  4. [Frage] zur Konfiguration Modbus Seriell
    6.8k
21 Beiträge 4 Kommentatoren 3.4k Aufrufe
  • C Offline
    ChristianF
    Danke für den Tipp, hat leider nicht funktioniert.
    Falls es hilft, hier das Log (von unten nach oben zu lesen):
    host.HWR-Raspi	2017-04-15 00:03:55.958	warn	startInstance cannot find adapter "modbus". Try to install it... 2 attempt
    host.HWR-Raspi	2017-04-15 00:03:54.875	info	iobroker exit 25
    host.HWR-Raspi	2017-04-15 00:03:54.842	error	iobroker host.HWR-Raspi Cannot install iobroker.modbus: 1
    host.HWR-Raspi	2017-04-15 00:03:54.768	info	iobroker npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log
    host.HWR-Raspi	2017-04-15 00:03:54.758	info	iobroker
    host.HWR-Raspi	2017-04-15 00:03:45.599	info	iobroker Failed at the serialport@4.0.7 install script 'node-pre-gyp install --fallback-to-build'.npm ERR! This is most likely a problem with the serialport package, npm ERR! not with npm itself. npm
    host.HWR-Raspi	2017-04-15 00:03:45.598	info	iobroker ERR!
    host.HWR-Raspi	2017-04-15 00:03:45.598	info	iobroker npm ERR! npm
    host.HWR-Raspi	2017-04-15 00:03:45.597	info	iobroker npm ERR! serialport@4.0.7 install: `node-pre-gyp install --fallback-to-build` npm ERR! Exit status 1
    host.HWR-Raspi	2017-04-15 00:03:45.597	info	iobroker npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.modbus" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.8.2 npm ERR! npm v2.15.11 npm ERR! code ELIFECYCLE
    host.HWR-Raspi	2017-04-15 00:03:45.596	info	iobroker ERR! Linux 4.4.38-v7+
    host.HWR-Raspi	2017-04-15 00:03:45.594	info	iobroker npm
    host.HWR-Raspi	2017-04-15 00:03:45.448	info	iobroker optional dep failed, continuing serialport@3.1.2
    host.HWR-Raspi	2017-04-15 00:03:45.447	info	iobroker WARN
    host.HWR-Raspi	2017-04-15 00:03:45.445	info	iobroker
    host.HWR-Raspi	2017-04-15 00:03:45.437	info	iobroker npm
    host.HWR-Raspi	2017-04-15 00:03:45.407	info	iobroker stack at maybeClose (internal/child_process.js:862:16)node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:222:5) node-pre-gyp ERR! System Linux 4
    host.HWR-Raspi	2017-04-15 00:03:45.393	info	iobroker
    host.HWR-Raspi	2017-04-15 00:03:45.391	info	iobroker ERR!
    host.HWR-Raspi	2017-04-15 00:03:45.390	info	iobroker node-pre-gyp
    host.HWR-Raspi	2017-04-15 00:03:45.390	info	iobroker at ChildProcess.emit (events.js:172:7)
    host.HWR-Raspi	2017-04-15 00:03:45.389	info	iobroker stack
    host.HWR-Raspi	2017-04-15 00:03:45.389	info	iobroker ERR!
    host.HWR-Raspi	2017-04-15 00:03:45.388	info	iobroker node-pre-gyp
    host.HWR-Raspi	2017-04-15 00:03:45.388	info	iobroker at emitTwo (events.js:87:13)
    host.HWR-Raspi	2017-04-15 00:03:45.387	info	iobroker stack
    host.HWR-Raspi	2017-04-15 00:03:45.387	info	iobroker ERR!
    host.HWR-Raspi	2017-04-15 00:03:45.386	info	iobroker node-pre-gyp
    host.HWR-Raspi	2017-04-15 00:03:45.386	info	iobroker at ChildProcess. (/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    host.HWR-Raspi	2017-04-15 00:03:45.386	info	iobroker stack
    host.HWR-Raspi	2017-04-15 00:03:45.385	info	iobroker ERR!
    host.HWR-Raspi	2017-04-15 00:03:45.385	info	iobroker node-pre-gyp
    host.HWR-Raspi	2017-04-15 00:03:45.384	info	iobroker stack Error: Failed to execute '/usr/bin/nodejs /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.modbus/n
    host.HWR-Raspi	2017-04-15 00:03:45.383	info	iobroker ERR!
    host.HWR-Raspi	2017-04-15 00:03:45.381	info	iobroker node-pre-gyp
    host.HWR-Raspi	2017-04-15 00:03:45.331	info	iobroker ERR! build error
    host.HWR-Raspi	2017-04-15 00:03:45.328	info	iobroker node-pre-gyp
    host.HWR-Raspi	2017-04-15 00:03:45.313	info	iobroker gyp ERR! System Linux 4.4.38-v7+gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node
    host.HWR-Raspi	2017-04-15 00:03:45.298	info	iobroker ERR! stack at emitTwo (events.js:87:13)gyp ERR! stack at ChildProcess.emit (events.js:172:7) gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:
    host.HWR-Raspi	2017-04-15 00:03:45.287	info	iobroker stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23) gyp
    host.HWR-Raspi	2017-04-15 00:03:45.282	info	iobroker ERR!
    host.HWR-Raspi	2017-04-15 00:03:45.277	info	iobroker gyp
    host.HWR-Raspi	2017-04-15 00:03:45.254	info	iobroker ERR! build error
    host.HWR-Raspi	2017-04-15 00:03:45.249	info	iobroker
    host.HWR-Raspi	2017-04-15 00:03:45.237	info	iobroker gyp
    host.HWR-Raspi	2017-04-15 00:03:45.227	info	iobroker make: *** No rule to make target '../.node-gyp/4.8.2/include/node/common.gypi', needed by 'Makefile'. Schluss.
    host.HWR-Raspi	2017-04-15 00:03:38.545	info	iobroker attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/.node-gyp"
    host.HWR-Raspi	2017-04-15 00:03:38.542	info	iobroker gyp WARN EACCES
    host.HWR-Raspi	2017-04-15 00:03:38.536	info	iobroker WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/4.8.2"
    host.HWR-Raspi	2017-04-15 00:03:38.532	info	iobroker
    host.HWR-Raspi	2017-04-15 00:03:38.523	info	iobroker gyp
    host.HWR-Raspi	2017-04-15 00:03:33.033	info	iobroker Pre-built binaries not found for serialport@3.1.2 and node@4.8.2 (node-v46 ABI) (falling back to source compile with node-gyp)
    host.HWR-Raspi	2017-04-15 00:03:33.031	info	iobroker node-pre-gyp ERR!
    host.HWR-Raspi	2017-04-15 00:03:33.020	info	iobroker
    host.HWR-Raspi	2017-04-15 00:03:33.014	info	iobroker ERR! Tried to download: https://github.com/voodootikigod/node-serialport/releases/download/3.1.2/serialport-v3.1.2-node-v46-linux-arm.tar.gz
    host.HWR-Raspi	2017-04-15 00:03:33.009	info	iobroker
    host.HWR-Raspi	2017-04-15 00:03:33.005	info	iobroker node-pre-gyp
    host.HWR-Raspi	2017-04-15 00:03:28.060	info	iobroker node-pre-gyp ERR! not ok
    host.HWR-Raspi	2017-04-15 00:03:28.060	info	iobroker v4.8.2node-pre-gyp ERR! node-pre-gyp -v v0.6.32
    host.HWR-Raspi	2017-04-15 00:03:28.060	info	iobroker node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialportnode-pre-gyp ERR! node -v
    host.HWR-Raspi	2017-04-15 00:03:28.059	info	iobroker node-pre-gyp ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-
    host.HWR-Raspi	2017-04-15 00:03:28.059	info	iobroker node-pre-gyp ERR! System Linux 4.4.38-v7+
    host.HWR-Raspi	2017-04-15 00:03:28.058	info	iobroker ERR! stack Error: Failed to execute '/usr/bin/nodejs /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.mo
    host.HWR-Raspi	2017-04-15 00:03:28.055	info	iobroker node-pre-gyp
    host.HWR-Raspi	2017-04-15 00:03:28.017	info	iobroker node-pre-gyp ERR! build error
    host.HWR-Raspi	2017-04-15 00:03:28.004	info	iobroker gyp ERR! node-gyp -v v3.4.0gyp ERR! not ok
    host.HWR-Raspi	2017-04-15 00:03:28.004	info	iobroker cwd /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialportgyp ERR! node -v v4.8.2
    host.HWR-Raspi	2017-04-15 00:03:28.003	info	iobroker ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.modbus/node_modul
    host.HWR-Raspi	2017-04-15 00:03:28.002	info	iobroker gyp
    host.HWR-Raspi	2017-04-15 00:03:28.001	info	iobroker stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)gyp ERR! System Linux 4.4.38-v7+
    host.HWR-Raspi	2017-04-15 00:03:28.001	info	iobroker ERR! stack at ChildProcess.emit (events.js:172:7)gyp ERR!
    host.HWR-Raspi	2017-04-15 00:03:27.997	info	iobroker ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23) gyp ERR! stack at emitTwo
    host.HWR-Raspi	2017-04-15 00:03:27.964	info	iobroker gyp
    host.HWR-Raspi	2017-04-15 00:03:27.940	info	iobroker ERR! build error
    host.HWR-Raspi	2017-04-15 00:03:27.935	info	iobroker
    host.HWR-Raspi	2017-04-15 00:03:27.924	info	iobroker gyp
    host.HWR-Raspi	2017-04-15 00:03:27.904	info	iobroker make: *** No rule to make target '../.node-gyp/4.8.2/include/node/common.gypi', needed by 'Makefile'. Schluss.
    host.HWR-Raspi	2017-04-15 00:03:20.041	info	iobroker gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/.node-gyp"
    host.HWR-Raspi	2017-04-15 00:03:20.034	info	iobroker WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/4.8.2"
    host.HWR-Raspi	2017-04-15 00:03:20.031	info	iobroker
    host.HWR-Raspi	2017-04-15 00:03:20.014	info	iobroker gyp
    host.HWR-Raspi	2017-04-15 00:03:14.877	info	iobroker ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v46-linux-arm.tar.gz node-pre-gyp ERR! Pre-built bin
    host.HWR-Raspi	2017-04-15 00:03:14.874	info	iobroker node-pre-gyp
    host.HWR-Raspi	2017-04-15 00:02:19.729	info	iobroker npm install iobroker.modbus --production --prefix "/opt/iobroker" (System call)
    host.HWR-Raspi	2017-04-15 00:02:19.298	info	instance system.adapter.ical.1 terminated with code 0 (OK)
    cul.0	2017-04-15 00:02:16.377	info	starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.cul, node: v4.8.2
    host.HWR-Raspi	2017-04-15 00:02:15.702	info	iobroker install modbus
    Viele Grüße
    Christian
