  4. Fehlermeldung bei Installation Version 0.54
    5.4k
6 Beiträge 4 Kommentatoren 1.9k Aufrufe
    mctom
    ich habe gerade versucht Version 0.54 zu installieren.
    Leider ist die Installation abgebrochen.
    Hier das LOG File:
    ! raspberrypi 2015-05-26 21:11:27 info host.raspberrypi instance system.adapter.history.0 started with pid 7871 raspberrypi 2015-05-26 21:11:27 info host.raspberrypi instance system.adapter.history.0 started with pid 7871 raspberrypi 2015-05-26 21:11:22 info host.raspberrypi instance system.adapter.web.0 started with pid 7865 raspberrypi 2015-05-26 21:11:19 info host.raspberrypi instance system.adapter.web.0 started with pid 7865 raspberrypi 2015-05-26 21:11:15 info host.raspberrypi instance system.adapter.hm-rega.0 started with pid 7859 raspberrypi 2015-05-26 21:11:15 info host.raspberrypi instance system.adapter.hm-rega.0 started with pid 7859 admin.0 2015-05-26 21:11:15 info admin.0 received all states admin.0 2015-05-26 21:11:15 info admin.0 received all objects admin.0 2015-05-26 21:11:15 info admin.0 received all states admin.0 2015-05-26 21:11:15 info admin.0 received all objects admin.0 2015-05-26 21:11:03 info admin.0 terminating admin.0 2015-05-26 21:11:03 info admin.0 terminating http server on port 8081 2015-05-2 iobroker 2015-05-26 21:10:21 info npm ERR! iobroker 2015-05-26 21:10:21 info npm ERR! fstream_stack /usr/local/lib/node_modules/npm/node_modules/mkdirp/index.js:37:53 iobroker 2015-05-26 21:10:21 info npm ERR! fstream_stack /usr/local/lib/node_modules/npm/node_modules/fstream/lib/dir-writer.js:36:23 iobroker 2015-05-26 21:10:21 info ERR! code ENOSPCnpm ERR! errno 54 iobroker 2015-05-26 21:10:21 info npm iobroker 2015-05-26 21:10:21 info npm ERR! fstream_class DirWriter iobroker 2015-05-26 21:10:21 info npm ERR! fstream_type Directory iobroker 2015-05-26 21:10:21 info path /root/.npm/iobroker.vis/0.5.4/packagenpm ERR! fstream_path /root/.npm/iobroker.vis/0.5.4/package iobroker 2015-05-26 21:10:21 info npm ERR! iobroker 2015-05-26 21:10:21 info npm ERR! npm -v 1.3.14 iobroker 2015-05-26 21:10:21 info npm ERR! node -v v0.10.22 iobroker 2015-05-26 21:10:21 info npm ERR! command '/usr/local/bin/node' '/usr/local/bin/npm' 'install' 'iobroker.vis' '--production' '--prefix' '/opt/iobroker'npm ERR! cwd / iobroker 2015-05-26 21:10:21 info npm ERR! System Linux 3.18.11-v7+ iobroker 2015-05-26 21:10:21 info npm ERR! iobroker 2015-05-26 21:10:21 info npm ERR! or email it to: iobroker 2015-05-26 21:10:21 info npm ERR! iobroker 2015-05-26 21:10:21 info ERR! Error: ENOSPC, mkdir '/root/.npm/iobroker.vis/0.5.4/package'npm ERR! If you need help, you may report this log at: iobroker 2015-05-26 21:10:21 info npm iobroker 2015-05-26 21:10:21 info 54 iobroker 2015-05-26 21:10:21 info ERR! errno iobroker 2015-05-26 21:10:21 info npm iobroker 2015-05-26 21:10:21 info npm -v 1.3.14npm ERR! code ENOSPC iobroker 2015-05-26 21:10:21 info npm ERR! iobroker 2015-05-26 21:10:21 info npm ERR! node -v v0.10.22 iobroker 2015-05-26 21:10:21 info npm ERR! command '/usr/local/bin/node' '/usr/local/bin/npm' 'install' 'iobroker.vis' '--production' '--prefix' '/opt/iobroker'npm ERR! cwd / iobroker 2015-05-26 21:10:21 info npm ERR! System Linux 3.18.11-v7+ iobroker 2015-05-26 21:10:21 info npm ERR! iobroker 2015-05-26 21:10:21 info ERR! npm ERR! or email it to: iobroker 2015-05-26 21:10:21 info npm iobroker 2015-05-26 21:10:21 info ERR! Error: ENOSPC, writenpm ERR! If you need help, you may report this log at: iobroker 2015-05-26 21:10:21 info npm iobroker 2015-05-26 21:10:21 info npm ERR! iobroker 2015-05-26 21:10:21 info npm ERR! npm ERR! or email it to: iobroker 2015-05-26 21:10:21 info ERR! Error: ENOSPC, writenpm ERR! If you need help, you may report this log at: iobroker 2015-05-26 21:10:21 info iobroker 2015-05-26 21:10:21 info npm iobroker 2015-05-26 21:08:10 info http 200 https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-0.5.4.tgz iobroker 2015-05-26 21:08:10 info npm iobroker 2015-05-26 21:08:09 info npm http GET https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-0.5.4.tgz iobroker 2015-05-26 21:07:59 info ERR! fetch failed https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-0.5.4.tgz iobroker 2015-05-26 21:07:59 info npm iobroker 2015-05-26 21:07:51 info npm http 200 https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-0.5.4.tgz iobroker 2015-05-26 21:07:51 info npm http GET https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-0.5.4.tgz iobroker 2015-05-26 21:07:51 info http 200 https://registry.npmjs.org/iobroker.vis iobroker 2015-05-26 21:07:51 info npm iobroker 2015-05-26 21:07:51 info http GET https://registry.npmjs.org/iobroker.vis iobroker 2015-05-26 21:07:51 info iobroker 2015-05-26 21:07:51 info npm iobroker 2015-05-26 21:07:48 info npm install iobroker.vis --production --prefix '/opt/iobroker' (System call) iobroker 2015-05-26 21:07:46 info upgrade vis !
    394_log.txt
    Gibt es hier noch einen Bug?
    Oder war ich zu schnell… :-)
    Michael
    • HomoranH Offline
      HomoranH Offline
      Hallo Michael,
      Bei mir läuft es gerade anscheinend gut durch.
      Habe bis jetzt keine Fehler;
      dein log enthält:
      Ich kenne mich da nicht allzusehr aus, aber E (rror) NO SPC klingt wie kein Speicherplatz mehr.
      EDIT: (google sagt das ist so!)
      Also SD-Karte voll?
      Bitte logs in code-tags posten, und wenn es viel text ist zusätzlich in spoiler-tags.
      Rainer
      • BluefoxB Offline
        BluefoxB Offline
        @Homoran:
        Hallo Michael,
        dein log enthält:
        Also SD-Karte voll?
        Rainer `
        Wollte gerade antworten, aber Rainer hat alles richtig vermutet. Du hast kein Platz mehr.
        • HomoranH Offline
          HomoranH Offline
          Aber es gibt trotzdem Probleme:
          meine import vies sind leer
          neue Installation - neu importiert - leer
          Unter pulldownmenü Aktiv-widget, lassen sich die widgets anwählen, einzelne werden sichtbar, andere nicht.
          unter Chrome verschwindet dann in der rechten Sidebar alle Infos zu den Widgets, die Sidebar bleibt weiß
          unter Firefox werden die Einstellungen angezeigt, aber keine Widgets
          unter IE ebenfalls die Sidebar mit Einstellungen vorhanden, aber keine widgets sichtbar
          Ändern der Z-Ebene hilft nicht
          Hinzufügen von neuen Widgets erfolgt nicht.
          Rainer
          • BluefoxB Offline
            BluefoxB Offline
            Muss jetzt wieder gehen mit 0.5.5
            • O Offline
              O Offline
              opul
              ja bei mir waren auch alle Widgets weg.
              Mit 0.5.5 ist alles wieder da.
              Arno
              Raspberry pi 3 Raspberrymatic / ioBroker
