  4. Zigbee - Error: SRSP - ZDO - mgmtPermitJoinReq after 6000ms
    6.3k
zigbeezigbee2mqttcc2652pzigbee adapter
1 Beiträge 1 Kommentatoren 893 Aufrufe 1 Beobachtet
    Malaus
    Hallo Ihr,
    ich habe einen Zigbee Gateway "CC2652P + WT32-ETH01 mit der Firmware 0.6.4.
    Der Zigbee Adapter hat die Version 1.6.16.
    Ich nutze den Zigbee Kanal 25.
    Leider kommt es häufig zu der o.g. Fehlermeldung.
    Wenn ich etwas steuern möchte kommt diese:
    zigbee.0
    2022-04-01 17:07:49.544	warn	DeviceAvailability:Failed to ping 0x00158d0006efe4c3 RB 278 T
    zigbee.0
    2022-04-01 17:02:25.438	warn	Device '0x00158d0006efe4c3' announced itself
    zigbee.0
    2022-04-01 16:59:38.279	error	Send command to 0x00158d0006efe4c3 failed with no error code (SRSP - AF - dataRequest after 6000ms)
    Zuerst dachte ich, es liegt an Empfangsprobleme. Daher habe ich mal direkt neben dem Stick eine neue Innr Lampe installiert und eingelernt. Dabei kam zuerst folgendes:
    	2022-04-01 16:49:26.072	error	Failed to open the network: Error: SREQ '--> AF - dataRequestExt - {"dstaddrmode":2,"dstaddr":"0x000000000000fffd","destendpoint":242,"dstpanid":0,"srcendpoint":242,"clusterid":33,"transid":25,"options":0,"radius":30,"len":6,"data":{"type":"Buffer","data":[25,42,2,11,254,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)') at Object.func (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:322:27) at runMicrotasks (<anonymous>) at processTicksAndRejections (internal/process/task_queues.js:95:5) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
    Nach Adapter Neustart:
    ee.0
    zigbee.0
    zigbee.0
    zigbee.0
    2022-04-01 16:59:21.815	info	DeviceConfigure successful 0x00158d0006efe4c3 RB 278 T
    zigbee.0
    2022-04-01 16:59:21.669	info	Configuring 0x00158d0006efe4c3 RB 278 T
    zigbee.0
    2022-04-01 16:59:21.666	info	Device '0x00158d0006efe4c3' is supported, identified as: Innr Smart bulb tunable white E27 (RB 278 T)
    zigbee.0
    2022-04-01 16:59:21.665	info	Successfully interviewed '0x00158d0006efe4c3', device has succesfully been paired
    zigbee.0
    2022-04-01 16:59:18.342	warn	Device '0x00158d0006efe4c3' announced itself
    zigbee.0
    2022-04-01 16:59:18.261	warn	Blocked interview for 'undefined' because the network is closed
    zigbee.0
    2022-04-01 16:59:02.516	info	Zigbee started
    zigbee.0
    2022-04-01 16:59:02.515	info	0x086bd7fffe5d09dd (addr 37720): HGZB-01 - Nue / 3A Smart Zigbee 3.0 light controller (Router)
    zigbee.0
    2022-04-01 16:59:02.513	info	0xa4c1382ebf5435a6 (addr 59657): TS0011_switch_module - TuYa 1 gang switch module - (without neutral) (EndDevice)
    zigbee.0
    2022-04-01 16:59:02.511	info	0x00124b0021f2a3c1 (addr 36968): GL-C-006 - Gledopto Zigbee LED Controller WW/CW (Router)
    zigbee.0
    2022-04-01 16:59:02.505	info	0x00124b001d44fc9d (addr 16831): GL-C-007-1ID - Gledopto Zigbee LED Controller RGBW (1 ID) (Router)
    zigbee.0
    2022-04-01 16:59:02.502	info	0x00158d00045bd478 (addr 24608): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    zigbee.0
    2022-04-01 16:59:02.499	info	0x00158d00034f6275 (addr 41062): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
    zigbee.0
    2022-04-01 16:59:02.497	info	0x00158d000588d1ad (addr 30274): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (Unknown)
    zigbee.0
    2022-04-01 16:59:02.495	info	0x00158d00017da30c (addr 65485): RB 178 T - Innr Smart bulb tunable white E27 (Router)
    zigbee.0
    2022-04-01 16:59:02.486	info	0x000b57fffebd6681 (addr 35594): LED1545G12 - IKEA TRADFRI LED bulb E26/E27 980 lumen, dimmable, white spectrum, opal white (Router)
    zigbee.0
    2022-04-01 16:59:02.424	info	Currently 9 devices are joined:
    zigbee.0
    2022-04-01 16:59:02.339	info	--> transmitPower : low
    zigbee.0
    2022-04-01 16:59:02.321	info	Unable to disable LED, unsupported function.
    zigbee.0
    2022-04-01 16:59:02.308	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
    zigbee.0
    2022-04-01 16:59:00.692	info	Installed Version: iobroker.zigbee@1.6.16
    zigbee.0
    2022-04-01 16:59:00.258	info	Starting Zigbee npm ...
    zigbee.0
    2022-04-01 16:59:00.123	info	starting. Version 1.6.16 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.0, js-controller: 4.0.21
    host.ca35ec565b24
    2022-04-01 16:58:56.241	info	instance system.adapter.zigbee.0 started with pid 6741
    host.ca35ec565b24
    2022-04-01 16:58:25.987	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.ca35ec565b24
    2022-04-01 16:58:25.986	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.ca35ec565b24
    2022-04-01 16:58:25.986	error	Caught by controller[1]: at processTimers (internal/timers.js:500:7)
    host.ca35ec565b24
    2022-04-01 16:58:25.986	error	Caught by controller[1]: at listOnTimeout (internal/timers.js:557:17)
    host.ca35ec565b24
    2022-04-01 16:58:25.986	error	Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)
    host.ca35ec565b24
    2022-04-01 16:58:25.985	error	Caught by controller[1]: Error: SRSP - ZDO - mgmtPermitJoinReq after 6000ms
    host.ca35ec565b24
    2022-04-01 16:58:25.985	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    zigbee.0
    2022-04-01 16:58:25.319	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0
    2022-04-01 16:58:25.316	info	terminating
    zigbee.0
    2022-04-01 16:58:24.851	info	Zigbee: disabling joining new devices.
    zigbee.0
    2022-04-01 16:58:24.814	info	cleaned everything up...
    zigbee.0
    2022-04-01 16:58:24.806	error	SRSP - ZDO - mgmtPermitJoinReq after 6000ms
    zigbee.0
    2022-04-01 16:58:24.806	error	Error: SRSP - ZDO - mgmtPermitJoinReq after 6000ms at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (internal/timers.js:557:17) at processTimers (internal/timers.js:500:7)
    zigbee.0
    2022-04-01 16:58:24.805	error	unhandled promise rejection: SRSP - ZDO - mgmtPermitJoinReq after 6000ms
    zigbee.0
    2022-04-01 16:58:24.804	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    2022-04-01 16:58:20.576	error	Failed to interview '0x00158d0006efe4c3', device has not succesfully been paired. undefined
    zigbee.0
    2022-04-01 16:56:10.040	warn	Device '0x00158d0006efe4c3' announced itself
    zigbee.0
    2022-04-01 16:56:09.889	info	Starting interview of '0x00158d0006efe4c3'
    zigbee.0
    2022-04-01 16:54:58.430	info	Zigbee: allowing new devices to join.
    zigbee.0
    2022-04-01 16:54:42.810	info	Zigbee started
    zigbee.0
    2022-04-01 16:54:42.808	info	0x086bd7fffe5d09dd (addr 37720): HGZB-01 - Nue / 3A Smart Zigbee 3.0 light controller (Router)
    zigbee.0
    2022-04-01 16:54:42.807	info	0xa4c1382ebf5435a6 (addr 59657): TS0011_switch_module - TuYa 1 gang switch module - (without neutral) (EndDevice)
    zigbee.0
    2022-04-01 16:54:42.803	info	0x00124b0021f2a3c1 (addr 36968): GL-C-006 - Gledopto Zigbee LED Controller WW/CW (Router)
    zigbee.0
    2022-04-01 16:54:42.800	info	0x00124b001d44fc9d (addr 16831): GL-C-007-1ID - Gledopto Zigbee LED Controller RGBW (1 ID) (Router)
    zigbee.0
    2022-04-01 16:54:42.798	info	0x00158d00045bd478 (addr 24608): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    zigbee.0
    2022-04-01 16:54:42.796	info	0x00158d00034f6275 (addr 41062): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
    zigbee.0
    2022-04-01 16:54:42.794	info	0x00158d000588d1ad (addr 30274): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (Unknown)
    zigbee.0
    2022-04-01 16:54:42.792	info	0x00158d00017da30c (addr 65485): RB 178 T - Innr Smart bulb tunable white E27 (Router)
    zigbee.0
    2022-04-01 16:54:42.785	info	0x000b57fffebd6681 (addr 35594): LED1545G12 - IKEA TRADFRI LED bulb E26/E27 980 lumen, dimmable, white spectrum, opal white (Router)
    zigbee.0
    2022-04-01 16:54:42.724	info	Currently 9 devices are joined:
    zigbee.0
    2022-04-01 16:54:42.588	info	--> transmitPower : low
    zigbee.0
    2022-04-01 16:54:42.571	info	Unable to disable LED, unsupported function.
    zigbee.0
    2022-04-01 16:54:42.543	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
    zigbee.0
    2022-04-01 16:54:40.828	info	Installed Version: iobroker.zigbee@1.6.16
    zigbee.0
    2022-04-01 16:54:40.384	info	Starting Zigbee npm ...
    zigbee.0
    2022-04-01 16:54:40.247	info	starting. Version 1.6.16 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.0, js-controller: 4.0.21
    host.ca35ec565b24
    2022-04-01 16:54:36.373	info	instance system.adapter.zigbee.0 started with pid 6513
    host.ca35ec565b24
    2022-04-01 16:54:36.141	info	"system.adapter.zigbee.0" enabled
    host.ca35ec565b24
    2022-04-01 16:54:03.177	info	Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
    host.ca35ec565b24
    2022-04-01 16:54:03.177	error	instance system.adapter.zigbee.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
    zigbee.0
    2022-04-01 16:54:02.553	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
    zigbee.0
    2022-04-01 16:54:02.475	error	adapter disabled
    host.ca35ec565b24
    2022-04-01 16:53:44.472	info	"system.adapter.zigbee.0" disabled
    host.ca35ec565b24
    2022-04-01 16:53:28.635	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.ca35ec565b24
    2022-04-01 16:53:28.634	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.ca35ec565b24
    2022-04-01 16:53:28.634	error	Caught by controller[1]: at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
    host.ca35ec565b24
    2022-04-01 16:53:28.634	error	Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:95:5)
    host.ca35ec565b24
    2022-04-01 16:53:28.633	error	Caught by controller[1]: at runMicrotasks (<anonymous>)
    host.ca35ec565b24
    2022-04-01 16:53:28.633	error	Caught by controller[1]: at Object.func (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:322:27)
    host.ca35ec565b24
    2022-04-01 16:53:28.633	error	Caught by controller[1]: Error: SREQ '--> AF - dataRequestExt - {"dstaddrmode":2,"dstaddr":"0x000000000000fffd","destendpoint":242,"dstpanid":0,"srcendpoint":242,"clusterid":33,"transid":7,"options":0,"radius":30,"len":6,"data":{"type":"Buffer","data":[25,8,2,11,254,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)')
    host.ca35ec565b24
    2022-04-01 16:53:28.632	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    zigbee.0
    2022-04-01 16:53:27.985	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0
    2022-04-01 16:53:27.984	info	terminating
    zigbee.0
    2022-04-01 16:53:27.536	error	Failed to open the network: Error: SREQ '--> AF - dataRequestExt - {"dstaddrmode":2,"dstaddr":"0x000000000000fffd","destendpoint":242,"dstpanid":0,"srcendpoint":242,"clusterid":33,"transid":8,"options":0,"radius":30,"len":6,"data":{"type":"Buffer","data":[25,9,2,10,0,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)') at Object.func (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:322:27) at runMicrotasks (<anonymous>) at processTicksAndRejections (internal/process/task_queues.js:95:5) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
    zigbee.0
    2022-04-01 16:53:27.520	info	Zigbee: disabling joining new devices.
    zigbee.0
    2022-04-01 16:53:27.482	info	cleaned everything up...
    zigbee.0
    2022-04-01 16:53:27.472	error	SREQ '--> AF - dataRequestExt - {"dstaddrmode":2,"dstaddr":"0x000000000000fffd","destendpoint":242,"dstpanid":0,"srcendpoint":242,"clusterid":33,"transid":7,"options":0,"radius":30,"len":6,"data":{"type":"Buffer","data":[25,8,2,11,254,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)')
    zigbee.0
    2022-04-01 16:53:27.472	error	Error: SREQ '--> AF - dataRequestExt - {"dstaddrmode":2,"dstaddr":"0x000000000000fffd","destendpoint":242,"dstpanid":0,"srcendpoint":242,"clusterid":33,"transid":7,"options":0,"radius":30,"len":6,"data":{"type":"Buffer","data":[25,8,2,11,254,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)') at Object.func (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:322:27) at runMicrotasks (<anonymous>) at processTicksAndRejections (internal/process/task_queues.js:95:5) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
    zigbee.0
    2022-04-01 16:53:27.470	error	unhandled promise rejection: SREQ '--> AF - dataRequestExt - {"dstaddrmode":2,"dstaddr":"0x000000000000fffd","destendpoint":242,"dstpanid":0,"srcendpoint":242,"clusterid":33,"transid":7,"options":0,"radius":30,"len":6,"data":{"type":"Buffer","data":[25,8,2,11,254,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)')
    zigbee.0
    2022-04-01 16:53:27.469	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    2022-04-01 16:50:07.132	info	Zigbee: allowing new devices to join.
    Irgendwann habe ich es geschafft, die neue Lampe einzulernen. Leider kann ich auch diese nicht steuern bzw. nur mit einem sehr starken Verzögerung.
    Hat von euch jemand auch diese Erfahrung? Bzw. weiß jemand, was diese Fehlermeldungen bedeuten?
