readHomepilot() {
    log('Start Homepilot Daten einlesen');
    request(link, function (error, response, body) {
        if (!error && response.statusCode == 200) {
            JSON.parse(body, {
                explicitArray: false,
                mergeAttrs: true
            function (err, result) {
                var data = JSON.stringify(result, null, 2);
                log(data);
                setState("javascript.0.Homepilot.json", data);
                if (err) {
                    log("Fehler: " + err);
                } else {
                    log('Kein Fehler :-D');
                    setState("javascript.0.Homepilot.Rollladen.Schlafzimmer.links.Level", result.devices[0].position); // device 10000
                    setState("javascript.0.Homepilot.Rollladen.Schlafzimmer.rechts.Level", result.devices[1].position); // device 10001
        } else {
            log('Fehler:' + error);
    });   // Ende request
    log('Daten aus Homepilot eingelesen');
    schedule("*/1 * * * *", readHomepilot);
    readHomepilot();
    Ich brauche die Devices nicht durchzuiterieren. Wenn man später mal einen Adapter baut, kann das sinnvoll sein. Die manuelle Abfrage über __result.devices[x].position__ reicht mir.
    Pix
    • BluefoxB Offline
      BluefoxB Offline
      Irgendwie strange versuchst du JSON.parse zu benutzen:
                              var result;
                  try{
                      result = JSON.parse(body);
                      log(data);
                  } catch (e) {
                      log('Parse Fehler:' + e);
                  if (result) {
              } else {
          });   // Ende request
      readHomepilot();
        pix
        Hallo Bluefox,
        try und catch sagen mir gar nix. Jedenfalls geht es jetzt wunderbar. Ist mir erstmal lieber, als länger auf node-red zu setzen.
        Vielen Dank für die schnelle Hilfe!
        Pix
        • Y Offline
          Y Offline
          ykuendig
          Er hat das Script etwas zerlegt, und das Ergebnis von JSON.parse in eine Variable (result) überführt um damit zu arbeiten.
          Mit 'try' wird versucht die nachfolgenden Befehle abzuarbeiten. Sollte ein Fehler auftreten, soll nicht das ganze Script sterben, sondern der Fehler mit 'catch' abgefangen werden. Dort wird in Deinem Fall ein erklärender Log-Eintrag erzeugt.
          Gruss Yves
            pix
            Danke für die Erklärung. Ich lerne nie aus.
            Allerdings habe ich festgestellt, dass das Skript so deutlich mehr Ressourcen braucht, als der Node-Red Flow. Bei 15sekündlicher Ausführung ging auf dem MacMini der Lüfter an und die cpu Auslastung auf 100%.
            Eigentlich reicht eine Ausführung pro Minute, aber in Node Red waren alle 10s kein Problem.
            Vielleicht schaffe ich es irgendwann, einen Adapter draus zu bauen.
            Pix
            Gesendet von meinem iPhone mit Tapatalk
              Alexxx2005
              Hallo Pix,
              kannst du bitte erklären wo man den Code im Javascript Engine einfügen
              muss komme da nicht weiter, danke.
              Grüße Alex
                pix
                Hallo Alex,
                So wie hier beschrieben.
                http://forum.iobroker.net/viewtopic.php?t=2011#p17349
                Gruß,
                Pix
                Gesendet mit Tapatalk
                  Alexxx2005
                  Hallo Pix,
                  Danke,
                  der Heftrücken hat noch gefehlt in der Beschreibung
                  nun bekomme ich eine Position ermittelt allerdings
                  stimmt die nicht.
                  Er zeigt mir 100% an obwohl 80 oder 0 sind und das
                  auch noch 5 min. später , hast du da eine Idee an was
                  das liegt
