  4. [gelöst] ioBroker startet nicht
    5.7k
4 Beiträge 2 Kommentatoren 1.2k Aufrufe
  • N Offline
    N Offline
    noxx
    bekomme bei der Installation einige Fehler/Hinweise. Unter <ip>:8081 ist
    der ioBroker (192.168.1.220:8081) auch nicht verfügbar.
    Installiert habe ich nach
    http://www.iobroker.net/docu/?page_id=5106&lang=de
    sudo npm install iobroker --unsafe-perm
    > iobroker@1.0.0 install /opt/iobroker/node_modules/iobroker
    > node lib/setup.js
    npm install iobroker.discovery --production --prefix /opt/iobroker
    node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v48-linux-arm.tar.gz
    node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.11.0 (node-v48 ABI) (falling back to source compile with node-gyp)
    ../src/serialport.cpp: In function ‘int getIntFromObject(v8::Local<v8::object>, std::string)’:
    ../src/serialport.cpp:90:52: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.0/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
       return getValueFromObject(options, key)->ToInt32()->Int32Value();
    ../src/serialport.cpp: In function ‘double getDoubleFromObject(v8::Local<v8::object>, std::string)’:
    ../src/serialport.cpp:102:53: warning: ‘v8::Local <v8::number>v8::Value::ToNumber() const’ is deprecated (declared at /root/.node-gyp/6.11.0/include/node/v8.h:8173): Use maybe version [-Wdeprecated-declarations]
       return getValueFromObject(options, key)->ToNumber()->NumberValue();
    ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
    ../src/serialport.cpp:174:31: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.0/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
         int fd = argv[1]->ToInt32()->Int32Value();
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:193:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.0/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
       int fd = info[0]->ToInt32()->Int32Value();
    ../src/serialport.cpp:217:116: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.0/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
       baton->baudRate = Nan::Get(options, Nan::New<v8::string>("baudRate").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Write(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:252:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.0/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:369:32: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.0/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
       baton->fd = info[0]->ToInt32()->Int32Value();
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:480:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.0/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:528:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.0/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:585:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.0/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
    ../src/serialport_unix.cpp: In function ‘OpenBatonPlatformOptions* ParsePlatformOptions(const v8::Local<v8::object>&)’:
    ../src/serialport_unix.cpp:44:109: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.0/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
       result->vmin = Nan::Get(options, Nan::New<v8::string>("vmin").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
    ../src/serialport_unix.cpp:45:111: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.0/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
       result->vtime = Nan::Get(options, Nan::New<v8::string>("vtime").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
    ../src/serialport_poller.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE SerialportPoller::New(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport_poller.cpp:86:31: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.0/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
       obj->fd_ = info[0]->ToInt32()->Int32Value();
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
    npm WARN iobroker No description
    npm WARN iobroker No repository field.
    npm WARN iobroker No README data
    npm WARN iobroker No license field.
    npm install iobroker.admin --production --prefix /opt/iobroker
    npm install iobroker.js-controller --production --prefix /opt/iobroker
    Write "./iobroker start" to start the ioBroker
    : Datei oder Verzeichnis nicht gefunden
    Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
    iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
    /opt/iobroker
    └─┬ iobroker@1.0.0
      └─┬ yargs@7.1.0
        ├── camelcase@3.0.0
        ├─┬ cliui@3.2.0
        │ ├─┬ strip-ansi@3.0.1
        │ │ └── ansi-regex@2.1.1
        │ └── wrap-ansi@2.1.0
        ├── decamelize@1.2.0
        ├── get-caller-file@1.0.2
        ├─┬ os-locale@1.4.0
        │ └─┬ lcid@1.0.0
        │   └── invert-kv@1.0.0
        ├─┬ read-pkg-up@1.0.1
        │ ├─┬ find-up@1.1.2
        │ │ ├── path-exists@2.1.0
        │ │ └─┬ pinkie-promise@2.0.1
        │ │   └── pinkie@2.0.4
        │ └─┬ read-pkg@1.1.0
        │   ├─┬ load-json-file@1.1.0
        │   │ ├── graceful-fs@4.1.11
        │   │ ├─┬ parse-json@2.2.0
        │   │ │ └─┬ error-ex@1.3.1
        │   │ │   └── is-arrayish@0.2.1
        │   │ ├── pify@2.3.0
        │   │ └─┬ strip-bom@2.0.0
        │   │   └── is-utf8@0.2.1
        │   ├─┬ normalize-package-data@2.3.8
        │   │ ├── hosted-git-info@2.4.2
        │   │ ├─┬ is-builtin-module@1.0.0
        │   │ │ └── builtin-modules@1.1.1
        │   │ ├── semver@5.3.0
        │   │ └─┬ validate-npm-package-license@3.0.1
        │   │   ├─┬ spdx-correct@1.0.2
        │   │   │ └── spdx-license-ids@1.2.2
        │   │   └── spdx-expression-parse@1.0.4
        │   └── path-type@1.1.0
        ├── require-directory@2.1.1
        ├── require-main-filename@1.0.1
        ├── set-blocking@2.0.0
        ├─┬ string-width@1.0.2
        │ ├── code-point-at@1.1.0
        │ └─┬ is-fullwidth-code-point@1.0.0
        │   └── number-is-nan@1.0.1
        ├── which-module@1.0.0
        ├── y18n@3.2.1
        └── yargs-parser@5.0.0
    npm WARN iobroker No license field.</v8::int32></v8::string></v8::int32></v8::string></v8::int32></v8::object></v8::int32></v8::int32></v8::int32></v8::int32></v8::int32></v8::string></v8::int32></v8::int32></v8::int32></v8::number></v8::object></v8::int32></v8::object>
    ````</ip>
    • eric2905E Offline
      eric2905E Offline
      eric2905
      Schon einen reboot des Raspi probiert?
      Laut Log wurde ioBroker installiert (steht kurz vor der Baumstruktur).
      Gruß,
      Eric
      Gesendet von iPad mit Tapatalk
      • N Offline
        N Offline
        noxx
        Reboot hat geholfen :-)
        Sorry…
        • eric2905E Offline
          eric2905E Offline
          eric2905
          Kein Problem.
          Änderst Du noch bitte den Betreff und setzt ein [gelöst] davor?
          Danke,
          Eric
