  3. Cloud Dienste
  4. Amazon Alexa English Skill for USA and UK
    2.6k
    4.6k
    4.0k
5 Beiträge 3 Kommentatoren 2.3k Aufrufe
  • BluefoxB Offline
    BluefoxB Offline
    https://www.amazon.com/gp/product/B01N5MTK9S
    Smart Home Skill from ioBroker is very popular and absolutely TOP HIT made in Germany.
    ioBroker is nominated in "SmartHome Germany Award 2017" as Best System Solution.
    Visionary and Trendmaker in Automation.
    Description
    • https://youtu.be/U-6_s7yuGQE
    • https://youtu.be/bTS6J2EkOYQ
    IoBroker Software
    • connects "Smart Home" devices,
    • is easy to set up and works reliable with Alexa.
    • it´s not just an Alexa app, but much more.
    • has the ability to connect almost everything with network interfaces, is a central server for SmartHome / Building Automation / Assisted Living. The data can be evaluated and linked, the corresponding devices can be controlled (also individually / directly). All existing data can be recorded for long-term analyzes, as well as the recorded data for graphical displays. With ioBroker you can easily control, automate, monitor your smart homes and even build a dashourd with very individual, unique, beautiful visualisation.
    1. You need the running system with ioBroker (on Raspberry, Windows-Server, Synology-NAS or MacOS) anywhere with running Node.js (ARM, x86, Windows, Linux, OSX)
    2. You need to build a connection for ioBroker and Alexa
    Please read and translate the instruction on http://www.iobroker.net/docu/?page_id=5090&lang=en
    3. the "cloud" adapter must be installed
    4. you must create the free cloud service account on https://iobroker.net
    (PLEASE CHECK EXACTLY, NOT http://WWW.iobroker.net !!! )
    5. After the account is created, click the "Create App-Key" button.
    6. enter the generated application key in the configuration of the ioBroker “cloud” adapter.
    7. That's all.
    Smart devices will become automatically names, based on the existing enumerations (rooms and functions) and these names will be sent to Alexa Skill by "discovering of devices".
    The user can set the specific device names in the cloud adapter configuration dialog box.
    The ioBroker Smart Home Skill supports the full set of Alexa voice commands for controlling lights, thermostats, blinds and scenes.
    Allowed commands:
    On/Off, Lights
    “Alexa, turn on <device or/group/name="">”
    “Alexa, turn off <device or/group/name="">”
    Percentage, Dimmers
    “Alexa, set <device or/group/name="">to <x>percent”
    “Alexa, brighten <device or/group/name="">”
    “Alexa, dim <device or/group/name="">”
    “Alexa, dim <device or/group/name="">by <x>percent”
    “Alexa, brighten <device or/group/name="">by <x>percent”
    Thermostats
    “Alexa, set <device or/group/name="">to <x>degrees”
    “Alexa, decrease <device or/group/name="">by <x>degrees”
    “Alexa, increase <device or/group/name="">by <x>degrees”
    “Alexa, decrease <device or/group/name="">"
    “Alexa, increase <device or/group/name="">"</device></device></x></device></x></device></x></device></x></device></x></device></device></device></x></device></device></device>
    • lobomauL Offline
      lobomauL Offline
      lobomau
      Wie läuft es dann ab?
      Vorhandener iobroker skill tauscht man gegen iobroker-english skill? Und Alexa muss man umstellen auf Englisch?
      Was wird da anders sein? Ich habe mitbekommen, dass Alexa auf Englisch die Farben erkennt. Sonst noch Unterschiede?
      Host: NUC8i3 mit Proxmox:
      • Slave: Pi4
      • MeistertrM Offline
        MeistertrM Offline
        Meistertr
        Kann ich das auch mit meiner deutschen alexa testen dann wäre ich dabei
        Gesendet von meinem E5823 mit Tapatalk
        • BluefoxB Offline
          BluefoxB Offline
          @lobomau:
          Vorhandener iobroker skill tauscht man gegen iobroker-english skill? Und Alexa muss man umstellen auf Englisch? `
          Genauso läuft das.
          @lobomau:
          Was wird da anders sein? Ich habe mitbekommen, dass Alexa auf Englisch die Farben erkennt. Sonst noch Unterschiede? `
          Man darf nach Temperatur fragen:
          • Alexa, what is the temperature of "outdoor"
          • Alexa, what is the "living room" set to
          Ein Schloss schließen (nicht aufmachen!):
          • “Alexa, is lock name locked/unlocked?”
          • “Alexa, lock the lock name”
          Und Farben steuern:
          • “Alexa, set the "device name" to color”
          • BluefoxB Offline
            BluefoxB Offline
            ioBroker skill is certified in US! At least.
