  4. Fehler im Log
    5.9k
Fehler im Log
3 Beiträge 2 Kommentatoren 400 Aufrufe 3 Beobachtet
  • RoddiEFR Offline
    RoddiEFR Offline
    RoddiEF
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi4
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte 32GB
    Betriebssystem: Raspi-OS Bullseye (alle Updates aktuell)
    Node-Version: 14.19.1
    NPM-Version: 6.14.16
    Installationsart: Skript
    Image genutzt: Nein
    Hallo, da ich irgenwie nicht weiter komme Stelle ich mal hier meine Frage(n):
    Und zwar habe ich seit Tagen im Logfile von ioBroker folgende Fehlermeldungen,
    influxdb.0 2022-04-16 16:48:56.353 info Add point that had error for SZ-Netzwerk-Total to buffer again, error-count=4
    influxdb.0 2022-04-16 16:48:56.353 warn Error on writePoint("{"value":22075.668,"time":"2022-04-16T14:48:45.328Z","from":"system.adapter.shelly.1","q":0,"ack":true}): Error: {"error":"timeout"} / "{\"error\":\"timeout\"}\n""
    influxdb.0 2022-04-16 16:48:56.344 info Add point that had error for SZ-Netzwerk-Akt to buffer again, error-count=4
    influxdb.0 2022-04-16 16:48:56.343 warn Error on writePoint("{"value":16.3,"time":"2022-04-16T14:48:45.328Z","from":"system.adapter.shelly.1","q":0,"ack":true}): Error: {"error":"timeout"} / "{\"error\":\"timeout\"}\n""
    influxdb.0 2022-04-16 16:48:54.921 info Add point that had error for ST-Fritz-DS-Temp to buffer again, error-count=9
    influxdb.0 2022-04-16 16:48:54.920 warn Error on writePoint("{"value":26.9,"time":"2022-04-16T14:48:43.901Z","from":"system.adapter.shelly.0","q":0,"ack":true}): Error: {"error":"timeout"} / "{\"error\":\"timeout\"}\n""
    influxdb.0 2022-04-16 16:48:54.912 info Add point that had error for ST-FR-Akt to buffer again, error-count=1
    influxdb.0 2022-04-16 16:48:54.911 warn Error on writePoint("{"value":23.49,"time":"2022-04-16T14:48:43.900Z","from":"system.adapter.shelly.0","q":0,"ack":true}): Error: {"error":"timeout"} / "{\"error\":\"timeout\"}\n""
    influxdb.0 2022-04-16 16:48:54.339 info	Add point that had error for SZ-Netzwerk-Total to buffer again, error-count=3
    influxdb.0 2022-04-16 16:48:54.338 warn Error on writePoint("{"value":22075.658,"time":"2022-04-16T14:48:43.313Z","from":"system.adapter.shelly.1","q":0,"ack":true}): Error: {"error":"timeout"} / "{\"error\":\"timeout\"}\n""
    influxdb.0 2022-04-16 16:48:54.334 info Add point that had error for SZ-Netzwerk-Akt to buffer again, error-count=3
    influxdb.0 2022-04-16 16:48:54.333 warn Error on writePoint("{"value":14.2,"time":"2022-04-16T14:48:43.313Z","from":"system.adapter.shelly.1","q":0,"ack":true}): Error: {"error":"timeout"} / "{\"error\":\"timeout\"}\n""
    influxdb.0 2022-04-16 16:48:53.785 info Add point that had error for SZ-PC-Akt to buffer again, error-count=1
    influxdb.0 2022-04-16 16:48:53.784 warn Error on writePoint("{"value":334.35,"time":"2022-04-16T14:48:42.772Z","from":"system.adapter.shelly.0","q":0,"ack":true}): Error: {"error":"timeout"} / "{\"error\":\"timeout\"}\n""
    Kann mir das jemand verständlich Erklären was das ist? Einige sind zwar "info" was ich nicht so Tragisch ansehen würde, aber die "warn Error" sind ziemlich merkwürdig.
    Das ganze lief seit Monaten ohne diese Meldungen und treten erst auf , nachdem einige Adapter von ioBroker aktuallisiert wurden.
    Welche genau kann ich leider nicht mehr nennen, da ich das System (ioBroker & Raspi OS) immer wenn möglich aktuell halte.
    Danke schonmal im voraus....
    Mario
    Ich bin wie ich bin, was anderes bekommt man nicht !!
    RoddiEFR 1 Antwort Letzte Antwort
    • RoddiEFR RoddiEF
      Hardwaresystem: Pi4
      Image genutzt: Nein
      Mario
      RoddiEFR Offline
      RoddiEFR Offline
      RoddiEF
      So das wohl keiner was mit dem Fehler anfangen kann , habe ich jetzt mal die vorletzte verfügbare Version des Influx-Adapters installiert.
      Kommen zwar immer noch ab und zu "Warn"-Meldungen aber damit kann ich leben.
      Beitrag kann geschlossen werden, ich werde mal sehen das Problem mit den "Warn"-Meldungen selber lösen zu können.
      Mfg.
      • RoddiEFR RoddiEF
        Mfg.
        @roddief sagte in Fehler im Log:
        was meinst du damit?
