  4. Solaredge Adapter (Photovoltaikanlage)
    2.7k
    4.7k
    4.0k
431 Beiträge 59 Kommentatoren 184.8k Aufrufe 45 Beobachtet
  • G guitardoc
    @manfredhi Woher hast du denn diese Register? Ich habe die gleiche Kombination (allerdings mit LVS 20) und verwende diese Register:
    _address	name	description	unit	type	len	factor	offset	formula	role	room	poll	wp	cw	isScale
    97709	Batt1_Avg_T	Batterie 1 Average Temperature °C		floatsw	2	1	0		level		true	false	false	false
    101697	CommitSettings	Commit Power Control Settings		uint16be	1	1	0		level		true	false	false	false
    101698	Restore Power Control Default Settings	Restore Power Control Default Settings		uint16be	1	1	0		level		true	false	false	false
    101701	ReactivePwrConfig	ReactivePwrConfig		uint32sw	2	1	0		level		true	false	false	false
    101761	PowerReduce	PowerReduce		floatsw	2	1	0		level		true	false	false	false
    101763	AdvancedPwrControlEn	AdvancedPwrControlEn		uint32sw	2	1	0		level		true	false	false	false
    102721	Battery 1 Manufacturer Name	Battery 1 Manufacturer Name		string	8	1	0		level		true	false	false	false
    102737	Battery 1 Model	Battery 1 Model		string	16	1	0		level		true	false	false	false
    102753	Battery 1 Firmware Version	Battery 1 Firmware Version		string	16	1	0		level		true	false	false	false
    102769	Battery 1 Serial Number	Battery 1 Serial Number		string	16	1	0		level		true	false	false	false
    102787	Batt Rated Energy	Batt Rated Energy	Wh	floatsw	2	1	0		level		true	false	false	false
    102789	Battery 1 Max Charge Continues Power	Battery 1 Max Charge Continues Power	W	floatsw	2	1	0		level		true	false	false	false
    102791	Battery 1 Max Discharge Continues Power	Battery 1 Max Discharge Continues Power	W	floatsw	2	1	0		level		true	false	false	false
    102829	Batt1_Avg_T	Batterie 1 Average Temperature °C	°C	floatsw	2	1	0		level		true	false	false	false
    102837	Speicher_Ladung	Speicher Ladeleistung	W	floatsw	2	1	0		level		true	false	false	false
    102839	xBattery 1 Lifetime Export Energy Counter	Battery 1 Lifetime Export Energy Counter	Wh	uint64le	4	1	0		value		true	false	false	false
    102843	xBattery 1 Lifetime Import Energy Counter	Battery 1 Lifetime Import Energy Counter	Wh	uint64le	4	1	0		value		true	false	false	false
    102847	Battery 1 Max Energy	Battery 1 Max Energy	Wh	floatsw	2	1	0		level		true	false	false	false
    102849	Battery 1 Available Energy	Battery 1 Available Energy	Wh	floatsw	2	1	0		level		true	false	false	false
    102851	Speicher_SoH	Batterie Alterung	%	floatsw	2	1	0		level		true	false	false	false
    102853	Speicher_SoC	Batterieladung	%	floatsw	2	1	0		level		true	false	false	false
    102855	Speicher_Betriebszustand	1: Aus, 3: Laden, 4: Entladen, 6: Erhaltungsladen		uint32sw	2	1	0		level		true	false	false	false
    102857	Battery 1 Status Internal	Battery 1 Status Internal		uint32sw	2	1	0		level		true	false	false	false
    102859	Battery 1 Events Log	Battery 1 Events Log		uint32sw	2	1	0		level		true	false	false	false
    102867	Battery 1 Events Log Internal	Battery 1 Events Log Internal		uint32sw	2	1	0		level		true	false	false	false
    103233	Export Control Mode	Export Control Mode		uint16be	1	1	0		level		true	false	false	false
    103234	Export Control Limit Mode	Export Control Limit Mode		uint16be	1	1	0		level		true	false	false	false
    103235	Export Control Site Limit	Export Control Site Limit		floatsw	2	1	0		level		true	false	false	false
    103237	Str	Storage control mode		uint16be	1	1	0		level		true	false	false	false
    103238	Storage_AC_Charge_Policy_RW	0: Disable, 1: Always allowed , 2: Fixed Energy Limit		uint16be	1	1	0		level		true	false	false	false
    103239	Storage AC Charge Limit	Storage AC Charge Limit	%	floatsw	2	1	0		level		true	false	false	false
    103241	Storage_Backup_Reserved_Setting	Storage Backup Reserved Setting	%	floatsw	2	1	0		level		true	false	false	false
    103243	StChDisChMode	Storage Charge/Discharge Mode		uint16be	1	1	0		level		true	false	false	false
    103244	Timeout	Timout	sec	uint32sw	2	1	0		level		true	false	false	false
    103246	Remote Control Command Mode RW	Remote Control Command Mode RW		uint16be	1	1	0		level		true	false	false	false
    103247	Remote Control Charge Limit	Remote Control Charge Limit	W	floatsw	2	1	0		level		true	false	false	false
    103249	Remote Control Command Discharge Limit	Remote Control Command Discharge Limit	W	floatsw	2	1	0		level		true	false	false	false
    40001	C_SunSpec_ID	"Wert = ""SunS"" (0x53756e53). Identifiziert dies eindeutig als eine SunSpec Modbus-Karte"		uint32be	2	1	0				true	false	false	false
    40003	C_SunSpec_DID	Wert = 0x0001. Identifiziert dies eindeutig als einen SunSpec “Common Block“		uint16be	1	1	0				true	false	false	false
    40004	C_SunSpec_Länge	65 = Länge eines Blocks in 16-bit Registern		uint16be	1	1	0				true	false	false	false
    40005	C_Hersteller	"Bei SunSpec eingetragener Wert = ""SolarEdge"""		string	16	1	0				true	false	false	false
    40021	C_Modell	Spezifischer SolarEdge Wert		string	16	1	0				true	false	false	false
    40045	C_Version	Spezifischer SolarEdge Wert		string	8	1	0				true	false	false	false
    40053	C_Seriennummer	Eindeutiger SolarEdge Wert		string	16	1	0				true	false	false	false
    40069	C_DeviceAddress 	MODBUS Unit ID		uint16be	1	1	0				true	false	false	false
    40070	C_SunSpec_DID	101 = Einphasig, 102 = Spaltphase, 103 = Dreiphasig		uint16be	1	1	0				true	false	false	false
    40072	I_AC_Strom	AC-Gesamtstromwert	A	uint16be	1	1	0	x * Math.pow(10, sf['40076'])			true	false	false	false
    40073	I_AC_StromA	AC-Phase A (L1) Stromwert	A	uint16be	1	1	0	x * Math.pow(10, sf['40076'])			true	false	false	false
    40074	I_AC_StromB	AC-Phase B (L2) Stromwert	A	uint16be	1	1	0	x * Math.pow(10, sf['40076'])			true	false	false	false
    40075	I_AC_StromC	AC-Phase C (L3) Stromwert	A	uint16be	1	1	0	x * Math.pow(10, sf['40076'])			true	false	false	false
    40076	I_AC_Strom_SF	AC-Strom Skalierungsfaktor	SF	int16be	1	1	0				true	false	false	true
    40084	I_AC_Leistung	AC-Leistungswert	W	uint16be	1	1	0	x * Math.pow(10, sf['40085'])			true	false	false	false
    40085	I_AC_Leistung_SF	AC-Leistung Skalierungsfaktor	SF	int16be	1	1	0				true	false	false	true
    40088	I_AC_VA	Scheinleistung	VA	uint16be	1	1	0	x * Math.pow(10, sf['40089'])			true	false	false	false
    40089	I_AC_VA_SF	Scheinleistung Skalierungsfaktor	SF	int16be	1	1	0				true	false	false	true
    40090	I_AC_VAR	Blindleistung	VAR	uint16be	1	1	0	x * Math.pow(10, sf['40091'])			true	false	false	false
    40091	I_AC_VAR_SF	Blindleistung Skalierungsfaktor	SF	int16be	1	1	0				true	false	false	true
    40092	I_AC_PF	Leistungsfaktor	%	uint16be	1	1	0	x * Math.pow(10, sf['40093'])			true	false	false	false
    40093	I_AC_PF_SF	Leistungsfaktor Skalierungsfaktor	SF	int16be	1	1	0				true	false	false	true
    40094	I_AC_Energie_WH	AC Gesamt-Energieproduktion	kWh	uint32be	2	1	0	x * Math.pow(10, sf['40096'] - 3)			true	false	false	false
    40096	I_AC_Energie_WH_SF	AC Gesamtenergie Skalierungsfaktor	SF	uint16be	1	1	0				true	false	false	true
    40097	I_DC_Strom	DC-Stromwert	A	uint16be	1	1	0	x * Math.pow(10, sf['40098'])			true	false	false	false
    40098	I_DC_Strom_SF	DC-Strom Skalierungsfaktor	SF	int16be	1	1	0				true	false	false	true
    40099	I_DC_Spannung	DC-Spannungswert	V	uint16be	1	1	0	x * Math.pow(10, sf['40100'])			true	false	false	false
    40100	I_DC_Spannung_SF	DC-Spannung Skalierungsfaktor	SF	int16be	1	1	0				true	false	false	true
    40101	I_DC_Leistung	DC-Leistungswert	W	uint16be	1	1	0	x * Math.pow(10, sf['40102'])			true	false	false	false
    40102	I_DC_Leistung_SF	DC-Leistung Skalierungsfaktor	SF	int16be	1	1	0				true	false	false	true
    40104	I_Temp_Kühler	Kühlkörpertemperatur	°C	uint16be	1	1	0	x * Math.pow(10, sf['40107'])			true	false	false	false
    40107	I_Temp_SF	Kühlkörpertemperatur Skalierungsfaktor	SF	int16be	1	1	0				true	false	false	true
    40108	I_Status	Betriebszustand (1 = Aus, 2 = Schlafen (Automatisches Herunterfahren) – Nachtmodus, 3 = Aufwachen/Starten, 4 = Wechselrichter ist AN und wandelt Energie, 5 = Begrenzte Produktion, 6 = Herunterfahren, 7 = Fehler, 8 = Wartung/Setup)		uint16be	1	1	0				true	false	false	false
    40109	I_Status_Anbieter	Anbieter-spezifischer Betriebszustand sowie Fehlercodes: 1 = Aus, 2 = Schlafen (Automatisches Herunterfahren) – Nachtmodus, 3 = Aufwachen/Starten, 4 = Wechselrichter ist AN und wandelt Energie, 5 = Begrenzte Produktion, 6 = Herunterfahren, 7 = Fehler, 8 = Wartung/Setup		uint16be	1	1	0				true	false	false	false
    40124	C_Manufacturer	Meter manufacturer		string	32	1	0				true	false	false	false
    40140	C_Model	Meter model		string	32	1	0				true	false	false	false
    40156	C_Option	Export + Import, Production, consumption		string	16	1	0				true	false	false	false
    40191	M_AC_Current	AC Current (sum of active phases)	A	uint16be	1	1	0	x * Math.pow(10, sf['40195'])			true	false	false	false
    40192	M_AC_Current_A	Phase A AC Current	A	uint16be	1	1	0	x * Math.pow(10, sf['40195'])			true	false	false	false
    40193	M_AC_Current_B	Phase B AC Current	A	uint16be	1	1	0	x * Math.pow(10, sf['40195'])			true	false	false	false
    40194	M_AC_Current_C	Phase C AC Current	A	uint16be	1	1	0	x * Math.pow(10, sf['40195'])			true	false	false	false
    40195	M_AC_Current_S F	AC Current Scale Factor	SF	int16be	1	1	0				true	false	false	true
    40207	M_AC_Power	Total Real Power (sum of active phases)	W	int16be	1	1	0	x * Math.pow(10, sf['40211'])			true	false	false	false
    40211	M_AC_Power_SF	AC Real Power Scale Factor	SF	int16be	1	1	0				true	false	false	true
    40221	M_AC_PF	Average Power Factor (average of active phases)	%	uint16be	1	1	0	x * Math.pow(10, sf['40226'])			true	false	false	false
    40226	M_AC_PF_SF	AC Power Factor Scale Factor	SF	int16be	1	1	0				true	false	false	true
    40227	M_Exported	Total Exported Real Energy	kWh	uint32be	2	1	0	x * Math.pow(10, sf['40243'] - 3)			true	false	false	false
    40235	M_Imported	Total Imported Real Energy	kWh	uint32be	2	1	0	x * Math.pow(10, sf['40243'] - 3)			true	false	false	false
    40243	M_Energy_W_SF	Real Energy Scale Factor	SF	int16be	1	1	0				true	false	false	true
    Edit: Die Berechnungen zu Verbrauch und die zugehörigen Register findest du in meinem Post darüber.
    lisalisa
    schrieb am zuletzt editiert von lisalisa
    #421
    @guitardoc
    Die von @manfredhi sind die gleichen wie diese:
    Falls du noch mehr Register brauchst...
    Die funktioniern bei mir auch:
    101699 PwrFrqDeratingConfig PwrFrqDeratingConfig uint32sw 2 1 0 level true false false false
    102209 Enable Dynamic Power Control Enable Dynamic Power Control uint16be 1 1 0 level true false false false
    102221 Active Power Limit Active Power Limit W floatsw 2 1 0 level true false false false
    102223 Reactive Power Limit Reactive Power Limit W floatsw 2 1 0 level true false false false
    102225 Command Timeout Command Timeout Sec uint32sw 2 1 0 level true false false false
    G 1 Antwort Letzte Antwort
    • L lisalisa
      @guitardoc
      guitardoc
      schrieb am zuletzt editiert von guitardoc
      #422
      @lisalisa Die Register geben sinnvolle Werte zurück. Die Frage ist aber - was bedeuten diese? Hast du da Erläuterungen dazu?
      101699: ist bei mir eine 7
      102209: ist bei mir eine 0
      Die anderen Werte sind klar.
      L 1 Antwort Letzte Antwort
      • G guitardoc
        lisalisa
        #423
        @guitardoc Erklärungen stehen wie immer in "Power Control Open Protocol for SolarEdge Inverters.pdf".
        Habe aber wie meistens keine Ahnung was man damit machen könnte. Ich verwende die Register nicht, habe nur mal rumgespielt welche funktionieren.
        F102 = 101699
        F300 = 102209
        • G Offline
          guitardoc
          #424
          @lisalisa said in Solaredge Adapter (Photovoltaikanlage):
          Cool. Das Dokument kannte ich noch gar nicht. Vielen Dank für die Info! Das hilft schon mal sehr weiter.
          Allerdings scheint es nicht aktuell zu sein... 101699 kann Werte von 0-4 annehmen (entsprechend Dokument) - bei mir steht da eine 7...
          Ist aber eigentlich auch egal, die Werte die ich brauche hab ich ja dank deiner Hilfe.
          • G guitardoc
            lisalisa
            #425
            @guitardoc sagte in Solaredge Adapter (Photovoltaikanlage):
            Bei mir steht auch 7
            Wenn du die PDF nicht kennst hast du den Beitrag wahrscheinlich auch nicht gelesen
            https://forum.iobroker.net/post/1130330
            • L lisalisa
              guitardoc
              #426
              @lisalisa Doch, hatte ich - aber mein Open Office (auf Mac) hat die Datei völlig falsch formatiert angezeigt, da konnte ich nichts damit anfangen. Besser als pdf posten, da ist die Anzeige überall gleich...
              • G guitardoc
                lisalisa
                #427
                Ich dachte als Open Office wäre besser da könnte man noch eigene Kommentare oder so hinzufügen...
                Decimal Power Control Open Protocol for SolarEdge Inverters.en.de.pdf
                Decimal Power Control Open Protocol for SolarEdge Inverters.pdf
                • L lisalisa
                  guitardoc
                  #428
                  Hab mittlerweile einen SolarEdge Warmwasser Controller angeschlossen. Hat zufällig jemand schon irgendwelche Modbus Register herausgefunden, welche Daten dieses Controllers liefern?
                  • G guitardoc
                    lisalisa
                    #429
                    Liefert keine Daten, ist nur ein Zigbee Schalter der einen Heizstab bedienen kann und ist nicht mit Modbus verbunden.
                    Das oben ist falsch.
                    Der ist über "SolarEdge Home Network" verbunden.
                    • L lisalisa
                      guitardoc
                      #430
                      @lisalisa
                      Ahh, OK. Aber Zigbee dürfte nicht mehr sein - die neuen haben ein eigenes Datenaustauschsystem.
                      PS: das ist dann sicher dieses Home Network System.
                      • G guitardoc
                        @lisalisa
                        guitardoc
                        #431
                        Liefert denn dann das Home Network Daten, die man in ioB auswerten kann?
