  4. iobroker: No connection to databases possible ...
    6.0k
4 Beiträge 2 Kommentatoren 354 Aufrufe 3 Beobachtet
  • L Offline
    lnix
    Hallo Zusammen,
    ich habe seit 2 Wochen Probleme mit meinem iobroker und weiß nicht mehr weiter:
    OS: Linux (RHEL8)
    Status
    [root@iobroker ~]# iobroker status
    oder manchmal dies
     Unable to enable Expiry Keyspace events from Redis Server: Connection is closed.
    Systemd
    [root@iobroker ~]# systemctl status iobroker.service
    ● iobroker.service - ioBroker Server
       Loaded: loaded (/usr/lib/systemd/system/iobroker.service; enabled; vendor preset: disabled)
       Active: active (running) since Wed 2022-03-16 10:29:19 CET; 4min 15s ago
         Docs: http://iobroker.net
     Main PID: 918 (node)
        Tasks: 132 (limit: 10672)
       Memory: 1.0G
       CGroup: /system.slice/iobroker.service
               ├─ 918 iobroker.js-controller
               ├─1564 io.admin.0
               ├─1594 /usr/bin/node /opt/iobroker/node_modules/iobroker.backitup/main.js 0 info
               ├─1595 /usr/bin/node /opt/iobroker/node_modules/iobroker.hmip/main.js 0 info
               ├─1603 /usr/bin/node /opt/iobroker/node_modules/iobroker.javascript/main.js 0 info
               ├─1615 /usr/bin/node /opt/iobroker/node_modules/iobroker.hmip/main.js 1 info
               ├─1621 /usr/bin/node /opt/iobroker/node_modules/iobroker.discovery/main.js 0 info
               ├─1629 io.ble.0
               ├─1635 io.ble.1
               ├─1644 io.whatsapp-cmb.0
               ├─1710 /usr/bin/node /opt/iobroker/node_modules/iobroker.whatsapp-cmb/main.js 1 info
               └─1717 /usr/bin/node /opt/iobroker/node_modules/iobroker.simple-api/main.js 0 info
    Mar 16 10:29:39 iobroker bash[918]: host.iobroker check instance "system.adapter.javascript.0" for host "iobroker"
    Mar 16 10:29:39 iobroker bash[918]: host.iobroker check instance "system.adapter.hmip.0" for host "iobroker"
    Mar 16 10:29:39 iobroker bash[918]: host.iobroker check instance "system.adapter.hmip.1" for host "iobroker"
    Mar 16 10:29:39 iobroker bash[918]: host.iobroker check instance "system.adapter.discovery.0" for host "iobroker"
    Mar 16 10:29:39 iobroker bash[918]: host.iobroker check instance "system.adapter.backitup.0" for host "iobroker"
    Mar 16 10:29:39 iobroker bash[918]: host.iobroker check instance "system.adapter.ble.0" for host "iobroker"
    Mar 16 10:29:39 iobroker bash[918]: host.iobroker check instance "system.adapter.ble.1" for host "iobroker"
    Mar 16 10:29:39 iobroker bash[918]: host.iobroker check instance "system.adapter.whatsapp-cmb.0" for host "iobroker"
    Mar 16 10:29:39 iobroker bash[918]: host.iobroker check instance "system.adapter.whatsapp-cmb.1" for host "iobroker"
    Mar 16 10:29:39 iobroker bash[918]: host.iobroker check instance "system.adapter.simple-api.0" for host "iobroker"
    Version
    [root@iobroker ~]# iobroker -v
    3.3.18
    List Adapters and Instances
    [root@iobroker ~]# iobroker list adapters
    [root@iobroker ~]# iobroker list instances
    Filesystem
    [root@iobroker ~]# ls -la /opt/iobroker
    total 236
    drwxrwxr-x+   6 iobroker iobroker   4096 Mar  2 19:06 .
    drwxr-xr-x.   3 root     root         22 Jun 21  2021 ..
    -rw-rwxr--+   1 iobroker iobroker    155 Mar  2 19:05 .npmrc
    -rwxrwxrwx+   1 iobroker iobroker    607 Mar  2 19:06 INSTALLER_INFO.txt
    drwxrwxr-x+   2 iobroker iobroker   4096 Jan  4 02:45 backups
    lrwxrwxrwx.   1 iobroker iobroker     22 Mar  2 19:06 iob -> /opt/iobroker/iobroker
    -rwxr-xr-x+   1 iobroker iobroker    309 Mar  2 19:06 iobroker
    drwxrwxr-x+   4 iobroker iobroker   4096 Mar 16 10:37 iobroker-data
    drwxrwxr-x+   2 iobroker iobroker   4096 Mar 16 10:37 log
    drwxrwxr-x+ 434 iobroker iobroker  12288 Dec  9 20:51 node_modules
    -rw-rwxr--+   1 iobroker iobroker 182043 Dec  9 20:51 package-lock.json
    -rw-rwxr--+   1 iobroker iobroker    496 Dec  9 20:51 package.json
    -rw-rwxr--+   1 iobroker iobroker   5693 Oct 20 20:35 reinstall.js
    Log: nur Errors
    [root@iobroker log]# tail -200 iobroker.current.log | grep error
    2022-03-16 10:33:22.331  - error: admin.0 (875837) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-16 10:30:10.218  - error: host.iobroker Your system has only 34 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
    2022-03-16 10:30:10.219  - error: host.iobroker In future versions, the adapter might not be started!
    2022-03-16 10:30:10.473  - error: host.iobroker Your system has only 46 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
    2022-03-16 10:30:10.473  - error: host.iobroker In future versions, the adapter might not be started!
    2022-03-16 10:30:10.475  - error: host.iobroker Your system has only 46 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
    2022-03-16 10:30:10.476  - error: host.iobroker In future versions, the adapter might not be started!
    2022-03-16 10:30:10.487  - error: host.iobroker Your system has only 46 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
    2022-03-16 10:30:10.488  - error: host.iobroker In future versions, the adapter might not be started!
    2022-03-16 10:30:10.490  - error: host.iobroker Your system has only 46 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
    2022-03-16 10:30:10.490  - error: host.iobroker In future versions, the adapter might not be started!
    2022-03-16 10:30:11.166  - error: host.iobroker Your system has only 39 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
    2022-03-16 10:30:11.167  - error: host.iobroker In future versions, the adapter might not be started!
    2022-03-16 10:30:11.168  - error: host.iobroker Your system has only 39 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
    2022-03-16 10:30:11.169  - error: host.iobroker In future versions, the adapter might not be started!
    2022-03-16 10:35:41.658  - error: ble.1 (1635) States database error: read ECONNRESET
    2022-03-16 10:35:41.676  - error: ble.0 (1629) States database error: read ECONNRESET
    2022-03-16 10:35:41.691  - error: admin.0 (1564) States database error: read ECONNRESET
    2022-03-16 10:35:41.743  - error: whatsapp-cmb.0 (1644) States database error: read ECONNRESET
    2022-03-16 10:35:42.113  - warn: simple-api.0 (1717) get state error: Connection is closed.
    2022-03-16 10:35:42.256  - warn: whatsapp-cmb.1 (1710) get state error: Connection is closed.
    2022-03-16 10:35:42.398  - warn: simple-api.0 (1717) redis get system.adapter.simple-api.0.alive, error - Connection is closed.
    2022-03-16 10:35:42.399  - warn: simple-api.0 (1717) redis get system.adapter.simple-api.0.sigKill, error - Connection is closed.
    2022-03-16 10:35:46.741  - error: ble.1 (1635) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-16 10:35:46.781  - error: ble.0 (1629) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-16 10:35:46.916  - error: admin.0 (1564) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-16 10:35:47.022  - error: discovery.0 (1621) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-16 10:35:47.179  - error: hmip.1 (1615) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-16 10:35:47.265  - error: backitup.0 (1594) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-16 10:35:47.259  - error: whatsapp-cmb.0 (1644) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-16 10:35:47.402  - error: hmip.0 (1595) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-16 10:35:47.491  - error: javascript.0 (1603) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-16 10:35:51.848  - error: ble.1 (1635) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-16 10:35:51.848  - error: ble.0 (1629) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-16 10:35:52.092  - error: discovery.0 (1621) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-16 10:35:52.130  - error: admin.0 (1564) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-16 10:35:52.253  - error: hmip.1 (1615) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-16 10:35:52.630  - error: hmip.0 (1595) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-16 10:35:53.020  - error: javascript.0 (1603) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-16 10:35:53.077  - error: whatsapp-cmb.0 (1644) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-16 10:35:53.220  - error: backitup.0 (1594) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-16 10:35:56.649  - warn: ble.1 (1635) get state error: Connection is closed.
    2022-03-16 10:35:56.676  - warn: javascript.0 (1603) get state error: Connection is closed.
    2022-03-16 10:35:56.678  - warn: backitup.0 (1594) get state error: Connection is closed.
    2022-03-16 10:35:56.687  - warn: hmip.0 (1595) get state error: Connection is closed.
    2022-03-16 10:35:56.714  - warn: whatsapp-cmb.0 (1644) get state error: Connection is closed.
    2022-03-16 10:35:56.743  - warn: admin.0 (1564) get state error: Connection is closed.
    2022-03-16 10:35:56.755  - warn: discovery.0 (1621) get state error: Connection is closed.
    2022-03-16 10:35:56.694  - warn: javascript.0 (1603) get state error: DB closed
    2022-03-16 10:35:56.700  - warn: hmip.0 (1595) get state error: DB closed
    2022-03-16 10:35:56.780  - warn: ble.0 (1629) get state error: Connection is closed.
    2022-03-16 10:35:56.799  - warn: hmip.1 (1615) get state error: Connection is closed.
    2022-03-16 10:36:34.738  - error: host.iobroker No connection to databases possible, restart
    Log letzte 200 Zeilen
    2022-03-16 10:33:17.331  - info: javascript.0 (875848) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-16 10:33:17.329  - info: hmip.1 (875862) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-16 10:33:17.336  - info: discovery.0 (875869) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-16 10:33:17.340  - info: hmip.0 (875849) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-16 10:33:17.338  - info: backitup.0 (875880) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-16 10:33:18.831  - info: admin.0 (875837) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-16 10:33:26.777  - info: host.iobroker iobroker.js-controller version 3.3.18 js-controller starting
    2022-03-16 10:33:26.784  - info: host.iobroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2022-03-16 10:33:26.785  - info: host.iobroker hostname: iobroker, node: v12.22.5
    2022-03-16 10:33:26.786  - info: host.iobroker ip addresses: 192.168.1.20 fe80::6853:56f4:505b:6c99
    2022-03-16 10:33:39.731  - info: host.iobroker connected to Objects and States
    2022-03-16 10:33:41.526  - info: host.iobroker added notifications configuration of host
    2022-03-16 10:33:44.413  - info: host.iobroker 11 instances found
    2022-03-16 10:33:44.443  - info: host.iobroker starting 11 instances
    2022-03-16 10:33:45.018  - info: host.iobroker instance system.adapter.admin.0 started with pid 875921
    2022-03-16 10:33:52.299  - info: admin.0 (875921) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-16 10:33:52.674  - warn: admin.0 (875921) slow connection to objects DB. Still waiting ...
    2022-03-16 10:33:52.894  - info: host.iobroker received SIGTERM
    2022-03-16 10:33:52.898  - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
    2022-03-16 10:33:52.901  - info: host.iobroker stopInstance system.adapter.javascript.0 (force=false, process=false)
    2022-03-16 10:33:52.902  - info: host.iobroker stopInstance system.adapter.hmip.0 (force=false, process=false)
    2022-03-16 10:33:52.902  - info: host.iobroker stopInstance system.adapter.hmip.1 (force=false, process=false)
    2022-03-16 10:33:52.903  - info: host.iobroker stopInstance system.adapter.discovery.0 (force=false, process=false)
    2022-03-16 10:33:52.903  - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=false)
    2022-03-16 10:33:52.904  - info: host.iobroker stopInstance system.adapter.ble.0 (force=false, process=false)
    2022-03-16 10:33:52.904  - info: host.iobroker stopInstance system.adapter.ble.1 (force=false, process=false)
    2022-03-16 10:33:52.905  - info: host.iobroker stopInstance system.adapter.whatsapp-cmb.0 (force=false, process=false)
    2022-03-16 10:33:52.905  - info: host.iobroker stopInstance system.adapter.whatsapp-cmb.1 (force=false, process=false)
    2022-03-16 10:33:52.906  - info: host.iobroker stopInstance system.adapter.simple-api.0 (force=false, process=false)
    2022-03-16 10:33:57.250  - info: host.iobroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2022-03-16 10:33:57.258  - info: host.iobroker All instances are stopped.
    2022-03-16 10:33:57.262  - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
    2022-03-16 10:33:59.268  - info: host.iobroker terminated
    2022-03-16 10:29:22.152  - info: host.iobroker iobroker.js-controller version 3.3.18 js-controller starting
    2022-03-16 10:29:22.159  - info: host.iobroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2022-03-16 10:29:22.159  - info: host.iobroker hostname: iobroker, node: v12.22.5
    2022-03-16 10:29:22.160  - info: host.iobroker ip addresses:
    2022-03-16 10:29:35.267  - info: host.iobroker connected to Objects and States
    2022-03-16 10:29:37.004  - info: host.iobroker added notifications configuration of host
    2022-03-16 10:29:39.852  - info: host.iobroker 11 instances found
    2022-03-16 10:29:39.882  - info: host.iobroker starting 11 instances
    2022-03-16 10:29:40.426  - info: host.iobroker instance system.adapter.admin.0 started with pid 1564
    2022-03-16 10:29:48.325  - warn: admin.0 (1564) slow connection to objects DB. Still waiting ...
    2022-03-16 10:30:11.263  - warn: admin.0 (1564) slow connection to states DB. Still waiting ...
    2022-03-16 10:30:11.354  - info: host.iobroker instance system.adapter.backitup.0 started with pid 1594
    2022-03-16 10:30:11.493  - info: host.iobroker instance system.adapter.hmip.0 started with pid 1595
    2022-03-16 10:30:11.622  - info: host.iobroker instance system.adapter.javascript.0 started with pid 1603
    2022-03-16 10:30:11.760  - info: host.iobroker instance system.adapter.hmip.1 started with pid 1615
    2022-03-16 10:30:11.875  - info: host.iobroker instance system.adapter.discovery.0 started with pid 1621
    2022-03-16 10:30:12.012  - info: host.iobroker instance system.adapter.ble.0 started with pid 1629
    2022-03-16 10:30:12.151  - info: host.iobroker instance system.adapter.ble.1 started with pid 1635
    2022-03-16 10:30:14.144  - warn: host.iobroker Your system has only 58 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
    2022-03-16 10:30:14.283  - info: host.iobroker instance system.adapter.whatsapp-cmb.0 started with pid 1644
    2022-03-16 10:30:25.214  - warn: backitup.0 (1594) slow connection to objects DB. Still waiting ...
    2022-03-16 10:30:25.201  - warn: discovery.0 (1621) slow connection to objects DB. Still waiting ...
    2022-03-16 10:30:25.203  - warn: ble.1 (1635) slow connection to objects DB. Still waiting ...
    2022-03-16 10:30:25.196  - warn: ble.0 (1629) slow connection to objects DB. Still waiting ...
    2022-03-16 10:30:26.581  - warn: hmip.0 (1595) slow connection to objects DB. Still waiting ...
    2022-03-16 10:30:26.665  - warn: hmip.1 (1615) slow connection to objects DB. Still waiting ...
    2022-03-16 10:30:26.759  - warn: whatsapp-cmb.0 (1644) slow connection to objects DB. Still waiting ...
    2022-03-16 10:30:27.225  - warn: javascript.0 (1603) slow connection to objects DB. Still waiting ...
    2022-03-16 10:30:53.618  - warn: ble.1 (1635) slow connection to states DB. Still waiting ...
    2022-03-16 10:31:00.430  - warn: hmip.0 (1595) slow connection to states DB. Still waiting ...
    2022-03-16 10:31:00.434  - warn: whatsapp-cmb.0 (1644) slow connection to states DB. Still waiting ...
    2022-03-16 10:31:00.466  - warn: discovery.0 (1621) slow connection to states DB. Still waiting ...
    2022-03-16 10:31:00.485  - warn: backitup.0 (1594) slow connection to states DB. Still waiting ...
    2022-03-16 10:31:00.520  - warn: ble.0 (1629) slow connection to states DB. Still waiting ...
    2022-03-16 10:31:00.528  - warn: hmip.1 (1615) slow connection to states DB. Still waiting ...
    2022-03-16 10:31:00.650  - warn: javascript.0 (1603) slow connection to states DB. Still waiting ...
    2022-03-16 10:31:04.230  - info: host.iobroker instance system.adapter.whatsapp-cmb.1 started with pid 1710
    2022-03-16 10:31:04.350  - info: host.iobroker instance system.adapter.simple-api.0 started with pid 1717
    2022-03-16 10:31:04.803  - info: admin.0 (1564) starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.5, js-controller: 3.3.18
    2022-03-16 10:31:05.718  - info: admin.0 (1564) requesting all states
    2022-03-16 10:31:05.719  - info: admin.0 (1564) requesting all objects
    2022-03-16 10:31:14.223  - warn: whatsapp-cmb.1 (1710) slow connection to objects DB. Still waiting ...
    2022-03-16 10:31:14.308  - warn: simple-api.0 (1717) slow connection to objects DB. Still waiting ...
    2022-03-16 10:31:27.012  - info: whatsapp-cmb.0 (1644) starting. Version 0.1.6 in /opt/iobroker/node_modules/iobroker.whatsapp-cmb, node: v12.22.5, js-controller: 3.3.18
    2022-03-16 10:31:27.435  - warn: whatsapp-cmb.0 (1644) APIKEY is not provided. No messages will be sent
    2022-03-16 10:31:31.998  - warn: simple-api.0 (1717) slow connection to states DB. Still waiting ...
    2022-03-16 10:32:18.124  - info: ble.1 (1635) starting. Version 0.12.0 in /opt/iobroker/node_modules/iobroker.ble, node: v12.22.5, js-controller: 3.3.18
    2022-03-16 10:32:38.362  - info: ble.0 (1629) starting. Version 0.12.0 in /opt/iobroker/node_modules/iobroker.ble, node: v12.22.5, js-controller: 3.3.18
    2022-03-16 10:33:42.589  - warn: whatsapp-cmb.1 (1710) slow connection to states DB. Still waiting ...
    2022-03-16 10:35:41.628  - warn: whatsapp-cmb.1 (1710) Unable to enable Expiry Keyspace events from Redis Server: Connection is closed.
    2022-03-16 10:35:41.834  - info: admin.0 (1564) terminating https server on port 8081
    2022-03-16 10:35:42.146  - info: simple-api.0 (1717) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-16 10:35:42.259  - info: whatsapp-cmb.1 (1710) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-16 10:35:42.369  - warn: simple-api.0 (1717) Unable to subscribe to expiry Keyspace events from Redis Server: Connection is closed.
    2022-03-16 10:35:42.371  - warn: simple-api.0 (1717) Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
    2022-03-16 10:35:43.228  - info: ble.1 (1635) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-16 10:35:43.239  - info: ble.0 (1629) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-16 10:35:43.270  - info: discovery.0 (1621) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-16 10:35:43.339  - info: admin.0 (1564) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-16 10:35:43.354  - info: hmip.1 (1615) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-16 10:35:43.668  - info: backitup.0 (1594) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-16 10:35:43.661  - info: javascript.0 (1603) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-16 10:35:43.688  - info: whatsapp-cmb.0 (1644) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-16 10:35:43.726  - info: hmip.0 (1595) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-16 10:35:46.698  - info: ble.1 (1635) Objects database successfully reconnected
    2022-03-16 10:35:46.762  - info: ble.0 (1629) Objects database successfully reconnected
    2022-03-16 10:35:46.904  - info: admin.0 (1564) Objects database successfully reconnected
    2022-03-16 10:35:47.221  - info: whatsapp-cmb.0 (1644) Objects database successfully reconnected
    2022-03-16 10:36:03.154  - info: host.iobroker iobroker.js-controller version 3.3.18 js-controller starting
    2022-03-16 10:36:03.165  - info: host.iobroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2022-03-16 10:36:03.166  - info: host.iobroker hostname: iobroker, node: v12.22.5
    2022-03-16 10:36:03.167  - info: host.iobroker ip addresses: 192.168.1.20 fe80::6853:56f4:505b:6c99
    2022-03-16 10:36:34.745  - info: host.iobroker iobroker _restart
    2022-03-16 10:36:36.483  - info: host.iobroker connected to Objects and States
    2022-03-16 10:36:42.006  - info: host.iobroker iobroker.js-controller version 3.3.18 js-controller starting
    2022-03-16 10:36:42.013  - info: host.iobroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2022-03-16 10:36:42.013  - info: host.iobroker hostname: iobroker, node: v12.22.5
    2022-03-16 10:36:42.014  - info: host.iobroker ip addresses: 192.168.1.20 fe80::6853:56f4:505b:6c99
    2022-03-16 10:36:54.657  - info: host.iobroker connected to Objects and States
    2022-03-16 10:36:56.534  - info: host.iobroker added notifications configuration of host
    2022-03-16 10:36:59.440  - info: host.iobroker 11 instances found
    2022-03-16 10:36:59.470  - info: host.iobroker starting 11 instances
    2022-03-16 10:37:00.042  - info: host.iobroker instance system.adapter.admin.0 started with pid 1842
    2022-03-16 10:37:07.769  - warn: admin.0 (1842) slow connection to objects DB. Still waiting ...
    2022-03-16 10:37:14.661  - warn: admin.0 (1842) slow connection to states DB. Still waiting ...
    2022-03-16 10:37:16.873  - info: host.iobroker instance system.adapter.javascript.0 started with pid 1853
    2022-03-16 10:37:16.941  - info: host.iobroker instance system.adapter.hmip.0 started with pid 1856
    2022-03-16 10:37:17.081  - info: host.iobroker instance system.adapter.hmip.1 started with pid 1867
    2022-03-16 10:37:17.275  - info: host.iobroker instance system.adapter.discovery.0 started with pid 1874
    2022-03-16 10:37:19.889  - info: host.iobroker instance system.adapter.backitup.0 started with pid 1882
    2022-03-16 10:37:29.044  - warn: discovery.0 (1874) slow connection to objects DB. Still waiting ...
    2022-03-16 10:37:29.183  - warn: hmip.0 (1856) slow connection to objects DB. Still waiting ...
    2022-03-16 10:37:29.215  - warn: hmip.1 (1867) slow connection to objects DB. Still waiting ...
    2022-03-16 10:37:29.418  - warn: backitup.0 (1882) slow connection to objects DB. Still waiting ...
    2022-03-16 10:37:29.922  - warn: javascript.0 (1853) slow connection to objects DB. Still waiting ...
    2022-03-16 10:37:45.748  - info: admin.0 (1842) starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.5, js-controller: 3.3.18
    2022-03-16 10:37:52.533  - warn: backitup.0 (1882) slow connection to states DB. Still waiting ...
    2022-03-16 10:37:52.588  - warn: discovery.0 (1874) slow connection to states DB. Still waiting ...
    2022-03-16 10:37:52.624  - warn: hmip.1 (1867) slow connection to states DB. Still waiting ...
    2022-03-16 10:37:52.625  - warn: hmip.0 (1856) slow connection to states DB. Still waiting ...
    2022-03-16 10:37:52.800  - info: admin.0 (1842) requesting all states
    2022-03-16 10:37:52.801  - info: admin.0 (1842) requesting all objects
    2022-03-16 10:37:54.956  - warn: javascript.0 (1853) slow connection to states DB. Still waiting ...
    2022-03-16 10:37:58.972  - info: host.iobroker instance system.adapter.ble.0 started with pid 1911
    2022-03-16 10:37:59.094  - info: host.iobroker instance system.adapter.ble.1 started with pid 1912
    2022-03-16 10:37:59.197  - info: host.iobroker instance system.adapter.whatsapp-cmb.1 started with pid 1920
    2022-03-16 10:37:59.337  - info: host.iobroker instance system.adapter.whatsapp-cmb.0 started with pid 1927
    2022-03-16 10:37:59.499  - info: host.iobroker instance system.adapter.simple-api.0 started with pid 1938
    2022-03-16 10:38:09.924  - warn: ble.0 (1911) slow connection to objects DB. Still waiting ...
    2022-03-16 10:38:09.936  - warn: ble.1 (1912) slow connection to objects DB. Still waiting ...
    2022-03-16 10:38:09.949  - warn: simple-api.0 (1938) slow connection to objects DB. Still waiting ...
    2022-03-16 10:38:10.466  - warn: whatsapp-cmb.1 (1920) slow connection to objects DB. Still waiting ...
    2022-03-16 10:38:10.625  - warn: whatsapp-cmb.0 (1927) slow connection to objects DB. Still waiting ...
    2022-03-16 10:38:20.316  - warn: whatsapp-cmb.0 (1927) slow connection to states DB. Still waiting ...
    Habt ihr eine Idee? System habe ich geupdatet und auch folgendes durchgeführt:
    iobroker fix
    Viele Grüße
    lnix
    • L lnix
      Hallo Zusammen,
      OS: Linux (RHEL8)
      Status
      oder manchmal dies
      Systemd
         Memory: 1.0G
                 ├─1564 io.admin.0
                 ├─1629 io.ble.0
                 ├─1635 io.ble.1
      Version
      3.3.18
      Filesystem
      total 236
      Log: nur Errors
      iobroker fix
      Viele Grüße
      lnix
      wendy2702W Online
      wendy2702W Online
      wendy2702
      @lnix sagte in iobroker: No connection to databases possible ...:
      Ja, du hast erstmal kein RAM mehr.
      Da würde ich mich mal zuerst drum kümmern.
      L 1 Antwort Letzte Antwort
      • wendy2702W wendy2702
        lnix
        @wendy2702 ja genau.
        Habe kdump abgeschaltet und bekomme die Meldung erstmal nicht. Kaufe mir einfach nochmal 2GB dazu bei Kleinanzeigen.
        Allerdings habe ich immer noch das Problem. Gibt es für die DB einen eigenen Service oder so?
        • L lnix
          wendy2702W Online
          wendy2702W Online
          wendy2702
          @lnix Sehe gerade noch eine mögliche Ursache:
          root@iobroker
          leg dir einen User an, mit "root" hast du dir möglicherweise schon diverse rechte verbogen.
          Eigenen User dann erst nochmal "iob fix"
