  4. BackitUp und Influxdb 2 Remote
2 Beiträge 1 Kommentatoren 551 Aufrufe
    Mitch
    ich wollte gerne meine auf der Synolgy liegende Influxdb 2 sichern:
    https://github.com/simatec/ioBroker.backitup/blob/master/docs/de/backitup.md#InfluxDB-Backup
    https://docs.influxdata.com/influxdb/v2.1/tools/influx-cli/?t=Linux
    den zweiten Link habe ich bis zur Installation der InfluxCLI durchgeführt. D.h. auf meiner Serverkonsole kann ich influxcli starten (natürlich wie beschrieben auf der iobroker Installation):
    root@mm-iobroker:~# influx
    NAME:
       influx - Influx Client
    USAGE:
       influx [command]
    COMMANDS:
       version              Print the influx CLI version
       ping                 Check the InfluxDB /health endpoint
       setup                Setup instance with initial user, org, bucket
       write                Write points to InfluxDB
       bucket               Bucket management commands
       completion           Generates completion scripts
       bucket-schema        Bucket schema management commands
       query                Execute a Flux query
       config               Config management commands
       org, organization    Organization management commands
       delete               Delete points from InfluxDB
       user                 User management commands
       task                 Task management commands
       backup               Backup database
       restore              Restores a backup directory to InfluxDB
       telegrafs            List Telegraf configuration(s). Subcommands manage Telegraf configurations.
       dashboards           List Dashboard(s).
       export               Export existing resources as a template
       secret               Secret management commands
       v1                   InfluxDB v1 management commands
       auth, authorization  Authorization management commands
       apply                Apply a template to manage resources
       stacks               List stack(s) and associated templates. Subcommands manage stacks.
       template             Summarize the provided template
       help, h              Shows a list of commands or help for one command
    GLOBAL OPTIONS:
       --help, -h  show help
    Wenn ich dann aber mittels BackitUp die DB sichern will passiert folgendes:
    [DEBUG] [influxDB] - InfluxDB-Backup started ...
    [DEBUG] [influxDB] - Start InfluxDB Backup ...
    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
    [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
    [ERROR] [influxDB] - Error: Command failed: influx backup --bucket iobroker --host http://192.168.15.5:8086 -t  "/opt/iobroker/backups/influxDB_2023_02_28-23_57_49_backupiobroker"
    Error: backup path must be specified as a single positional argument
    Hat jemand eine Idee, warum das nicht klappt? Die InfluxDB lässt sich auf jedenfall im ioBroker nutzen, sprich Werte loggen und auch z.B. über Echart anzeigen.
    • M Mitch
      NAME:
      USAGE:
         influx [command]
      COMMANDS:
      GLOBAL OPTIONS:
      Mitch
      Ich Held der Nacht sollte natürlich auch den Token in BackItUp hinterlegen!
      Jetzt geht es !
