  3. Entwicklung
  4. Fehler bei Test und Release Workflows
    5.2k
3 Beiträge 2 Kommentatoren 464 Aufrufe 2 Beobachtet
  • Z Offline
    Z Offline
    zap
    die Test und Release Workflows in Github schlagen für meinen Adapter regelmäßig fehl (https://github.com/zapccu/ioBroker.sma-ev-charger).
    Die Fehlermeldungen beim Adapter Test (Ubuntu) lauten:
    npm ERR! code ENOTSUP
    264
    npm ERR! notsup Unsupported engine for iobroker.js-controller@5.0.1-alpha.0-20230525-c580eb7e: wanted: {"node":">=16.4.0"} (current: {"node":"14.21.3","npm":"6.14.18"})
    265
    npm ERR! notsup Not compatible with your version of node/npm: iobroker.js-controller@5.0.1-alpha.0-20230525-c580eb7e
    266
    267
    npm ERR! notsup Required: {"node":">=16.4.0"}
    268
    npm ERR! notsup Actual:   {"npm":"6.14.18","node":"14.21.3"}
    Das kommt mehrfach. Dann noch dieser Fehler hier (vielleicht ein Folgefehler):
    1) Adapter integration tests
    299
           "before all" hook: prepareTests in "Adapter integration tests":
    300
         Error: /tmp/test-iobroker.sma-ev-charger/iobroker-data/iobroker.json: ENOENT: no such file or directory, open '/tmp/test-iobroker.sma-ev-charger/iobroker-data/iobroker.json'
    301
          at Object.openSync (fs.js:498:3)
    302
          at Object.readFileSync (fs.js:394:35)
    303
          at readFileSync (node_modules/jsonfile/index.js:50:22)
    304
          at DBConnection.getSystemConfig (node_modules/@iobroker/testing/build/tests/integration/lib/dbConnection.js:115:44)
    305
          at DBConnection.get objectsType [as objectsType] (node_modules/@iobroker/testing/build/tests/integration/lib/dbConnection.js:102:21)
    306
          at DBConnection.createObjectsDB (node_modules/@iobroker/testing/build/tests/integration/lib/dbConnection.js:175:34)
    307
          at DBConnection.start (node_modules/@iobroker/testing/build/tests/integration/lib/dbConnection.js:149:20)
    308
          at Context.prepareTests (node_modules/@iobroker/testing/build/tests/integration/index.js:66:28)
    309
          at processTicksAndRejections (internal/process/task_queues.js:95:5)
    Leider habe ich keine Erfahrung mit ioBroker Entwicklung. Ist mein erster Adapter. Also sorry schonmal, wenn das eine blöde Frage ist.
    ? 1 Antwort Letzte Antwort
    • Z zap
      264
      265
      266
      267
      268
      299
      300
      301
      302
      303
      304
      305
      306
      307
      308
      309
      @zap hi,
      Die node version 14x wird bei Test & release nicht mehr unterstützt. Dies musst du händisch selbst änder in der datei .github/workflows/test-and-release.yml
      Dort kannst du die node versionen wo nur eine version bei dir drin steht (bei der ersten ist es bei dir node v16.x und bei der ganz unten node v14.x) kannst auf node v16.x oder auf v18.x ändern und bei der wo drei versionen drin steht (das in der mitte ca.) nimmst du das v14.x raus und machst daraus
      node-version: [16.x, 18.x, 20.x]
      Z 1 Antwort Letzte Antwort
        @zap hi,
        Z Offline
        Z Offline
        zap
        @ciddi89 Das wars. Tests laufen nun fehlerfrei durch. Vielen Dank!
