  4. [erledigt]jarvis: Failed connecting to http://192.168.2....
    6.3k
connection errorjarvis
4 Beiträge 2 Kommentatoren 835 Aufrufe 2 Beobachtet
    Stmiko
    schrieb am zuletzt editiert von Stmiko
    habe seit ein paar Tagen Probleme mit jarvis. Es kommt keine Verbindung mehr zustande.
    Die Entwickler-Console sagt folgendes:
    app.d3faf308.js:1 App Welcome to jarvis v3.0.11
    app.d3faf308.js:1 App Using instance 0.
    app.d3faf308.js:1 App Time - Router Ready: 161.00ms
    app.d3faf308.js:1 19:08:50 | INFO | CONNECTION | Connecting to http://192.168.2.102:8400 (#1)...
    translate_content.js:1 -- Adding event listener for "initpopup" in content script
    translate_content.js:1 -- Adding event listener for "translateGoogleContent" in content script
    translate_content.js:1 -- Adding event listener for "translateGmailContent" in content script
    pdf_content.js:1 -- Adding event listener document event "to-content-script-event-start-pdf-compression-pdf2go"
    pdf_content.js:1 -- Adding event listener for "injectContentCss" in content script
    pdf_content.js:1 -> sending event to service worker from content script: to-service-worker-is-allowed-file-access-pdf2go
    pdf_injected.js:2 -- Adding event listener document event "to-injected-script-event-pdf-init-injected-main-pdf2go"
    pdf_injected.js:2 -- Adding event listener document event "to-injected-script-event-pdf-close-tool-pdf2go"
    pdf_injected.js:2 -- Adding event listener document event "to-injected-script-event-local-compress-fail-pdf2go"
    pdf_injected.js:2 -- Adding event listener for "setProgressBar" in injected script
    pdf_content.js:1 SENDING CONFIG
    pdf_content.js:1 -> Sending docment event "to-injected-script-event-pdf-init-injected-main-pdf2go"
    pdf_injected.js:2 <- Received document event "to-injected-script-event-pdf-init-injected-main-pdf2go"
    app.d3faf308.js:1 19:08:55 | ERROR | CONNECTION | Failed connecting to http://192.168.2.102:8400 (#1)!
    _message @ app.d3faf308.js:1
    app.d3faf308.js:1 19:08:55 | INFO | CONNECTION | Connecting to https://192.168.2.102:8400 (#2)...
    app.d3faf308.js:1 19:09:00 | ERROR | CONNECTION | Failed connecting to https://192.168.2.102:8400 (#2)!
    error @ app.d3faf308.js:1
    (anonym) @ app.d3faf308.js:1
    app.d3faf308.js:1 App-hGejAmgnwn Connection delayed Error: Connection delayed
        at app.d3faf308.js:1:563144
    index.html#/status0:1 Failed to decode downloaded font: http://192.168.2.102:8082/jarvis/fonts/materialdesignicons-webfont.606b1642.woff2
    index.html#/status0:1 OTS parsing error: Failed to convert WOFF 2.0 font to SFNT
    :8400/jarvis-socket/?EIO=4&transport=polling&t=O3TIpMU:1          Failed to load resource: net::ERR_SSL_PROTOCOL_ERROR
    Wann ist das Problem zum 1.mal aufgetreten: Tja, kann ich nicht so genau sagen :(
    Ich bin auf dem beta-Repository. Meine Vermutung ist, das das mit irgendeinem Update kaputt gegangen ist. Leider hört hier mein Halbwissen auf.
    Kann mir evtl. jmd einen Tipp geben, woran das liegen könnte?
    Cache habe ich natürlich schon gelöscht. IP und Port sind richtig!
    js-controller: 4.0.23
    admin: 5.4.9
    jarvis: 3.0.11
    Vielen Dank im Voraus!
    Lg,
    Systemdata Bitte Ausfüllen
    Hardwaresystem: NUC
    Arbeitsspeicher: 16GB
    Festplattenart: SSD/HDD
    Betriebssystem: Debian11
    Node-Version: v14.19.3
    Nodejs-Version: v14.19.3
    NPM-Version: 6.14.17
    Installationsart: Manuell
    Image genutzt: Nein
    iobroker auf Intel NUC mit Proxmox LXC und Raspi3+
    • S Stmiko
      admin: 5.4.9
      jarvis: 3.0.11
      Lg,
      Hardwaresystem: NUC
      Image genutzt: Nein
      M Online
      M Online
      MCU
      @stmiko
      Wenn möglich bei neuen Fragen im jarvis Thread stellen:
      v3 -> https://forum.iobroker.net/topic/49776/jarvis-v3-0-0-just-another-remarkable-vis
      Web-Adapter-Version?
      https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/besonderheiten-v3/fehler-hinweise-v3#error-timeout-oefter-bei-unterschiedlichen-geraeten
        Stmiko
        @mcu sagte in jarvis: Failed connecting to http://192.168.2.102:8400 (#1)!:
        @stmiko
        Ok, Danke für den Hinweis... Lg
        • S Stmiko
          @stmiko
          Stmiko
          Falls es jmd interessiert: Dank proxmox habe ich einen alten snapshot eingespielt und die Updates nach-und-nach wieder eingespielt.......und jetzt läuft jarvis.
          Also k.A. woran das letztendlich gelegen hat :(
          Lg
