  4. Modbus-Adapter lässt sich nicht installieren
    5.7k
4 Beiträge 3 Kommentatoren 981 Aufrufe
  • L Offline
    leo013
    Ich versuch gerade den Modbus-Adapter zu installieren.
    Leider gelingt mir dies nicht:
    $ ./iobroker add modbus
    npm install iobroker.modbus --production --prefix "/opt/iobroker" (System call)
    node-pre-gyp
    ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v46-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@4.8.2 (node-v46 ABI) (falling back to source compile with node-gyp)
    ! gyp
    WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/4.8.2"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/.node-gyp"
    ! make: *** No rule to make target '../.node-gyp/4.8.2/include/node/common.gypi', needed by 'Makefile'. Schluss.
    gyp
    ERR!
    build error
    gyp
    ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    ! gyp ERR! stack at emitTwo (events.js:87:13)gyp ERR! stack at ChildProcess.emit (events.js:172:7)
    gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)
    ! gyp ERR! System Linux 4.4.4-v7+gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/build/Release"
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport
    gyp ERR! node -v v4.8.2
    ! gyp ERR! node-gyp -v v3.4.0gyp ERR! not ok
    node-pre-gyp ERR! build error
    ! node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/nodejs /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/build/Release' (1)node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack at emitTwo (events.js:87:13)
    node-pre-gyp ERR! stack at ChildProcess.emit (events.js:172:7)
    node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:862:16)
    node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:222:5)
    node-pre-gyp ERR! System Linux 4.4.4-v7+
    node-pre-gyp ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport
    node-pre-gyp ERR! node -v v4.8.2
    node-pre-gyp ERR! node-pre-gyp -v v0.6.32
    node-pre-gyp ERR! not ok
    ! node-pre-gyp
    ERR!
    Tried to download: https://github.com/voodootikigod/node-serialport/releases/download/3.1.2/serialport-v3.1.2-node-v46-linux-arm.tar.gz node-pre-gyp
    ERR! Pre-built binaries not found for serialport@3.1.2 and node@4.8.2 (node-v46 ABI) (falling back to source compile with node-gyp)
    gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/4.8.2"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/.node-gyp"
    gyp
    ERR!
    build error
    gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    ! gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/build/Release"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport
    gyp ERR!
    node -v v4.8.2gyp ERR! node-gyp -v v3.4.0
    gyp ERR! not ok
    ! node-pre-gyp ERR! build error
    node-pre-gyp
    ERR!
    stack Error: Failed to execute '/usr/bin/nodejs /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/build/Release' (1)node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp
    ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.modbus/node_modules/serialportnode-pre-gyp ERR! node -v v4.8.2
    node-pre-gyp ERR! node-pre-gyp -v v0.6.28
    ! npm WARN optional dep failed, continuing serialport@3.1.2npm ERR! Linux 4.4.4-v7+
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.modbus" "--production" "--prefix" "/opt/iobroker"
    npm ERR! node v4.8.2
    npm ERR! npm v2.15.11
    npm ERR! code ELIFECYCLE
    ! npm ERR! serialport@4.0.7 install: node-pre-gyp install --fallback-to-build
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the serialport@4.0.7 install script 'node-pre-gyp install --fallback-to-build'.
    npm ERR! This is most likely a problem with the serialport package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR! node-pre-gyp install --fallback-to-build
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR! npm bugs serialport
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!
    npm ERR! npm owner ls serialport
    npm ERR! There is likely additional logging output above.
    ! npm
    ERR!
    Please include the following file with any support request:npm ERR! /opt/npm-debug.log
    ! ERROR: host.raspberrypi Cannot install iobroker.modbus: 1
    ERROR: process exited with code 25</anonymous></anonymous>
    Hat jemnad eine Idee?
    Wolfgang
    • C Offline
      ChristianF
      Ja, das Problem ist bekannt. Der Adapter ist noch nicht fertig, was die serielle Implementierung angeht. Du kannst versuchen, serialport 4.0.7 manuell zu installieren.
      Mehr Infos sonst http://forum.iobroker.net/viewtopic.php … lit=modbus
      • BluefoxB Offline
        BluefoxB Offline
        Ist build-essential Lib Installiert?
        Mich stört diese Aussage:
        Versuch mal hier zu lesen:
        http://www.iobroker.net/docu/?page_id=5510&lang=de
        • L Offline
          leo013
          Habe alles nach der Anleitung durch gestestet, ohne Erfolg.
          Sowohl die Installation aus IOBROKER heraus, wie auch die Installation
          über die Console werden mit Fehlermeldungen abgebrochen.
