  4. Adapterupdate schlägt fehl > Version dennoch hochgezogen
4 Beiträge 2 Kommentatoren 637 Aufrufe 2 Beobachtet
  • MichMeinM Offline
    MichMeinM Offline
    MichMein
    nun muss ich mich auch mal melden, auch wenn die Themen schon zahlreich vorhanden sind.
    Ich habe ein Updatedes Admin von 6.2.3 auf 6.2.4 machen wollen und folgendes hat sich ereignet:
    Update über die Konsole angestoßen mit folgendem Ergebnis,
    pi@ioBroker:/opt/iobroker $ iobroker upgrade --debug
    This upgrade of "admin" will introduce the following changes:
    -> 6.2.4:
    Corrected yahka settings
    Would you like to upgrade admin from @6.2.3 to @6.2.4 now? [(y)es, (n)o]: y
    Update admin from @6.2.3 to @6.2.4
    host.ioBroker Adapter "system.adapter.admin.0" is stopped.
    NPM version: 8.11.0
    Installing iobroker.admin@6.2.4... (System call)
    npm WARN skipping integrity check for git dependency ssh://git@github.com/MiGoller/ioBroker.xplora.git
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src
    npm ERR! dest /opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src' -> '/opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src'
    npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T17_42_27_099Z-debug-0.log
    host.ioBroker Cannot install iobroker.admin@6.2.4: 217
    Dann den Admin Adapter per Hand gestartet da er nicht lief und entdeckt das im Admin V6.2.4 steht,
    Und hier noch die Ausgaben der Konsole zu den Instanzen und Adaptern,
    pi@ioBroker:/opt/iobroker $ iobroker list instances
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
      system.adapter.echarts.0                : echarts               : ioBroker                                 - disabled
    + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
    + system.adapter.go-e.0                   : go-e                  : ioBroker                                 -  enabled
    + system.adapter.heatingcontrol.0         : heatingcontrol        : ioBroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
      system.adapter.linkeddevices.0          : linkeddevices         : ioBroker                                 - disabled
    + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
      system.adapter.minuvis.0                : minuvis               : ioBroker                                 - disabled
    + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : ioBroker                                 -  enabled
    + system.adapter.node-red.0               : node-red              : ioBroker                                 -  enabled, port: 1880, bind: 0.0.0.0
      system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : ioBroker                                 -  enabled
    + system.adapter.sayit.0                  : sayit                 : ioBroker                                 -  enabled, port: 0
      system.adapter.scenes.0                 : scenes                : ioBroker                                 - disabled
      system.adapter.schoolfree.0             : schoolfree            : ioBroker                                 -  enabled
    + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 -  enabled
      system.adapter.shuttercontrol.1         : shuttercontrol        : ioBroker                                 - disabled
      system.adapter.shuttercontrol.2         : shuttercontrol        : ioBroker                                 - disabled
      system.adapter.smartcontrol.0           : smartcontrol          : ioBroker                                 - disabled
    + system.adapter.smartmeter.0             : smartmeter            : ioBroker                                 -  enabled
    + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : ioBroker                                 -  enabled
    + system.adapter.sony-bravia.0            : sony-bravia           : ioBroker                                 -  enabled
    + system.adapter.sony-bravia.1            : sony-bravia           : ioBroker                                 -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
    + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5001
      system.adapter.vis.0                    : vis                   : ioBroker                                 - disabled
    + system.adapter.vw-connect.0             : vw-connect            : ioBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
    + instance is alive
    pi@ioBroker:/opt/iobroker $ iobroker list adapters
    system.adapter.admin                   : admin          - v6.2.3
    system.adapter.alias-manager           : alias-manager  - v1.2.6
    system.adapter.backitup                : backitup       - v2.4.10
    system.adapter.device-reminder         : device-reminder - v1.2.9
    system.adapter.discovery               : discovery      - v3.0.5
    system.adapter.echarts                 : echarts        - v1.0.12
    system.adapter.email                   : email          - v1.1.3
    system.adapter.fb-checkpresence        : fb-checkpresence - v1.1.19
    system.adapter.feiertage               : feiertage      - v1.1.0
    system.adapter.go-e                    : go-e           - v1.0.23
    system.adapter.heatingcontrol          : heatingcontrol - v2.9.1
    system.adapter.influxdb                : influxdb       - v3.1.7
    system.adapter.info                    : info           - v1.9.19
    system.adapter.javascript              : javascript     - v6.0.0
    system.adapter.linkeddevices           : linkeddevices  - v1.5.5
    system.adapter.linux-control           : linux-control  - v1.1.5
    system.adapter.minuvis                 : minuvis        - v2.3.0
    system.adapter.mqtt                    : mqtt           - v4.0.7
    system.adapter.net-tools               : net-tools      - v0.2.0
    system.adapter.node-red                : node-red       - v3.3.1
    system.adapter.openweathermap          : openweathermap - v0.3.0
    system.adapter.rpi2                    : rpi2           - v1.3.2
    system.adapter.sayit                   : sayit          - v1.12.6
    system.adapter.scenes                  : scenes         - v2.3.9
    system.adapter.schoolfree              : schoolfree     - v1.0.1
    system.adapter.shuttercontrol          : shuttercontrol - v1.4.14
    system.adapter.simple-api              : simple-api     - v2.7.0
    system.adapter.smartcontrol            : smartcontrol   - v1.2.1
    system.adapter.smartmeter              : smartmeter     - v3.3.4
    system.adapter.socketio                : socketio       - v6.1.8
    system.adapter.sonoff                  : sonoff         - v2.5.1
    system.adapter.sonos                   : sonos          - v2.2.3
    system.adapter.sony-bravia             : sony-bravia    - v1.0.9
    system.adapter.sourceanalytix          : sourceanalytix - v0.4.14
    system.adapter.synology                : synology       - v2.1.9
    system.adapter.vis                     : vis            - v1.4.15
    system.adapter.vw-connect              : vw-connect     - v0.0.51
    system.adapter.web                     : web            - v5.2.4
    system.adapter.ws                      : ws             - v2.1.3
    system.adapter.zigbee                  : zigbee         - v1.7.5
    Das macht irgendwie nen ganz schön verrückten Eindruck.
    pi@ioBroker:/opt/iobroker $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
    /usr/bin/nodejs
    v16.16.0
    /usr/bin/node
    v16.16.0
    /usr/bin/npm
    8.11.0
    nodejs:
      Installed: 16.16.0-deb-1nodesource1
      Candidate: 16.16.0-deb-1nodesource1
      Version table:
     *** 16.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
            100 /var/lib/dpkg/status
         10.24.0~dfsg-1~deb10u1 500
    Es muss doch irgendwie ne Lösung geben die Probleme seit den NodeJS Updates in den Griff zu bekommen. Ich habe ehrlicher Weise keine Lust ständig irgendwelche Verzeichnisse zu löschen nur damit sie wieder erstellt werden oder gar mein ganzes System neu aufzusetzen.
    Schönes Wochenende
    Gruß Michael
    Sofern Beiträge hilfreich für Dich sind, nutze das Voting unten rechts.
    MichMeinM GlasfaserG 2 Antworten Letzte Antwort
    • MichMeinM MichMein
      -> 6.2.4:
      NPM version: 8.11.0
      npm ERR! errno -39
      + instance is alive
      /usr/bin/nodejs
      v16.16.0
      /usr/bin/node
      v16.16.0
      /usr/bin/npm
      8.11.0
      nodejs:
        Version table:
      Schönes Wochenende
      MichMeinM Offline
      MichMeinM Offline
      MichMein
      @michmein
      Hier noch ein kleines Update aus der Konsole (es wurde nichts geändert, ich habe es nur im ersten Post vergessen),
      All adapters are up to date
      Gruß Michael
        -> 6.2.4:
        NPM version: 8.11.0
        npm ERR! errno -39
        + instance is alive
        /usr/bin/nodejs
        v16.16.0
        /usr/bin/node
        v16.16.0
        /usr/bin/npm
        8.11.0
        nodejs:
          Version table:
        Schönes Wochenende
        GlasfaserG Offline
        GlasfaserG Offline
        Glasfaser
        @michmein sagte in Adapterupdate schlägt fehl > Version dennoch hochgezogen:
        Nicht Böse sein ....aber :
        wenn man sich wie du im Beta -Zweig aufhält , kann es schon sein das es so zu diesem kommen kann .
        Da muß man schon sein System kennen bzw. auch mal was einstecken das sowas kommen kann .
        MichMeinM 1 Antwort Letzte Antwort
        • GlasfaserG Glasfaser
          MichMeinM Offline
          MichMeinM Offline
          MichMein
          schrieb am zuletzt editiert von MichMein
          @glasfaser sagte in Adapterupdate schlägt fehl > Version dennoch hochgezogen:
          Danke für die Blumen, dessen bin ich mir durchaus bewusst und auch nicht böse. Diese Aussagen lassen sich sehr häufig hier im Forum lesen.
          Kann ich deiner Aussage denn entnehmen bzw. würdest du diese so umformulieren?
          "Wenn du NICHT im Beta-Zweig unterwegs gewesen wärst, dann wären diese Fehler NICHT aufgetaucht"?
          Ich danke dir.
          Gruß Michael
