  4. IOB nicht erreichbar, per Putty schon. *gelöst*
    5.4k
26 Beiträge 4 Kommentatoren 812 Aufrufe 4 Beobachtet
  • G gluecksmann
    @glasfaser
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     22:31:31 up 14 min,  1 user,  load average: 0.52, 1.06, 0.81
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=63.3'C
    volt=0.8500V
    *** Time and Time Zones ***
                   Local time: Sun 2023-04-16 22:31:31 CEST
               Universal time: Sun 2023-04-16 20:31:31 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           7.9G        1.6G        5.7G        8.0M        565M        6.5G
    Swap:           99M          0B         99M
    Total:         8.0G        1.6G        5.8G
             7898 M total memory
             1629 M used memory
              285 M active memory
             1787 M inactive memory
             5703 M free memory
              104 M buffer memory
              461 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FILESYSTEM ***
    /dev/root      ext4       29G   10G   18G  36% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     3.9G  8.5M  3.9G   1% /run
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
    [Sun Apr 16 22:17:18 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:3D:9B:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sun Apr 16 22:17:19 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Sun Apr 16 22:17:19 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Apr 16 22:17:21 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    Show mounted filesystems (real ones only):
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    408M    /var/
    117M    /var/lib
    112M    /var/log
    76M     /var/cache
    69M     /var/lib/apt/lists
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    85M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    554M    /opt/iobroker/iobroker-data/
    270M    /opt/iobroker/iobroker-data/files
    140M    /opt/iobroker/iobroker-data/backup-objects
    87M     /opt/iobroker/iobroker-data/sonosCache
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
    22M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
    12M     /opt/iobroker/iobroker-data/objects.json.migrated
    12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.19.1
    /usr/bin/node           v16.19.1
    /usr/bin/npm            8.19.3
    /usr/bin/npx            8.19.3
    nodejs:
      Installed: 16.19.1-deb-1nodesource1
      Candidate: 16.19.1-deb-1nodesource1
      Version table:
     *** 16.19.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
            100 /var/lib/dpkg/status
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    MULTIHOSTSERVICE/enabled: false
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
    npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
    npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
    npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
    npm ERR! invalid: iobroker.govee@0.0.5 /opt/iobroker/node_modules/iobroker.govee
    npm ERR! invalid: iobroker.icons-ultimate-png@1.0.1 /opt/iobroker/node_modules/iobroker.icons-ultimate-png
    npm ERR! invalid: iobroker.vis-icontwo@0.90.0 /opt/iobroker/node_modules/iobroker.vis-icontwo
    npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
    npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
    npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
    npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
    npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
    npm ERR!     /home/pi/.npm/_logs/2023-04-16T20_31_54_097Z-debug-0.log
    Adapters from github:   3
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
      system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
    + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
      system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
      system.adapter.devices.0                : devices               : raspberrypi                              - disabled
    + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
    + system.adapter.govee.0                  : govee                 : raspberrypi                              -  enabled
    + system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              -  enabled
      system.adapter.history.0                : history               : raspberrypi                              - disabled
    + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
    + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
    + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
    + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
    + system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
    + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
    + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
    + system.adapter.philips-air.0            : philips-air           : raspberrypi                              -  enabled
    + system.adapter.philips-air.1            : philips-air           : raspberrypi                              -  enabled
      system.adapter.philips-tv.0             : philips-tv            : raspberrypi                              - disabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
      system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
    + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
      system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
      system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.3.5    , installed 6.3.5
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "alias-manager": 1.2.4    , installed 1.2.6
    Adapter    "backitup"     : 2.6.16   , installed 2.5.12 [Updatable]
    Adapter    "ble"          : 0.13.0   , installed 0.13.0
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "chromecast"   : 3.0.3    , installed 2.3.1  [Updatable]
    Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
    Adapter    "devices"      : 1.1.2    , installed 1.1.2
    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hue"          : 3.7.1    , installed 3.7.1
    Adapter    "ical"         : 1.13.2   , installed 1.13.2
    Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
    Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
    Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.14.2   , installed 1.14.2
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Controller "js-controller": 4.0.24   , installed 4.0.24
    Adapter    "meross"       : 1.14.0   , installed 1.14.0
    Adapter    "mielecloudservice": 6.4.0, installed 6.4.0
    Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
    Adapter    "musiccast"    : 0.1.5    , installed 0.2.2
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
    Adapter    "philips-air"  : 1.0.1    , installed 1.0.1
    Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
    Adapter    "ping"         : 1.5.3    , installed 1.5.3
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "scenes"       : 2.3.9    , installed 2.3.9
    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
    Adapter    "shuttercontrol": 1.4.23  , installed 1.4.18 [Updatable]
    Adapter    "smartcontrol" : 1.3.2    , installed 1.2.1  [Updatable]
    Adapter    "socketio"     : 4.2.0    , installed 6.1.7
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "sonos"        : 2.2.3    , installed 2.2.3
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tuya"         : 3.13.1   , installed 3.13.1
    Adapter    "vis"          : 1.4.16   , installed 1.4.15 [Updatable]
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-icontwo"  : 0.93.0   , installed 0.90.0 [Updatable]
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "web"          : 4.3.0    , installed 5.2.3
    Adapter    "ws"           : 1.3.0    , installed 2.1.2
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        11010
    States:         9062
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 https://deb.nodesource.com/node_16.x buster InRelease
    Hit:3 http://archive.raspberrypi.org/debian buster InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17935      651/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16045      393/cupsd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20949      1045/io.sonoff.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19578      642/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18195      642/iobroker.js-con
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18264      721/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       27821      2288/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17937      651/sshd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16044      393/cupsd
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       20101      1029/io.sonos.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       21777      1076/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       21778      1076/io.tuya.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16097      640/dhcpcd
    udp        0      0 0.0.0.0:41038           0.0.0.0:*                           1001       19370      949/io.philips-air.
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16073      480/cups-browsed
    udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       22505      1369/io.musiccast.0
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       27576      2786/io.broadlink2.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14981      387/avahi-daemon: r
    udp        0      0 0.0.0.0:49935           0.0.0.0:*                           1001       21752      1061/io.philips-air
    udp        0      0 0.0.0.0:47902           0.0.0.0:*                           108        14983      387/avahi-daemon: r
    udp        0      0 0.0.0.0:37188           0.0.0.0:*                           1001       29782      2786/io.broadlink2.
    udp6       0      0 :::546                  :::*                                0          16109      640/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        14982      387/avahi-daemon: r
    udp6       0      0 :::46429                :::*                                108        14984      387/avahi-daemon: r
    2023-04-16 22:28:49.458  - warn: fullybrowser.0 (1170) updateDeviceERROR 192.168.2.176
    2023-04-16 22:29:52.353  - warn: fullybrowser.0 (1170) updateDeviceERROR 192.168.2.176
    2023-04-16 22:30:00.121  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 20228
    2023-04-16 22:30:03.061  - info: dwd.0 (20228) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.1, js-controller: 4.0.24
    2023-04-16 22:30:04.151  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 20456
    2023-04-16 22:30:04.724  - info: dwd.0 (20228) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-04-16 22:30:05.259  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-04-16 22:30:07.054  - info: daswetter.0 (20456) starting. Version 3.1.7 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.19.1, js-controller: 4.0.24
    2023-04-16 22:30:08.187  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 20495
    2023-04-16 22:30:12.087  - info: ical.0 (20495) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v16.19.1, js-controller: 4.0.24
    2023-04-16 22:30:13.822  - info: ical.0 (20495) processing GELOESCHT basic.ics
    2023-04-16 22:30:20.371  - info: ical.0 (20495) Terminated (NO_ERROR): Without reason
    2023-04-16 22:30:20.905  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2023-04-16 22:30:21.555  - info: daswetter.0 (20456) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2023-04-16 22:30:22.071  - info: daswetter.0 (20456) cleaned everything up...
    2023-04-16 22:30:22.085  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-04-16 22:30:55.779  - warn: fullybrowser.0 (1170) updateDeviceERROR 192.168.2.176
    2023-04-16 22:31:21.908  - error: gruenbeck.0 (1200) https://prod-eu-gruenbeck-api.azurewebsites.net/api/devices/softliQ.C/GELOESCHT/realtime/enter?api-version=2020-08-03
    2023-04-16 22:31:21.909  - error: gruenbeck.0 (1200) AxiosError: Request failed with status code 404
    2023-04-16 22:31:21.910  - error: gruenbeck.0 (1200) Failed enter SD
    2023-04-16 22:31:21.910  - info: gruenbeck.0 (1200) Relogin
    2023-04-16 22:31:22.208  - info: gruenbeck.0 (1200) Login step 1
    2023-04-16 22:31:22.575  - info: gruenbeck.0 (1200) Login step 2
    2023-04-16 22:31:23.028  - info: gruenbeck.0 (1200) Login successful
    2023-04-16 22:31:59.134  - warn: fullybrowser.0 (1170) updateDeviceERROR 192.168.2.176
    MOD-EDIT: private Daten gelöscht!
    GlasfaserG Offline
    GlasfaserG Offline
    Glasfaser
    @gluecksmann sagte in IOB nicht erreichbar, per Putty schon.:
    Aber , die die aus , warum !
    G 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      gluecksmann
      @glasfaser
      ich wünschte ich könnte diese Frage beantworten ;-) Hab es nicht ausgeschaltet...
        @glasfaser
        Das habe ich aber eigendlich....
        Alles gut ... deshalb wollte ich die Full Ausgabe sehen !!!
        gluecksmann
        @glasfaser
        Sieht man da auch warum Adapter Updates bei mir ewig brauchen?
        • CodierknechtC Codierknecht
          @glasfaser sagte in IOB nicht erreichbar, per Putty schon.:
          das ist nur die Zusammenfassung, die Full ist am anfang .
          Reicht aber schon um zu sehen, dass hier eine veraltete Installation am Start ist.
          @gluecksmann Buster ist tot, installier da Bullseye.
          Und dann dabei auch das Target umstellen auf MultiUser.
          gluecksmann
          @codierknecht
          Sorry...diese Aussagen bringen mich nicht wirklich weiter....Ich benötige wenn...sehr genaue Anleitung dazu...
          • G gluecksmann
            @glasfaser
            GlasfaserG Offline
            GlasfaserG Offline
            Glasfaser
            Was heißt ...
            bei Nodejs 14 hätte ich es mir noch vorstellen können ( Fehler war mal dort vorhanden ) , aber du hast schon Nodejs 16 da ist es nicht mehr vorhanden.
            Du hast da ein paar Beta Adapter vorhanden !
            Vorschlag :
            Aktuelles Backup erstellen ,
            ioBroker mit Bullseye ( inkl. Nodejs18 ) neu aufsetzen
              Was heißt ...
              Vorschlag :
              gluecksmann
              @glasfaser
              Sorry, sei mir nicht böse... ich bin dankbar für die Hilfe... aber ich fürchte daaüfr fehlt uns beiden die Geduld das durchzuspielen...
