  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Драйвер squeezenode / logitech media server / squeezebox
    5.9k
30 Beiträge 6 Kommentatoren 11.8k Aufrufe
  • V Offline
    V Offline
    vtec
    http://www.maison-et-domotique.com/56929-realisation-de-multiroom-audio-a-base-de-raspberry-pi-hifiberry/
    • aurodionovA Offline
      aurodionovA Offline
      aurodionov
      А так пока засунул в единый интерфейс, не по феншую но работает
      [{"tpl":"tplIFrame","data":{"visibility-cond":"==","visibility-val":1,"refreshInterval":"0","src":"http://192.168.55.180:9002/"},"style":{"left":"8px","top":"9px","width":"1010","border-radius":"20px","border-width":"","height":"645"},"widgetSet":"basic"}]
      Пишу с пульта….
      • I Offline
        I Offline
        iapet
        Перестал ставится.
        ! ` > $ ./iobroker add harmony
        npm install iobroker.harmony –production --prefix "/opt/iobroker" (System call)
        npm
        WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:78:19)
        npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:82:29)
        npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:93:16
        npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)
        npm WARN addRemoteGit git+https://github.com/Pmant/harmonyhubjs-client.git resetting remote /root/.npm/_git-remotes/https-github-com-Pmant-harmonyhubjs-client-git-49cda7c8 because of error: { [Error: not found: git] code: 'ENOGIT' }
        npm ERR!
        git clone –template=/root/.npm/_git-remotes/_templates --mirror https://github.com/Pmant/harmonyhubjs-client.git /root/.npm/_git-remotes/https-github-com-Pmant-harmonyhubjs-client-git-49cda7c8: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/Pmant/harmonyhubjs-client.git /root/.npm/_git-remotes/https-github-com-Pmant-harmonyhubjs-client-git-49cda7c8: undefined
        npm ERR! Linux 4.1.17-v7+npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"
        npm ERR! node v4.3.1
        npm ERR! npm v2.14.12npm ERR! code ENOGIT
        npm ERR! not found: git
        npm ERR!
        npm ERR! Failed using git.
        npm ERR! This is most likely not a problem with npm itself.
        npm ERR! Please check if you have git installed and in your PATH.
        npm
        ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
        ERROR: host.raspberrypi Cannot install iobroker.harmony: 1
        ERROR: process exited with code 25 `
        4 Node ему не нравится. Можно подправить?
          MSapogov
          Хочу пойти по следам UncleSam, и немного доработать драйвер https://github.com/UncleSamSwiss/ioBroker.squeezebox
          для начала хочу добавить трек вперед и назад…, потом может и TTS, но не обещаю...
          Подскажите, как правильно воспозоваться наработками UncleSam, что-бы не было плагиата. Где и как нужно указать, что это модернизация проекта от UncleSamSwiss.
          PS: ух… столько нового узнал.... это называется Fork проекта. Зарегился на githab начал вносить небольшие правки...
          Только никак не могу найти в каком месте задавался порт 9090 и где происходит подписка на изменения "listel 1"?
            MSapogov
            BlueFox, подскажи с чего начать написание драйвера? (где почитать?)
            На вопрос где задается порт и подписка на комманды, UncleSamSwiss мне ответил, что
            "The entire communication with Logitech Media Server is done with the node.js module "logitechmediaserver"."
            Что делать если порт CLI висит на другом порту, или вдруг понадобится "listen 1" менять на "subscribe …".
            Может вынести настройку порта в настройку драйвера?
            Посмотрел программы .js нескольких драйверов... начал немного вникать. Думаю, что сил и знаний хватит... :-)
            Очень хочется сделать полноценный драйвер для LMS с поддержкой TTS и SayIt.
            • I Offline
              I Offline
              instalator
              @MSapogov:
              Очень хочется сделать полноценный драйвер для LMS с поддержкой TTS и SayIt. `
              https://github.com/ioBroker/ioBroker.te … /README.md
              Высокий уровень Децибел вреден для здоровья!
              http://blog.instalator.ru/
                MSapogov
                Еще короткий вопросик. Как перезапустить драйвер, после проделанных изменений в файлах
                /opt/iobroker/node_modules/iobroker.squeezenode/…
                Что-бы посмотреть как повлияли изменения на работу.
                • I Offline
                  I Offline
                  instalator
                  @MSapogov:
                  Что-бы посмотреть как повлияли изменения на работу. `
                  Не в ту ветку пишешь. Перезапускается штатно на вкладке настройки драйвера.
                  А в идеале установи wеbstorm https://github.com/ioBroker/ioBroker/wi … nvironment
                  • H Offline
                    Haus
                    @MSapogov:
                    iobroker upload squeezenode
                    iobroker restart squeezenode
                    js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
                    admin: 3.6.0
                    javascript: 4.1.10
                    web: 2.4.1 vis: 1.1.10
                    cloud: 2.6.2
                    Server: DELL FX170 / linux: Debian 9.5 Stretch
                    Adapter: MegaD-2561, Mega-ES…
                      MSapogov
                      Ох… тяжела ноша програмиста...
                      Безуспешно вникал целую неделю в азы програмирования, но безуспешно.
                      У instalator-а, драйвера как горячие пирожки разлетаются :-)
                      Пытался разобраться с биндингом в OpenHAB2, https://github.com/openhab/openhab2-add … squeezebox, там как раз реализована системная озвучка для SqueezeBox.
                      Вижу знакомые команды из CLI, но чем дальше вникаю, тем меньше понимаю.
                      Решил испытать этот OpenHAB2… Установил... подключил к нему плееры и то не сразу :-)... Полдня прошло, а получилось управлять только громкость и названия треков вытащить из плееров :-)
                      В IoBroker как то все более интуитивно... И состояния объектов можно смело наблюдать, и менять их... Короче не получилось у меня перелезть на OpenHAB. Продолжаю использовать IoBroker !
                      Может кто-то, кто более селен в написании драйверов, и сможет допилить squeezebox для системной озвучки, но кажется что это точно буду не я.
