  4. Harmony Adapter gibt error und startet immer neu
    5.6k
1 Beiträge 1 Kommentatoren 502 Aufrufe
    badplay
    Hallo
    ich hab nen denke ich Problem mit dem harmony adapter. Wenn ich eine Aktion bzw Activität nutze und diese ausführe bleibt der adapter immer hängen folgenden fehler bekomme ich
    harmony.0 2017-04-06 19:13:32.330 info synced hub config
    harmony.0 2017-04-06 19:13:31.635 info connected to Harmony Hub
    harmony.0 2017-04-06 19:13:29.334 info connecting to Harmony Hub
    harmony.0 2017-04-06 19:13:29.296 info discovered Harmony Hub
    harmony.0 2017-04-06 19:13:28.119 info searching for Harmony Hubs…
    harmony.0 2017-04-06 19:13:28.089 info starting. Version 0.7.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.8.1
    host.ubuntu-hd 2017-04-06 19:13:26.695 info instance system.adapter.harmony.0 started with pid 20565
    host.ubuntu-hd 2017-04-06 19:12:56.687 info Restart adapter system.adapter.harmony.0 because enabled
    host.ubuntu-hd 2017-04-06 19:12:56.686 error instance system.adapter.harmony.0 terminated with code 0 (OK)
    harmony.0 2017-04-06 19:12:56.670 info terminating
    harmony.0 2017-04-06 19:12:56.657 info terminating
    harmony.0 2017-04-06 19:12:56.656 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3030:38)
    harmony.0 2017-04-06 19:12:56.656 error at Adapter.emit (events.js:172:7)
    harmony.0 2017-04-06 19:12:56.656 error at emitTwo (events.js:87:13)
    harmony.0 2017-04-06 19:12:56.656 error at Adapter. (/opt/iobroker/node_modules/iobroker.harmony/harmony.js:34:15)
    harmony.0 2017-04-06 19:12:56.656 error at Object.semaphore.take (/opt/iobroker/node_modules/iobroker.harmony/node_modules/semaphore/lib/semaphore.js:45:9)
    harmony.0 2017-04-06 19:12:56.656 error at Object.item.task (/opt/iobroker/node_modules/iobroker.harmony/node_modules/semaphore/lib/semaphore.js:34:29)
    harmony.0 2017-04-06 19:12:56.656 error at /opt/iobroker/node_modules/iobroker.harmony/harmony.js:36:9
    harmony.0 2017-04-06 19:12:56.656 error at processStateChange (/opt/iobroker/node_modules/iobroker.harmony/harmony.js:67:21)
    harmony.0 2017-04-06 19:12:56.656 error at switchActivity (/opt/iobroker/node_modules/iobroker.harmony/harmony.js:137:92)
    harmony.0 2017-04-06 19:12:56.656 error at Promise.fin.Promise.finally (/opt/iobroker/node_modules/iobroker.harmony/node_modules/harmonyhubjs-client/node_modules/q/q.js:1775:15)
    harmony.0 2017-04-06 19:12:56.656 error Error: Q can't apply finally callback
    harmony.0 2017-04-06 19:12:56.652 error uncaught exception: Q can't apply finally callback
    harmony.0 2017-04-06 19:11:19.739 info synced hub config
    harmony.0 2017-04-06 19:11:18.893 info connected to Harmony Hub
    harmony.0 2017-04-06 19:11:16.594 info connecting to Harmony Hub
    harmony.0 2017-04-06 19:11:16.555 info discovered Harmony Hub
    harmony.0 2017-04-06 19:11:15.354 info searching for Harmony Hubs...
    harmony.0 2017-04-06 19:11:15.325 info starting. Version 0.7.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.8.1
    host.ubuntu-hd 2017-04-06 19:11:13.784 info instance system.adapter.harmony.0 started with pid 20419
    host.ubuntu-hd 2017-04-06 19:10:43.775 info Restart adapter system.adapter.harmony.0 because enabled
    weiß einer warum das kommt? wenn ich ein gerät mit dem Scenen Adapter also ohne einer fertigen Aktivität aus Harmony nutze passiert das nicht
