  4. Zigbee-kein Pairing mit gleichem Device möglich
    5.4k
11 Beiträge 3 Kommentatoren 978 Aufrufe 3 Beobachtet
    MiPl
    schrieb am zuletzt editiert von MiPl
    ich habe zwei Philips Bewegungsmelder. Trotz zahlreicher versuche inkl. Tausch der Batterien kann ich einen davon nicht fehlerfrei in Zigbee einbinden. Hier der log von heute Morgen:
    2023-06-17 04:19:59.897  - warn: zigbee.0 (24296) Blocked interview for 'undefined' because the network is closed
    2023-06-17 04:20:19.932  - error: zigbee.0 (24296) Failed to interview '0x00178801094a32a7', device has not successfully been paired. undefined
    2023-06-17 04:34:58.624  - warn: zigbee.0 (24296) Blocked interview for 'undefined' because the network is closed
    2023-06-17 04:35:18.649  - error: zigbee.0 (24296) Failed to interview '0x00178801094a32a7', device has not successfully been paired. undefined
    2023-06-17 06:00:00.060  - warn: javascript.0 (5134) You are assigning a string to the state "zigbee.0.cc86ecfffec3ab52.target_temperature" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
    2023-06-17 06:00:00.085  - info: javascript.0 (5134) State value to set for "zigbee.0.cc86ecfffec3ab52.target_temperature" has to be type "number" but received type "string"
    2023-06-17 06:09:51.684  - warn: zigbee.0 (24296) Blocked interview for 'undefined' because the network is closed
    2023-06-17 06:10:11.704  - error: zigbee.0 (24296) Failed to interview '0x00178801094a32a7', device has not successfully been paired. undefined
    2023-06-17 06:19:53.730  - warn: zigbee.0 (24296) Blocked interview for 'undefined' because the network is closed
    2023-06-17 06:20:13.764  - error: zigbee.0 (24296) Failed to interview '0x00178801094a32a7', device has not successfully been paired. undefined
    2023-06-17 06:55:40.779  - info: zigbee.0 (24296) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyACM0","manufacturer":"ITEAD","serialNumber":"20221202194853","pnpId":"usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20221202194853-if00","vendorId":"1a86","productId":"55d4"}]
    2023-06-17 07:04:36.817  - warn: zigbee.0 (24296) Blocked interview for 'undefined' because the network is closed
    2023-06-17 07:04:56.842  - error: zigbee.0 (24296) Failed to interview '0x00178801094a32a7', device has not successfully been paired. undefined
    2023-06-17 07:09:50.525  - warn: zigbee.0 (24296) Blocked interview for 'undefined' because the network is closed
    2023-06-17 07:10:10.544  - error: zigbee.0 (24296) Failed to interview '0x00178801094a32a7', device has not successfully been paired. undefined
    2023-06-17 07:14:35.662  - warn: zigbee.0 (24296) Blocked interview for 'undefined' because the network is closed
    2023-06-17 07:14:55.681  - error: zigbee.0 (24296) Failed to interview '0x00178801094a32a7', device has not successfully been paired. undefined
    2023-06-17 07:19:48.183  - warn: zigbee.0 (24296) Blocked interview for 'undefined' because the network is closed
    2023-06-17 07:20:08.218  - error: zigbee.0 (24296) Failed to interview '0x00178801094a32a7', device has not successfully been paired. undefined
    2023-06-17 07:23:24.850  - info: zigbee.0 (24296) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyACM0","manufacturer":"ITEAD","serialNumber":"20221202194853","pnpId":"usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20221202194853-if00","vendorId":"1a86","productId":"55d4"}]
    2023-06-17 07:23:37.331  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2023-06-17 07:23:37.349  - info: zigbee.0 (24296) Got terminate signal TERMINATE_YOURSELF
    2023-06-17 07:23:37.360  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
    2023-06-17 07:23:37.368  - info: zigbee.0 (24296) cleaned everything up...
    2023-06-17 07:23:37.441  - info: zigbee.0 (24296) Zigbee: disabling joining new devices.
    2023-06-17 07:23:37.871  - info: zigbee.0 (24296) terminating
    2023-06-17 07:23:37.873  - info: zigbee.0 (24296) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-06-17 07:23:38.365  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 24296
    2023-06-17 07:23:38.872  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-06-17 07:23:40.526  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 27993
    2023-06-17 07:23:51.952  - info: zigbee.0 (27993) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.0, js-controller: 4.0.24
    2023-06-17 07:23:52.246  - info: zigbee.0 (27993) delete old Backup files. keep only last 10
    2023-06-17 07:23:52.253  - info: zigbee.0 (27993) Starting Zigbee  npm ...
    2023-06-17 07:23:53.672  - info: zigbee.0 (27993) Installed Version: iobroker.zigbee@1.8.10
    2023-06-17 07:25:17.336  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2023-06-17 07:25:17.346  - info: zigbee.0 (27993) Got terminate signal TERMINATE_YOURSELF
    2023-06-17 07:25:17.347  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
    2023-06-17 07:25:17.351  - info: zigbee.0 (27993) cleaned everything up...
    2023-06-17 07:25:17.468  - info: zigbee.0 (27993) Zigbee: disabling joining new devices.
    2023-06-17 07:25:18.062  - warn: zigbee.0 (27993) Failed to stop zigbee during startup
    2023-06-17 07:25:18.064  - info: zigbee.0 (27993) terminating
    2023-06-17 07:25:18.068  - info: zigbee.0 (27993) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-06-17 07:25:18.349  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 27993
    2023-06-17 07:25:18.701  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-06-17 07:25:20.496  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 28014
    2023-06-17 07:25:28.363  - info: zigbee.0 (28014) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.0, js-controller: 4.0.24
    2023-06-17 07:25:28.619  - info: zigbee.0 (28014) delete old Backup files. keep only last 10
    2023-06-17 07:25:28.624  - info: zigbee.0 (28014) Starting Zigbee  npm ...
    2023-06-17 07:25:29.882  - info: zigbee.0 (28014) Installed Version: iobroker.zigbee@1.8.10
    2023-06-17 07:25:32.949  - info: zigbee.0 (28014) Coordinator firmware version: {"type":"EZSP v8","meta":{"product":8,"majorrel":"6","minorrel":"10","maintrel":"3 ","revision":"6.10.3.0 build 297"}}
    2023-06-17 07:25:32.952  - info: zigbee.0 (28014) Unable to disable LED, unsupported function.
    2023-06-17 07:25:32.990  - info: zigbee.0 (28014)   --> transmitPower : normal
    2023-06-17 07:25:33.028  - info: zigbee.0 (28014) Currently 4 devices are joined:
    2023-06-17 07:25:33.093  - info: zigbee.0 (28014) Configuring 0x00178801094a32a7 SML002
    2023-06-17 07:25:33.104  - info: zigbee.0 (28014) 0x00178801094a28f0 (addr 23572): 9290019758 - Philips Hue motion outdoor sensor (EndDevice)
    2023-06-17 07:25:33.132  - info: zigbee.0 (28014) 0x00178801094a32a7 (addr 53570): 9290019758 - Philips Hue motion outdoor sensor (EndDevice)
    2023-06-17 07:25:33.139  - info: zigbee.0 (28014) 0x0017880109c6e2f2 (addr 45509): 1741530P7 - Philips Hue Lily outdoor spot light (Router)
    2023-06-17 07:25:33.145  - info: zigbee.0 (28014) 0xcc86ecfffec3ab52 (addr 42243): SEA801-Zigbee/SEA802-Zigbee - Saswell Thermostatic radiator valve (EndDevice)
    2023-06-17 07:25:33.148  - info: zigbee.0 (28014) Zigbee started
    2023-06-17 07:25:33.632  - error: zigbee.0 (28014) DeviceConfigure:Failed to DeviceConfigure.configure 0x00178801094a32a7 SML002 (Error: Bind 0x00178801094a32a7/2 genPowerCfg from '0xdc8e95fffe25823a/1' failed (ZdoRequest error)
        at Driver.zdoRequest (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:571:19)
        at Object.func (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:538:13)
        at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32))
    2023-06-17 07:26:45.595  - info: zigbee.0 (28014) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyACM0","manufacturer":"ITEAD","serialNumber":"20221202194853","pnpId":"usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20221202194853-if00","vendorId":"1a86","productId":"55d4"}]
    2023-06-17 07:27:55.502  - warn: zigbee.0 (28014) Blocked interview for 'undefined' because the network is closed
    2023-06-17 07:27:57.250  - info: zigbee.0 (28014) Successfully interviewed '0x00178801094a28f0', device has successfully been paired
    2023-06-17 07:27:57.251  - info: zigbee.0 (28014) Device '0x00178801094a28f0' is supported, identified as: Philips Hue motion outdoor sensor (9290019758)
    2023-06-17 07:43:06.666  - warn: zigbee.0 (28014) Blocked interview for 'undefined' because the network is closed
    2023-06-17 07:43:26.967  - error: zigbee.0 (28014) Failed to interview '0x00178801094a32a7', device has not successfully been paired. undefined
    2023-06-17 07:44:34.574  - info: zigbee.0 (28014) State cleanup with {"force":false}
    2023-06-17 07:46:58.208  - info: zigbee.0 (28014) Configuring 0x00178801094a32a7 SML002
    2023-06-17 07:47:08.234  - error: zigbee.0 (28014) DeviceConfigure:Failed to DeviceConfigure.configure 0x00178801094a32a7 SML002 (Error: Bind 0x00178801094a32a7/2 genPowerCfg from '0xdc8e95fffe25823a/1' failed ({"address":53570,"clusterId":32801,"sequence":32} after 10000ms)
        at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)
    2023-06-17 07:56:12.382  - info: zigbee.0 (28014) Zigbee: allowing new devices to join.
    2023-06-17 07:56:34.266  - info: zigbee.0 (28014) Starting interview of '0x00178801094a32a7'
    2023-06-17 07:56:40.211  - info: zigbee.0 (28014) Successfully interviewed '0x00178801094a32a7', device has successfully been paired
    2023-06-17 07:56:40.212  - info: zigbee.0 (28014) Device '0x00178801094a32a7' is supported, identified as: Philips Hue motion outdoor sensor (9290019758)
    2023-06-17 07:56:40.216  - info: zigbee.0 (28014) Configuring 0x00178801094a32a7 SML002
    2023-06-17 07:56:50.235  - error: zigbee.0 (28014) DeviceConfigure:Failed to DeviceConfigure.configure 0x00178801094a32a7 SML002 (Error: Bind 0x00178801094a32a7/2 genPowerCfg from '0xdc8e95fffe25823a/1' failed ({"address":42997,"clusterId":32801,"sequence":42} after 10000ms)
    2023-06-17 07:56:53.746  - info: zigbee.0 (28014) Starting interview of '0x00178801094a32a7'
    2023-06-17 07:57:13.702  - info: zigbee.0 (28014) Zigbee: stop joining
    2023-06-17 07:57:13.755  - error: zigbee.0 (28014) Device 0xdc8e95fffe25823a "undefined" not described in statesMapping.
    2023-06-17 07:57:13.814  - error: zigbee.0 (28014) Failed to interview '0x00178801094a32a7', device has not successfully been paired. undefined
    2023-06-17 07:58:33.160  - info: zigbee.0 (28014) Zigbee: allowing new devices to join.
    2023-06-17 07:58:40.230  - info: zigbee.0 (28014) Starting interview of '0x00178801094a32a7'
    2023-06-17 07:58:46.438  - info: zigbee.0 (28014) Successfully interviewed '0x00178801094a32a7', device has successfully been paired
    2023-06-17 07:58:46.438  - info: zigbee.0 (28014) Device '0x00178801094a32a7' is supported, identified as: Philips Hue motion outdoor sensor (9290019758)
    2023-06-17 07:58:46.441  - info: zigbee.0 (28014) Configuring 0x00178801094a32a7 SML002
    2023-06-17 07:58:46.525  - warn: zigbee.0 (28014) Object 00178801094a32a7.motion_sensitivity is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    2023-06-17 07:58:46.525  - warn: zigbee.0 (28014) This object will not be created in future versions. Please report this to the developer.
    2023-06-17 07:58:46.544  - warn: zigbee.0 (28014) Object zigbee.0.00178801094a32a7.motion_sensitivity is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    2023-06-17 07:58:46.545  - warn: zigbee.0 (28014) This object will not be created in future versions. Please report this to the developer.
    2023-06-17 07:58:56.459  - error: zigbee.0 (28014) DeviceConfigure:Failed to DeviceConfigure.configure 0x00178801094a32a7 SML002 (Error: Bind 0x00178801094a32a7/2 genPowerCfg from '0xdc8e95fffe25823a/1' failed ({"address":42822,"clusterId":32801,"sequence":51} after 10000ms)
    2023-06-17 07:59:00.169  - info: zigbee.0 (28014) Starting interview of '0x00178801094a32a7'
    2023-06-17 07:59:20.192  - error: zigbee.0 (28014) Failed to interview '0x00178801094a32a7', device has not successfully been paired. undefined
    2023-06-17 07:59:34.509  - info: zigbee.0 (28014) Zigbee: stop joining
    2023-06-17 08:00:00.067  - warn: javascript.0 (5134) You are assigning a string to the state "zigbee.0.cc86ecfffec3ab52.target_temperature" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
    2023-06-17 08:00:00.093  - info: javascript.0 (5134) State value to set for "zigbee.0.cc86ecfffec3ab52.target_temperature" has to be type "number" but received type "string"
    2023-06-17 08:00:06.537  - info: zigbee.0 (28014) Zigbee: allowing new devices to join.
    2023-06-17 08:00:50.984  - info: zigbee.0 (28014) Starting interview of '0x00178801094a32a7'
    2023-06-17 08:00:56.885  - info: zigbee.0 (28014) Successfully interviewed '0x00178801094a32a7', device has successfully been paired
    2023-06-17 08:00:56.886  - info: zigbee.0 (28014) Device '0x00178801094a32a7' is supported, identified as: Philips Hue motion outdoor sensor (9290019758)
    2023-06-17 08:00:56.888  - info: zigbee.0 (28014) Configuring 0x00178801094a32a7 SML002
    2023-06-17 08:00:56.968  - warn: zigbee.0 (28014) Object 00178801094a32a7.motion_sensitivity is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    2023-06-17 08:00:56.969  - warn: zigbee.0 (28014) This object will not be created in future versions. Please report this to the developer.
    2023-06-17 08:00:56.985  - warn: zigbee.0 (28014) Object zigbee.0.00178801094a32a7.motion_sensitivity is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    2023-06-17 08:00:56.986  - warn: zigbee.0 (28014) This object will not be created in future versions. Please report this to the developer.
    2023-06-17 08:01:06.905  - error: zigbee.0 (28014) DeviceConfigure:Failed to DeviceConfigure.configure 0x00178801094a32a7 SML002 (Error: Bind 0x00178801094a32a7/2 genPowerCfg from '0xdc8e95fffe25823a/1' failed ({"address":48809,"clusterId":32801,"sequence":65} after 10000ms)
    2023-06-17 08:01:07.849  - info: zigbee.0 (28014) Zigbee: stop joining
    2023-06-17 08:01:11.699  - warn: zigbee.0 (28014) Blocked interview for 'undefined' because the network is closed
    Auch ein Neustart des Zigbee-Adapters führt nicht zum Ziel. Dabei ist mir aufgefallen, dass beim ersten Neustart des Adapters dieser auf gelb bleibt (Verbunden mit Gerät oder Dienst). Erst bei nochmaligem Neustart des Adapters wird dieser grün. Das habe ich mehrfach beobachtet in der Vergangenheit.
    Hat da jemand einen Lösungsansatz?
    Danke für Eure Hilfe.
    P 1 Antwort Letzte Antwort
    • M MiPl
      peterfido
      @mipl Meine Erfahrungen mit den Philips HUE Bewegunsmeldern sind durchwachsen.
      Das Beste, was ich machen konnte, war, diese gegen die Zigbee Bewegungsmelder von Ikea zu ersetzen. Die Philips waren mal da, dann wieder nicht, dann sogar mal "abgelernt".
      Peterfido
      M 2 Antworten Letzte Antwort
      • P peterfido
        MiPl
        @peterfido
        Danke für Deine Erfahrung. Werde mir die Alternative mal ansehen.
        Bei mir sieht es derzeit auch so aus. Derzeit ist auch der zweite Bewegungsmelder wieder "online". Merkwürdig. Nun gut, kann man wohl so nichts machen, da die Einstellungen ja zu stimmen scheinen.
        • P peterfido
          MiPl
          @peterfido
          ich nochmal. Meinst Du diesen Bewegungsmelder von Ikea: TRÅDFRI Funk-Bewegungsmelder, smart weiß?
          Der ist aber glaub ich nur für innen, oder?
          DJMarc75D P 2 Antworten Letzte Antwort
          • M MiPl
            @peterfido
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @mipl sagte in Zigbee-kein Pairing mit gleichem Device möglich:
            Link dazu würde helfen ;)
            Lehrling seit 1975 !!!
            • DJMarc75D DJMarc75
              MiPl
              @djmarc75
              kommt...
              link text
              • M MiPl
                @djmarc75
                kommt...
                link text
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                @mipl externe Links bitte nicht verschleiern
                  MiPl
                  @djmarc75
                  ähhm, ich habe den link aus dem Browser in die Zwischenablage kopiert, im Forum den Link-Button geklickt und die Zwischenablage eingefügt. Das sollte "vom System" ok sein. Ich kann es auch so übermitteln: https://www.ikea.com/de/de/p/tradfri-funk-bewegungsmelder-smart-weiss-70429913/
                  Besser?
                  • M MiPl
                    @djmarc75
                    Besser?
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    genau so ist es auch gewollt ;)
                    • M MiPl
                      @peterfido
                      peterfido
                      @mipl Tradfri passt. Stimmt, ich habe die nur innen im Betrieb. Außen sitzen Bewegungsmelder, welche direkt an eine Eaton Easy E4 gehen. Also klassische Bewegungsmelder mit 230 V.
                      Peterfido
                      • P peterfido
                        MiPl
                        @peterfido said in Zigbee-kein Pairing mit gleichem Device möglich:
                        Eaton Easy E4
                        Aha, ok.
                        Ich will jetzt keine weitere Baustelle bei mir aufmachen und Strippen ziehen. Werde wohl mit dem derzeitigen Zustand leben oder/und andere Bewegungmelder ausprobieren müssen. Danke für die Infos.
