  2. English
  3. ioBroker general
  4. iObroker not accessible
    2.7k
    2.9k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
33 Beiträge 4 Kommentatoren 5.7k Aufrufe 3 Beobachtet
    @vraanaa
    Nein, auch kein remote DESKTOP.
    NO DESKTOP.
    sudo raspi-config
    Menu:
    1 System Options
    S5 Boot / Auto Login
    B1 Console
    VraanaaV Offline
    VraanaaV Offline
    Vraanaa
    @thomas-braun I did it:
    pi@raspberrypi:~ $ whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_S        ESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy n        odejs
    pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g        pio i2c spi iobroker
    tty
    /home/pi
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:4 https://dl.yarnpkg.com/debian stable InRelease
    Reading package lists... Done
    Building dependency tree... Done
    All packages are up to date.
    nodejs:
      Installed: 16.18.1-deb-1nodesource1
      Candidate: 16.18.1-deb-1nodesource1
      Version table:
     *** 16.18.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
            100 /var/lib/dpkg/status
         12.22.12~dfsg-1~deb11u1 500
            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
    • VraanaaV Vraanaa
      @thomas-braun meinst du dass ich remote vnc desktop benutzen nicht?
      kann ich auch durch putty zum ssh gehen.
      @vraanaa sagte in iObroker not accessible:
      • VraanaaV Vraanaa
        pi
        tty
        /home/pi
        nodejs:
          Version table:
        @vraanaa
        iobroker status
        VraanaaV 1 Antwort Letzte Antwort
          @vraanaa
          iobroker status
          VraanaaV Offline
          VraanaaV Offline
          Vraanaa
          @thomas-braun gleiche
          pi@raspberrypi:~ $ iobroker status
          node:internal/modules/cjs/loader:988
            throw err;
          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
              at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
              at Function.Module._load (node:internal/modules/cjs/loader:833:27)
              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
              at node:internal/main/run_main_module:22:47 {
            code: 'MODULE_NOT_FOUND',
            requireStack: []
          • VraanaaV Vraanaa
              throw err;
              requireStack: []
            @vraanaa
            cd /opt/iobroker
            sudo -H -u iobroker npm install iobroker.js-controller
              @vraanaa
              cd /opt/iobroker
              VraanaaV Offline
              VraanaaV Offline
              Vraanaa
              pi@raspberrypi:~ $ cd /opt/iobroker
              pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
              npm ERR! code 24
              npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
              npm ERR! command failed
              npm ERR! command sh -c -- node iobroker.js setup first
              npm ERR! Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
              npm ERR!     /home/iobroker/.npm/_logs/2022-12-12T22_41_51_919Z-debug-0.log
              • VraanaaV Vraanaa
                npm ERR! code 24
                systemctl status iobroker.service
                sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                  VraanaaV Offline
                  VraanaaV Offline
                  Vraanaa
                  pi@raspberrypi:/opt/iobroker $ systemctl status iobroker.servicesystemctl status iobroker.service
                  Unit iobroker.servicesystemctl.service could not be found.
                  Unit status.service could not be found.
                  * iobroker.service - ioBroker Server
                       Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
                       Active: active (running) since Mon 2022-12-12 23:46:34 CET; 550ms ago
                         Docs: http://iobroker.net
                     Main PID: 7175 (node)
                        Tasks: 7 (limit: 4915)
                          CPU: 534ms
                       CGroup: /system.slice/iobroker.service
                               `-7175 /usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/controller.js
                  pro 12 23:46:35 raspberrypi bash[7175]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/controller.js'
                  pro 12 23:46:35 raspberrypi bash[7175]:     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
                  pro 12 23:46:35 raspberrypi bash[7175]:     at Function.Module._load (node:internal/modules/cjs/loader:833:27)
                  pro 12 23:46:35 raspberrypi bash[7175]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                  pro 12 23:46:35 raspberrypi bash[7175]:     at node:internal/main/run_main_module:22:47 {
                  pro 12 23:46:35 raspberrypi bash[7175]:   code: 'MODULE_NOT_FOUND',
                  pro 12 23:46:35 raspberrypi bash[7175]:   requireStack: []
                  pro 12 23:46:35 raspberrypi bash[7175]: }
                  pro 12 23:46:35 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                  pro 12 23:46:35 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                  pi@raspberrypi:/opt/iobroker $ sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                       Active: activating (auto-restart) (Result: exit-code) since Mon 2022-12-12 23:48:20 CET; 654ms ago
                      Process: 7409 ExecStart=/usr/bin/bash -c ${NODE} /opt/iobroker/node_modules/iobroker.js-controller/controller.js (code=exited, status=1/FAILURE)
                     Main PID: 7409 (code=exited, status=1/FAILURE)
                          CPU: 657ms
                  • VraanaaV Vraanaa
                            CPU: 534ms
                            CPU: 657ms
                    @vraanaa
                    sudo systemctl disable iobroker.service
                    sudo systemctl stop iobroker.service
                    cd /opt/iobroker
                      @vraanaa
                      cd /opt/iobroker
                      VraanaaV Offline
                      VraanaaV Offline
                      Vraanaa
                      pi@raspberrypi:~ $ sudo systemctl disable iobroker.service
                      pi@raspberrypi:~ $ sudo systemctl stop iobroker.service
                      npm ERR! code 22
                      npm ERR! No connection to databases possible ...
                      npm ERR!     /home/iobroker/.npm/_logs/2022-12-12T23_22_21_375Z-debug-0.log
                      • VraanaaV Vraanaa
                        npm ERR! code 22
                        @vraanaa
                        No idea.
                          @vraanaa
                          No idea.
                          VraanaaV Offline
                          VraanaaV Offline
                          Vraanaa
                          @thomas-braun Thank you anyway. Youre the best - I have a backup image of my iobroker - maybe to completely reinstall entire system...
                          Maybe will help.
                          If I will install entire RPI - new installation will come with Bullseye - or what I need to take care of if I renew entire installation?
                          Thank you for your time and support
                          • VraanaaV Vraanaa
                            Maybe will help.
                            @vraanaa
                            If you want to completely reinstall:
                            Download the Raspberry OS Imager at their site and choose the 64bit Lite Version.
