  4. Probleme mit Zigbee-Adapter / -Netzwerk
10 Beiträge 6 Kommentatoren 1.2k Aufrufe 6 Beobachtet
    Stefi
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Raspberry Pi 4 Model B Rev 1.1
    Arbeitsspeicher: 4GB
    Festplattenart: SSD
    Betriebssystem: Debian GNU/Linux 11 (bullseye)
    Node-Version: v16.19.0
    Nodejs-Version: v16.19.0
    NPM-Version: 8.19.3
    Installationsart: via Docker
    Image genutzt: Ja
    Ort/Name der Imagedatei: buanet/iobroker:v7.2.0 @ Docker Hub
    root@08c95e33711d:/opt/iobroker# uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    aarch64
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.19.0
    v16.19.0
    8.19.3
    root
    /opt/iobroker
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists... Done
    Building dependency tree... Done
    61 packages can be upgraded. Run 'apt list --upgradable' to see them.
    nodejs:
      Installed: 16.19.0-deb-1nodesource1
      Candidate: 16.20.2-deb-1nodesource1
      Version table:
         16.20.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
     *** 16.19.0-deb-1nodesource1 100
            100 /var/lib/dpkg/status
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://deb.debian.org/debian-security bullseye-security/main arm64 Packages
                         v.2023-06-20
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Kernel          : aarch64
    Userland        : arm64
    Docker          : v7.2.0
    Installation:           Docker
    Kernel:                 aarch64
    Userland:               arm64
    Timezone:               Etc/UTC
    User-ID:                0
    X-Server:               false
    Pending OS-Updates:     61
    Pending iob updates:    7
    Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
                            /usr/bin/node           v16.19.0
                            /usr/bin/npm            8.19.3
                            /usr/bin/npx            8.19.3
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            3.8G        1.6G        1.2G        1.0M        963M        2.1G
    Swap:            99M          0B         99M
    Total:          3.9G        1.6G        1.3G
    Active iob-Instances:   19
    Active repo(s): stable
    ioBroker Core:          js-controller           4.0.23
                            admin                   6.10.1
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : 08c95e33711d                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : 08c95e33711d                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                8030
    States:                 6770
    Size of iob-Database:
    14M     /opt/iobroker/iobroker-data/objects.jsonl
    7.4M    /opt/iobroker/iobroker-data/states.jsonl
    Zusatzinfos:
    • FritzBox in direkter Nachbarschaft zum Conbee2 Stick
    • FB WLAN-Funkkanal auf auto, aktuell Kanal 13
    • Conbee2 Stick Funkkanal war auf 13, wurde auch mit 11 und neu anlernen getestet
    • Firmware vom Conbee2 Stick ist auf dem aktuellen Stand (15.05.22)
    • Probleme traten mit dem iobroker.zigbee Adapter 1.8.23 auf, ich habe zwischenzeitlich von Github installiert auf 1.8.24
    • der Conbee2 ist über ttyAMC0 angebunden und verwendet für das Binding in den Docker Container einen fixed port name
    • mein USB-Verlängerungskabel scheint defekt (Wackelkontakt, neues ist bestellt), so dass der Conbee2 nun direkt am USB-Anschluss am Raspi angesteckt ist
    • Sentry ist auf Adapterebene (iobroker.zigbee) deaktiviert
    • Verbindungseinstellungen für iobroker.zigbee: PanID=6754, erw. PanID=16xD
    • Zigbee Daten zurückgesetzt (Adapter gestoppt, Objektbaum gelöscht, Inhalt von /opt/iobroker/iobroker-data/zigbee_0 in einen Tmp-Ordner verschoben, Adapter neu gestartet)
    • Conbee2-Stick neu geflasht (gleiche Firmware)
    • Batterie am Temp-Sensor (mit dem ich das Anlernen getestet habe) vorsichtshalber getauscht
    (jetzt nachdem ich mir diese Punkteliste ansehe: wäre das vielleicht etwas für eine Art Checkliste? Ich habe mir das aus verschiedenen aktuellen Posts zusammengesucht)
    Hi zusammen,
    ich brauche mal einen Schubs in die richtige Richtung. Derzeit habe ich folgendes Problem:
    Zentral in meiner Wohnung gelegen, befindet sich seit rund 1 Jahr ein RaspPi 4 mit SSD und Conbee II Stick. Leider sehr nahe an der FritzBox, das hat aber bisher keine Probleme gemacht. ioBroker läuft als Docker-Container. Router und Repeater sind keine weiter im Einsatz, nur der Conbee2-Stick.
    Vor ein paar Tagen habe ich von SD-Karte auf SSD geswitcht. Seitdem (meine ich) habe ich Probleme mit meinem Zigbee Netzwerk und krieg einfach nicht auf die Kette wo mein Problem liegt. Probiere jetzt schon seit 7-8 Stunden unterschiedliche Kombinationen aus, aber nichts will fruchten (Ergebnis seht ihr oben bzw. an den Zusatzinfos).
    Mein aktueller Stand:
    • iobroker.zigbee Adapter ist grün
    • Zustand vor Konfigänderung am Adapter: Devices waren available + LQ von 10, keine 30 Sekunden später waren sie gar nicht erreichbar
    • Ich habe testweise einen Aquara Temp-Sensor rausgeschissen, um ihn nach Konfigänderung am Adapter neu anlernen zu können -> anlernen funktioniert nicht mehr
    • Anlernen scheitert, indem a) der Kopplungsfortschritt-Countdown zählt, aber kein Device angelernt/erkannt wird oder b) der Kopplungsfortschritt-Countdown gar nicht mehr angezeigt und auch kein Device angelernt/erkannt wird -> Fehlermeldungen gibt es im Log keine, Log zeigt aber "Zigbee: allowing new devices to join."
    • Funkkanal-Scannen über den Adapter lässt den Adapter crashen (Fehlermeldung s.u.)
    Ich kann derzeit keins meiner Zigbee-Devices anbinden/nutzen. Betroffen sind:
    • 8 Temperatur-Sensoren
    • 14 Tür-/Fensterkontakte
    • 1 Bewegungsmelder
    Hat einer von euch noch eine Idee, was ich noch ausprobieren kann - außer alles in den Müll zu schmeißen (= alles komplett neu aufzusetzen)? 😟
    Lg Stefi
    	TypeError: Cannot read properties of undefined (reading 'waitFor') at ZigbeeController.getChannelsEnergy (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:978:54) at Commands.getChannels (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:489:52) at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:76:30) at Zigbee.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:14:48) at Zigbee.emit (node:events:525:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5301:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:322:37) at processImmediate (node:internal/timers:466:21)
    F ? GlasfaserG 3 Antworten Letzte Antwort
    • S Stefi
      Festplattenart: SSD
      NPM-Version: 8.19.3
      Image genutzt: Ja
      aarch64
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.19.0
      v16.19.0
      8.19.3
      root
      /opt/iobroker
      nodejs:
        Version table:
                           v.2023-06-20
      Kernel          : aarch64
      Userland        : arm64
      Docker          : v7.2.0
      Kernel:                 aarch64
      Userland:               arm64
      Timezone:               Etc/UTC
      User-ID:                0
      X-Server:               false
                              /usr/bin/npm            8.19.3
                              /usr/bin/npx            8.19.3
      MEMORY:
      Swap:            99M          0B         99M
                              admin                   6.10.1
      Objects type: jsonl
      States  type: jsonl
      Objects:                8030
      States:                 6770
      Zusatzinfos:
      Hi zusammen,
      • 1 Bewegungsmelder
      Lg Stefi
      Frank579
      @stefi sagte in Probleme mit Zigbee-Adapter / -Netzwerk:
      SSD am USB3 ? Das hat hier schon öfter zu Problemen geführt... wenn ja Versuch mal keinen USB3 Port für die SSD zu nehmen.
      • S Stefi
        Festplattenart: SSD
        NPM-Version: 8.19.3
        Image genutzt: Ja
        aarch64
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.19.0
        v16.19.0
        8.19.3
        root
        /opt/iobroker
        nodejs:
          Version table:
                             v.2023-06-20
        Kernel          : aarch64
        Userland        : arm64
        Docker          : v7.2.0
        Kernel:                 aarch64
        Userland:               arm64
        Timezone:               Etc/UTC
        User-ID:                0
        X-Server:               false
                                /usr/bin/npm            8.19.3
                                /usr/bin/npx            8.19.3
        MEMORY:
        Swap:            99M          0B         99M
                                admin                   6.10.1
        Objects type: jsonl
        States  type: jsonl
        Objects:                8030
        States:                 6770
        Zusatzinfos:
        Hi zusammen,
        • 1 Bewegungsmelder
        Lg Stefi
        Moin,
        hast Dir viel mühe gemacht, mit den Informationen, danke dafür.
        Was noch nicht beantwortet ist, hängt der Zigbee - Stick an einem min. 30 cm langen Kabel am USB 2 Port des RaspI, der Stick muss weiter weg vom USB 3 Port, da DU da ja jetzt die SSD dran hast, und der USB 3 Port HF Störungen verursacht.
        Das zweite ist auch ein gern gemachter Fehler, dass Zigbee und FritzBox die gleichen Funkkanäle nutzen.
        Das dritte, in Deiner Beschreibung zählst Du nur Zigbee Geräte mit Batterie auf, um ein gutes Mesh Netzwerk zu bekommen, solltest Du auch Geräte nutzen, die dauerhaft Strom nutzen, z. B. Zigbee Leuchtmittel, Zigbee Stromzwischenstecker oder die kleinen Repeater/Verstärker von Ikea.
        VG
        Bernd
        • F Frank579
          Stefi
          schrieb am zuletzt editiert von Stefi
          @frank579 said in Probleme mit Zigbee-Adapter / -Netzwerk:
          Grad könnte ich wie Rumpelstilzchen auftreten, dass ich an diesen Punkt nicht gedacht habe 😂
          Echt verrückt. Raspi runtergefahren, SSD umgesteckt auf USB2, hochgefahren und zack war das Pairen möglich. Hängt das u.U. auch mit den Störungen durch USB3 zusammen? Anders kann ich es mir nicht erklären.
          @db20eic - 1000 Dank für die Tipps, das werde ich beherzigen. Habe mir aktuell ein 30cm USB-Verlängerungskabel bestellt. Und gern geschehen was die Infos angeht: habe heute haufenweise Artikel gelesen, die alle so ähnlich klangen wie meiner und überall waren es ähnliche Fragen. Dachte mir das das unnötige Warterei spart, wenn mich das jemand fragen muss 😁
          Great SUNG 1 Antwort Letzte Antwort
          • S Stefi
            Festplattenart: SSD
            NPM-Version: 8.19.3
            Image genutzt: Ja
            aarch64
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v16.19.0
            v16.19.0
            8.19.3
            root
            /opt/iobroker
            nodejs:
              Version table:
                                 v.2023-06-20
            Kernel          : aarch64
            Userland        : arm64
            Docker          : v7.2.0
            Kernel:                 aarch64
            Userland:               arm64
            Timezone:               Etc/UTC
            User-ID:                0
            X-Server:               false
                                    /usr/bin/npm            8.19.3
                                    /usr/bin/npx            8.19.3
            MEMORY:
            Swap:            99M          0B         99M
                                    admin                   6.10.1
            Objects type: jsonl
            States  type: jsonl
            Objects:                8030
            States:                 6770
            Zusatzinfos:
            Hi zusammen,
            • 1 Bewegungsmelder
            Lg Stefi
            GlasfaserG Offline
            GlasfaserG Offline
            Glasfaser
            SEHR große Empfehlung !!
            Das sieht man ... in deinen Angaben , ( was luppt aktualisiere ich nicht )
            Halte Ihn aktuell , besonders
            sonst ist dein geheule hier mal groß wenn der RaspPi mal abstürzt ..
            und
            v16.19.0
            usw...
            alles sehr alt !!
            • GlasfaserG Glasfaser
              und
              v16.19.0
              usw...
              alles sehr alt !!
              Stefi
              @glasfaser said in Probleme mit Zigbee-Adapter / -Netzwerk:
              Halte Ihn aktuell
              alles sehr alt !!
              Mist, erwischt 😇
              Aber ja, du hast absolut recht! An ein Update des js-controllers hatte ich mich noch nicht wirklich getraut 😁 Dann weiß ich aber jetzt ja, was ich die Tage noch zu tun habe 😇
              DuffyD 1 Antwort Letzte Antwort
              • S Stefi
                Halte Ihn aktuell
                alles sehr alt !!
                Mist, erwischt 😇
                DuffyD Offline
                DuffyD Offline
                Duffy
                schrieb am zuletzt editiert von Duffy
                @stefi
                Ich habe auch nur Probleme mit Zigbee, habe jetzt aber mal von USB 3 auf USB 2 umgesteckt.
                Was ich gemacht habe ist über influxdb mal den „state“ aufzuzeichnen.
                Dabei konnte ich sehen das, wenn ich einen Repeater zusätzlich angeschlossen habe möglicherweise das Zigbee Netz schlechter wurde.
                Jetzt warte ich mal was der Tip mit dem USB2 bringt.
                Aber meine bescheidene, nichts sagende Erfahrung, die nur aus trial and error besteht ist das evtl weniger mehr sein könnte.
                Ich habe mein kleines Häuschen mit Steckdosen, repeaten, Relais und Lampen überflutet aber wirklich besser wurde das Zigbee Netz nicht. Eher Nervöser, soll heissen in der Grafik ging es hoch und runter und teilweise sind die Geräte auch mit nicht erreichbar gemeldet worden (ich überwache auch das).
                Andere die Top > 100 waren fielen auf 40 oder weniger beim zusätzlichen Verstärker Einsatz.
                Ich für mich finde das überwachen des “state“ zumindest mal hilfreich wenn auch nicht DIE Lösung.
                Vielleicht kann es auch dir helfen.
                Viele Grüsse Duffy
                evtl. hilft auch das
                Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
                Node.js: v22.23.2
                NPM: 10.9.4
                js-controller 7.1.2
                Linux: Trixie
                • DuffyD Duffy
                  @stefi
                  Viele Grüsse Duffy
                  Stefi
                  @duffy vielen Dank für die Info. Den Beitrag hatte ich tatsächlich bei meiner Fehleranalyse auch verfolgt 😳
                  Ich glaube einfach, dass es mit dem Zigbee-Mesh wie mit dem WLAN sein kann. Hast du viele außenrum, die zusätzlich Netze ausstrahlen (können), dann kann das auch mal instabiler werden. Möchte gar nicht wissen, was sonst noch alles für Störquellen sorgen kann.
                  • S Stefi
                    DuffyD Offline
                    DuffyD Offline
                    Duffy
                    @stefi
                    Ich habe um meine Hütte herum kaum andere Wlan Netzwerke (2 manchmal 3 gaaanz schwach), selbst wenn ich mein eigenes abgeschaltet hatte war da keine Verbesserung.
                    Liebe Grüsse Duffy
                    Node.js: v22.23.2
                    NPM: 10.9.4
                    js-controller 7.1.2
                    Linux: Trixie
                    • S Stefi
                      Great SUNG Offline
                      Great SUNG Offline
                      Great SUN
                      Rein technisch gesehen, liegt es sicher nicht an direkten "Störungen" wegen USB3. Allerdings kann es sein, dass Dein RaspPi evtl. wenn Du ein paar dicke Geräte (SSD z.B.) angeschlossen hast ein wenig unter Stromschwankungen leidet. Diese können dann theoretisch dazu führen, dass Geräte nicht sauber funktionieren bzw. auf Dauer evtl. sogar kaputt gehen.
                      Das Umstecken von USB3.0 auf USB2.0 bei Deiner SSD sorgt dafür, dass die SSD nicht mehr soviele Daten übertragen kann -> weniger Strom braucht.
                      Ich habe besonders auch deswegen, weil ich sowieso relativ groß und mit viel Holz lebe, einen mit WLAN verbundenen ZigBee GW der mit Tasmota läuft. So habe ich ganz sicher auch keine Stromprobleme ;-)
