  4. Shelly / Mqtt Adapter: Message 123 deleted after 11 retries
    5.3k
1 Beiträge 1 Kommentatoren 252 Aufrufe 1 Beobachtet
    Matzeit
    seit ca. 1 Woche oder so meldet der MQTT Adapter im Log folgende Abfolge im Sekundentakt:
    mqtt.0
    	2023-06-30 15:58:35.669	warn	Client [shellyplusi4-xxx] Message 62627 deleted after 12 retries
    mqtt.0
    	2023-06-30 15:58:35.668	warn	Client [shellyplusi4-xxx] Message 62628 deleted after 12 retries
    mqtt.0
    	2023-06-30 15:58:32.872	info	Client [shellyplusi4-xxx] publishOnSubscribe
    mqtt.0
    	2023-06-30 15:58:32.867	info	Client [shellyplusi4-xxx] publishOnSubscribe
    mqtt.0
    	2023-06-30 15:58:32.861	info	Client [shellyplusi4-xxx] publishOnSubscribe
    mqtt.0
    	2023-06-30 15:58:32.840	info	Client [shellyplusi4-xxx] publishOnSubscribe
    mqtt.0
    	2023-06-30 15:58:32.672	info	Client [shellyplusi4-xxx] subscribes on "mqtt.0.shellies.command"
    mqtt.0
    	2023-06-30 15:58:32.666	info	Client [shellyplusi4-xxx] subscribes on "mqtt.0.shellyplusi4-xxx.command"
    mqtt.0
    	2023-06-30 15:58:32.660	info	Client [shellyplusi4-xxx] subscribes on "mqtt.0.shellyplusi4-xxx.command.sys"
    mqtt.0
    	2023-06-30 15:58:32.639	info	Client [shellyplusi4-xxx] subscribes on "mqtt.0.shellyplusi4-xxx.rpc"
    mqtt.0
    	2023-06-30 15:58:32.588	info	Client [shellyplusi4-xxx] reconnected. Old secret 1688133502944_311. New secret 1688133512587_8208
    mqtt.0
    	2023-06-30 15:58:29.667	warn	Client [shellyplusi4-xxx] Message 62605 deleted after 11 retries
    mqtt.0
    	2023-06-30 15:58:27.667	warn	Client [shellyplusi4-xxx] Message 62606 deleted after 11 retries
    mqtt.0
    	2023-06-30 15:58:27.666	warn	Client [shellyplusi4-xxx] Message 62607 deleted after 11 retries
    mqtt.0
    	2023-06-30 15:58:27.666	warn	Client [shellyplusi4-xxx] Message 62608 deleted after 11 retries
    mqtt.0
    	2023-06-30 15:58:25.665	warn	Client [shellyplusi4-xxx] Message 62597 deleted after 12 retries
    Das betroffene Gerät ist ein Shelly i4 Plus (Gen2) Aktor. Firmware habe ich 0.14 drauf und auch schon die 1.0 beta5 probiert. An den MQTT Einstellungen habe ich nichts geändert. An dem Adapter sind noch zwei Sonoff nspanels dran. Diese funktionieren ohne Probleme.
    Auf den Shelly kann ich nicht zugreifen, außer wenn ich den MQTT Adapter deaktiviere. Ich vermute, dass die Kommunikation den Adapter arg zusetzt?
    Habe auch schon testweise alle Beteiligten neu gestartet, aber es bleibt dabei, das Log wird zugespammt.
