  4. Tägliches Problem mit Unifi Adapter
2 Beiträge 2 Kommentatoren 159 Aufrufe 3 Beobachtet
  • K Offline
    Kuddel
    Systemdata Bitte Ausfüllen
    Hardwaresystem: NUC
    Arbeitsspeicher: ESX-Host 32 GB / VM 3,5GB
    Festplattenart: SSD
    Betriebssystem: Ubuntu 18.04.6
    Node-Version: 16.18.0
    Nodejs-Version: 16.18.0
    NPM-Version: 8.19.2
    Installationsart: Manuell
    Hallo zusammen, ich bekomme jeden Tag um 02:00 Uhr den gleiche Fehler bzgl. des Unifi-Adapters.
    unifi.0 2023-02-16 02:00:18.481	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    unifi.0 2023-02-16 02:00:18.473	error	Cannot read properties of undefined (reading 'captureException')
    unifi.0 2023-02-16 02:00:18.473	error	TypeError: Cannot read properties of undefined (reading 'captureException') at Unifi.handleError (/opt/iobroker/node_modules/iobroker.unifi/main.js:218:53) at Unifi.updateUnifiData (/opt/iobroker/node_modules/iobroker.unifi/main.js:243:22) at runMicrotasks (<anonymous>) at processTicksAndRejections (node:internal/process/task_queues:96:5)
    unifi.0 2023-02-16 02:00:18.472	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
    unifi.0 2023-02-16 02:00:18.472	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    unifi.0 2023-02-16 02:00:18.456	error	[updateUnifiData-login site undefined] error: Request failed with status code 503, stack: AxiosError: Request failed with status code 503 at settle (/opt/iobroker/node_modules/node-unifi/node_modules/axios/dist/node/axios.cjs:1268:12) at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/node-unifi/node_modules/axios/dist/node/axios.cjs:2446:11) at IncomingMessage.emit (node:events:525:35) at endReadableNT (node:internal/streams/readable:1358:12) at processTicksAndRejections (node:internal/process/task_queues:83:21)
    Der Verdacht liegt nahe, dass es das tägliche Unifi-Controller Backup um 2 Uhr ist.
    Allerdings kommt der Fehler auch, wenn das Backup deaktiviert ist.
    V 1 Antwort Letzte Antwort
    • K Kuddel
      Hardwaresystem: NUC
      Festplattenart: SSD
      NPM-Version: 8.19.2
      V Offline
      V Offline
      valbuz
      @kuddel
      Ich verwende für meine Abwesenheitserkennung die Handys, welche im WLan eingebucht sind.
      Ztw. kommte es vor, dass alle Handys um 02:00 die Verbindung kurz verlieren und sich dann wieder einbuchen.
      Ich habe das Problem bis anhin in Unifi nicht gefunden.... 😕
      Patrick
      2xProxmox auf NUC
      E3DC 13kWh Speicher via RCSP an ioBroker
