  4. Kube Pod restart, 'Cannot find module '../iobroker.js'
1 Beiträge 1 Kommentatoren 149 Aufrufe 1 Beobachtet
    Matthias Meyer
    schrieb am zuletzt editiert von Matthias Meyer
    ich betreibe IOBroker in einem Kubernetes Cluster als Statefullset. Nach dem mir der Pod durch einen Node-Restart einmal abgeräumt wurde, startet dieser nicht mehr ordnungsgemäß.
    Systemdata
    Hardwaresystem: Pi4 Kubernetes Cluster
    Arbeitsspeicher: jeweils 8GB
    Festplattenart: SSD
    Betriebssystem: Ubuntu
    Installationsart: kubernetes statefullset
    Image genutzt: ja
    Ort/Name der Imagedatei: iobroker/iobroker:latest-v7@sha256:534f5ef0d23ceafabddee2fdfea9816848b454e75d936bb5bc934640b8321d69
    Log-Ausgabe:
    -------------------------     2022-09-10 22:43:40      -------------------------
    -----                 Welcome to your ioBroker-container!                  -----
    -----                    Startupscript is now running.                     -----
    -----                          Please be patient!                          -----
    -----                        Debugging information                         -----
    -----                                System                                -----
    -----                    arch:                aarch64                      -----
    -----                    hostname:            iobroker-0                   -----
    -----                             Docker-Image                             -----
    -----                    image:               v7.0.1                       -----
    -----                    build:               2022-07-05T18:51:49+00:00    -----
    -----                               Versions                               -----
    -----                    node:                v14.19.3                     -----
    -----                    npm:                 6.14.17                      -----
    -----                                 ENV                                  -----
    -----                    IOB_ADMINPORT:       8081                         -----
    -----                    SETGID:              1000                         -----
    -----                    SETUID:              1000                         -----
    -----                  Step 1 of 5: Preparing container                   -----
    Updating Linux packages on first run...
    # gekürzt
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Done.
    Registering maintenance script as command... Done.
    Installing additional packages is set by ENV.
    Checking the following Packages: ...
    Reading package lists...
    Building dependency tree...
    Reading state information...
    Done.
    -----             Step 2 of 5: Detecting ioBroker installation             -----
    Existing installation of ioBroker detected in /opt/iobroker.
    -----             Step 3 of 5: Checking ioBroker installation              -----
    (Re)Setting folder permissions (This might take a while! Please be patient!)... Done.
    Fixing "sudo-bug" by replacing sudo in iobroker with gosu... Done.
    internal/modules/cjs/loader.js:905
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
        at Function.Module._load (internal/modules/cjs/loader.js:746:27)
        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
        at internal/main/run_main_module.js:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    /opt/scripts/iobroker_startup.sh: line 212: [: !=: unary operator expected
    -----                Step 4 of 5: Applying special settings                -----
    Some adapters have special requirements/ settings which can be activated by the use of environment variables.
    For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
      throw err;
      requireStack: []
    /opt/scripts/iobroker_startup.sh: line 236: [: 8081: unary operator expected
    -----                    Step 5 of 5: ioBroker startup                     -----
    Starting ioBroker...
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/controller.js'
      requireStack: []
    Auf den ersten Blick sieht es so aus, als gäbe es die iobroker.js und die controller.js-Datei nicht gibt. Die Dateien sind jedoch existent und werden scheinbar dennoch nicht gefunden.
    root@iobroker-0:/opt/iobroker# head node_modules/iobroker.js-controller/controller.js
     *      Redirect for older installations
     *      Copyright 2018-2022 bluefox <dogafox@gmail.com>,
     *      MIT License
    require('./main').init();
    root@iobroker-0:/opt/iobroker# cd node_modules/iobroker.js-controller/ && ls -la
    total 368
    drwxrwxr-x+   6 iobroker iobroker   4096 Sep 10 22:39 .
    drwxrwxrwx+ 522 iobroker iobroker  20480 Sep 10 22:33 ..
    -rw-rwxr--+   1 iobroker iobroker    420 Okt 26  1985 compactgroupController.js
    drwxrwxr-x+   2 iobroker iobroker   4096 Sep 10 22:32 conf
    -rw-rwxr--+   1 iobroker iobroker    158 Okt 26  1985 controller.js
    -rwxrwxr-x+   1 iobroker iobroker     34 Okt 26  1985 iobroker.js
    -rw-rwxr--+   1 iobroker iobroker  54395 Okt 26  1985 io-package.json
    drwxrwxr-x+   9 iobroker iobroker   4096 Sep 10 22:32 lib
    -rw-rwxr--+   1 iobroker iobroker   1135 Okt 26  1985 LICENSE
    -rw-rwxr--+   1 iobroker iobroker 249293 Okt 26  1985 main.js
    drwxrwxr-x+   7 iobroker iobroker   4096 Sep 10 22:32 node_modules
    -rw-rwxr--+   1 iobroker iobroker   4503 Sep 10 22:32 package.json
    -rw-rwxr--+   1 iobroker iobroker    193 Okt 26  1985 README.md
    drwxrwxr-x+   2 iobroker iobroker   4096 Sep 10 22:32 tmp
    root@iobroker-0:/opt/iobroker/node_modules/iobroker.js-controller# head iobroker.js
    require('./lib/setup').execute();
    Ist das Problem bekannt? Hat jemand einen Rat dies zu beheben?
    Temporär lässt sich iobroker via root@iobroker-0:/opt/iobroker# sudo node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js start starten. Hilft nur nicht, wenn der Pod wieder terminiert und neustartet.
    Beste Grüße, Matthias
    StatefullSet-Definition:
    resource "kubernetes_stateful_set" "iobroker" {
      metadata {
        name      = "iobroker"
        namespace = kubernetes_namespace.smartmeter_namespace.id
      spec {
        service_name           = "iobroker"
        revision_history_limit = 5
        selector {
          match_labels = {
            "app.kubernetes.io/instance" : "iobroker"
            "app.kubernetes.io/name" : "iobroker"
        volume_claim_template {
          metadata {
            name = "iobroker-data"
          spec {
            access_modes       = ["ReadWriteOnce"]
            storage_class_name = "openebs-jiva-csi-default"
            resources {
              requests = {
                storage = "10Gi"
        template {
          metadata {
            name = "iobroker"
            labels = {
          spec {
            container {
              name  = "iobroker"
              image = "iobroker/iobroker:latest-v7@sha256:534f5ef0d23ceafabddee2fdfea9816848b454e75d936bb5bc934640b8321d69"
              port {
                name           = "http"
                container_port = 8081
              port {
                name           = "httpui"
                container_port = 8082
              volume_mount {
                mount_path = "/opt/iobroker"
              env {
                name  = "IOB_ADMINPORT"
                value = "8081"
    Users & Permissions
    root@iobroker-0:/opt# cat /etc/passwd
    root:x:0:0:root:/root:/bin/bash
    daemon:x:1:1:daemon:/usr/sbin:/usr/sbin/nologin
    bin:x:2:2:bin:/bin:/usr/sbin/nologin
    sys:x:3:3:sys:/dev:/usr/sbin/nologin
    sync:x:4:65534:sync:/bin:/bin/sync
    games:x:5:60:games:/usr/games:/usr/sbin/nologin
    man:x:6:12:man:/var/cache/man:/usr/sbin/nologin
    lp:x:7:7:lp:/var/spool/lpd:/usr/sbin/nologin
    mail:x:8:8:mail:/var/mail:/usr/sbin/nologin
    news:x:9:9:news:/var/spool/news:/usr/sbin/nologin
    uucp:x:10:10:uucp:/var/spool/uucp:/usr/sbin/nologin
    proxy:x:13:13:proxy:/bin:/usr/sbin/nologin
    www-data:x:33:33:www-data:/var/www:/usr/sbin/nologin
    backup:x:34:34:backup:/var/backups:/usr/sbin/nologin
    list:x:38:38:Mailing List Manager:/var/list:/usr/sbin/nologin
    irc:x:39:39:ircd:/run/ircd:/usr/sbin/nologin
    gnats:x:41:41:Gnats Bug-Reporting System (admin):/var/lib/gnats:/usr/sbin/nologin
    nobody:x:65534:65534:nobody:/nonexistent:/usr/sbin/nologin
    _apt:x:100:65534::/nonexistent:/usr/sbin/nologin
    _rpc:x:101:65534::/run/rpcbind:/usr/sbin/nologin
    statd:x:102:65534::/var/lib/nfs:/usr/sbin/nologin
    iobroker:x:1000:1000::/opt/iobroker:/bin/bash
    root@iobroker-0:/opt# stat /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
      File: /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
      Size: 34              Blocks: 8          IO Block: 4096   regular file
    Device: 810h/2064d      Inode: 399354      Links: 1
    Access: (0775/-rwxrwxr-x)  Uid: ( 1000/iobroker)   Gid: ( 1000/iobroker)
    Access: 2022-09-10 23:24:57.083078730 +0200
    Modify: 1985-10-26 09:15:00.000000000 +0100
    Change: 2022-09-10 22:47:17.530576383 +0200
     Birth: 2022-09-10 22:32:50.225830721 +0200
