  4. HomeKit Adapter
    5.7k
HomeKit Adapter
4 Beiträge 2 Kommentatoren 993 Aufrufe
    Marty56
    Es gibt einen HomeKit Adapter 0.1.6.
    Ist dieser Adapter funktionsfähig?
    Leider fehlt die Dokumentation.
    Es steht da nur
    Enums are no longer needed, Objects were included cause of ioBroker roles.
    (For Usage you must define a enum named enum.homekit. There you must include all needed Objects. Set a common Name for all Objects e.g. hm-rpc.0.JEQ0225305.1.TEMPERATURE = Kinderzimmer)
    Wer versteht das und könnte mir eine Anleitung geben.
    Ich habe noch ein bisschen herumgefummelt und bekomme jetzt folgende Fehlermeldung
    host.Raspberry	2017-08-05 10:47:34.556	info	Restart adapter system.adapter.homekit2.0 because enabled
    host.Raspberry	2017-08-05 10:47:34.555	error	instance system.adapter.homekit2.0 terminated with code 0 (OK)
    homekit2.0	2017-08-05 10:47:34.507	info	terminating
    homekit2.0	2017-08-05 10:47:34.476	error	at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    homekit2.0	2017-08-05 10:47:34.476	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    homekit2.0	2017-08-05 10:47:34.476	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    homekit2.0	2017-08-05 10:47:34.476	error	at Socket. (/opt/iobroker/node_modules/iobroker.homekit2/main.js:200:60)
    homekit2.0	2017-08-05 10:47:34.476	error	at /opt/iobroker/node_modules/iobroker.homekit2/main.js:18:13
    homekit2.0	2017-08-05 10:47:34.476	error	at main (/opt/iobroker/node_modules/iobroker.homekit2/main.js:215:19)
    homekit2.0	2017-08-05 10:47:34.476	error	at require (internal/module.js:20:19)
    homekit2.0	2017-08-05 10:47:34.476	error	at Module.require (module.js:497:17)
    homekit2.0	2017-08-05 10:47:34.476	error	at Function.Module._load (module.js:417:25)
    homekit2.0	2017-08-05 10:47:34.476	error	at Function.Module._resolveFilename (module.js:469:15)
    homekit2.0	2017-08-05 10:47:34.476	error	Error: Cannot find module 'hap-nodejs/node_modules/node-persist'
    homekit2.0	2017-08-05 10:47:34.475	error	uncaught exception: Cannot find module 'hap-nodejs/node_modules/node-persist'
    homekit2.0	2017-08-05 10:47:34.454	info	hap-nodejs starting...
    homekit2.0	2017-08-05 10:47:34.447	debug	received all objects
    homekit2.0	2017-08-05 10:47:33.744	debug	received all states
    homekit2.0	2017-08-05 10:47:31.990	debug	requesting all objects
    homekit2.0	2017-08-05 10:47:31.986	debug	requesting all states
    homekit2.0	2017-08-05 10:47:31.978	info	starting. Version 0.1.6 in /opt/iobroker/node_modules/iobroker.homekit2, node: v6.11.1
    homekit2.0	2017-08-05 10:47:31.920	debug	statesDB connected
    homekit2.0	2017-08-05 10:47:31.849	debug	objectDB connected
    HW:NUC (16 GB Ram)
    OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
    • apollon77A Offline
      Vergiss Homekit, nimm yahka Adapter
        Marty56
        I have Yakha versucht und bekomme schon beim Installieren ein Index.html not found error.
        HW:NUC (16 GB Ram)
          Dann mach dazu mal nen Thread auf bzw. schreib was im passenden Thread.
