  4. state.val.split is not a function
    5.7k
1 Beiträge 1 Kommentatoren 214 Aufrufe
  • O Offline
    O Offline
    ok1
    Re: FHEM Adapter
    @LausiD , ich erhalte seit heute Abend folgende Fehlermeldungen im Log, so dass der fhem-Adapter nicht startet.
    Das System wurde nicht verändert, der aktuellste fhem-Adapter ist installiert und lief bislang einwandfrei.
    (eine zweite fhem-Instanz fhem.1 startet dagegen einwandfrei ?!)
    Vielen Dank schon jetzt für einen Hinweis !
    fhem.0
    2022-10-23 23:16:37.756	info	State value to set for "fhem.0.info.Configurations.allowedInternals" has to be type "string" but received type "boolean"
    fhem.0
    2022-10-23 23:16:37.750	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    fhem.0
    2022-10-23 23:16:37.748	debug	Plugin sentry destroyed
    fhem.0
    2022-10-23 23:16:37.746	info	terminating
    fhem.0
    2022-10-23 23:16:37.737	error	state.val.split is not a function
    fhem.0
    2022-10-23 23:16:37.736	error	TypeError: state.val.split is not a function at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.fhem/main.js:529:44) at processImmediate (internal/timers.js:463:21)
    fhem.0
    2022-10-23 23:16:37.735	error	uncaught exception: state.val.split is not a function
    fhem.0
    2022-10-23 23:16:37.731	warn	TypeError: state.val.split is not a function at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.fhem/main.js:529:44) at processImmediate (internal/timers.js:463:21)
    fhem.0
    2022-10-23 23:16:37.728	warn	Exception: TypeError: state.val.split is not a function
    fhem.0
    2022-10-23 23:16:37.726	debug	[main] [getConfigurationsSYNC] [getConfig] info.Configurations.allowedInternals: {"val":true,"ack":true,"ts":1666559762075,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1666547534818}
    fhem.0
    2022-10-23 23:16:37.717	debug	[main] [getConfigurationsSYNC] [getConfig] info.Configurations.allowedInternals (TYPE,NAME)
