  2. English
  3. Scripting / Logic
  5. setTimeout() keeps running on script stop.
    apollon77A
4 Beiträge 3 Kommentatoren 2.1k Aufrufe 2 Beobachtet
  • J
    J
    j1s2e3
    I have a js-script which sends every 20min the setpoint temperatures to the heating control panels.
    Something likes this:
    let heatingCbTmo = null;
    function heatingCb() {
        // do something and send setpoint temps
        // resart timeout
        heatingCbTmo = setTimeout(heatingCb, 20 * 60 * 1000);
    function main() {
        // setup
        heatingCb();
    main();
    The problem is, that the timeout keeps running although I have stopped it. If I start the script again (or do an restart), then I have multiple timeout callbacks running! This annoying and not what you expect if you terminate the script. Currently I have 3 timeout instances running.
    Is this a desired behavior, or a bug? If it's not a bug, how can I cancel (with cancelTimeout(id)) the timeout on script stop/exit or restart? I need somehow a hook to call cancelTimeout(heatingCbTmo) on exit/stop/restart.
    Platform: rapsi4, raspbian (up to date)
    Node.js: v16.19.0
    NPM: 8.19.3
    pi@iobroker:~ $ iob update
    Used repository: beta
    Adapter "admin" : 6.3.6 , installed 6.3.6
    Adapter "backitup" : 2.5.12 , installed 2.5.12
    Adapter "discovery" : 3.1.0 , installed 3.1.0
    Adapter "enocean" : 0.8.4 , installed 0.8.4
    Adapter "homeconnect" : 1.1.1 , installed 1.1.1
    Adapter "influxdb" : 3.2.0 , installed 3.2.0
    Adapter "jarvis" : 3.1.2 , installed 3.1.2
    Adapter "javascript" : 6.1.4 , installed 6.1.4
    Controller "js-controller": 4.0.24 , installed 4.0.24
    Adapter "rpi2" : 1.3.2 , installed 1.3.2
    Adapter "simple-api" : 2.7.2 , installed 2.7.2
    Adapter "socketio" : 6.3.3 , installed 6.3.3
    Adapter "telegram" : 1.15.2 , installed 1.15.2
    Adapter "web" : 5.4.3 , installed 5.4.3
    Adapter "ws" : 2.3.5 , installed 2.3.5
    • J j1s2e3
          // resart timeout
      function main() {
          // setup
          heatingCb();
      main();
      Node.js: v16.19.0
      NPM: 8.19.3
      mickymM
      mickymM
      mickym
      @j1s2e3 I guess cancelling Timeout ist with
      clearTimeout(myTimeout);
      not cancelTimeout.
      I`m not sure that if you start the script again a new instance is created and you get not the same instance as the timeout was created before. But as i do not work with JS - may someone else can help.
      J 1 Antwort Letzte Antwort
      • mickymM mickym
        not cancelTimeout.
        J
        J
        j1s2e3
        @mickym Yes, you are right. It was my fault while writing. In the code I had it correct:
                if (heatingCbTmo != null) {
                    clearTimeout(heatingCbTmo);
        ... and it's working (in subcribe for instance). But the problem is stopping the script. On stop I get this log:
        12:36:15.857	info	javascript.0 (619) script.js.common.VirtualAutomations.04_Heizung: ### setting: room=14-gwc temp=16
        12:43:21.268	info	javascript.0 (619) Stop script script.js.common.VirtualAutomations.04_Heizung
        12:56:13.005	info	javascript.0 (619) script.js.common.VirtualAutomations.04_Heizung: ###### before temp_override=0
        12:56:13.006	info	javascript.0 (619) script.js.common.VirtualAutomations.04_Heizung: ### setting: room=01-die temp=20
        so I thought it's not running anymore, including timeouts. But it seems the timeout keeps running...
        Now I'm searching for a way to place a hook on or before exit to cancel the timeout with clearTimeout(). No idea so far...
        process.on("beforeExit", (code) => {});
        process.on does not work. It's not defined.
        The first question is, if timeout should keep running if the sarting script is stopped? Whether it's a bug or a feature.
        • J j1s2e3
          paul53P
          paul53P
          @j1s2e3 sagte: The first question is, if timeout should keep running if the sarting script is stopped? Whether it's a bug or a feature.
          It's a bug in your javascript instance. Restart the instance or ioBroker.
          84.0k
          1.4m
