  4. Skript: TypeError: Converting circular structure to JSON
    1.0k
    3.2k
3 Beiträge 3 Kommentatoren 319 Aufrufe 3 Beobachtet
    abcklaus
    schrieb am zuletzt editiert von abcklaus
    Systemdata Bitte Ausfüllen
    Hardwaresystem: NUC
    Arbeitsspeicher: 4GB
    Festplattenart: HDD
    Betriebssystem: Ubuntu / Docker
    Node-Version: 10.x.x
    Nodejs-Version: 14.18.3
    NPM-Version: 6.14.15
    Installationsart: Docker
    Image genutzt: Nein
    Ort/Name der Imagedatei: Link
    Zur Steuerung meines AV Receivers nutze ich dieses Skript.
    var host, port, message;
    let socketClient;
    host = '10.10.21.14';
    port = 84;
    // PowerON
    on({id: 'fakeroku.0.lyngdorf.keys.Select', change: "any"}, async function (obj) {
      var value = obj.state.val;
      if (getState("fakeroku.0.lyngdorf.keys.Select").val) {
        await Send_mesage_via_TCP(host, port, '!POWERONMAIN\r');
    // PowerOFF
    on({id: 'fakeroku.0.lyngdorf.keys.Home', change: "any"}, async function (obj) {
      if (getState("fakeroku.0.lyngdorf.keys.Home").val) {
        await Send_mesage_via_TCP(host, port, '!POWEROFFMAIN\r');
    // Vol+
    on({id: 'fakeroku.0.lyngdorf.keys.Up', change: "any"}, async function (obj) {
      if (getState("fakeroku.0.lyngdorf.keys.Up").val) {
        await Send_mesage_via_TCP(host, port, '!VOL+\r!VOL+\r');
    // Vol-
    on({id: 'fakeroku.0.lyngdorf.keys.Down', change: "any"}, async function (obj) {
      if (getState("fakeroku.0.lyngdorf.keys.Down").val) {
        await Send_mesage_via_TCP(host, port, '!VOL-\r!VOL-\r');
    async function Send_mesage_via_TCP(host, port, message) {
        // Create the socket client if it was not already created
        if (!socketClient) {
            console.log('create new connection.');
            var net = require('net');
            socketClient = net.connect({ host: host, port: port });
            // On disconnect
            socketClient.on("end", () => {
                console.log("Disconnected from API");
                socketClient.destroy();
                socketClient = null;
            // Wait until connection is established
            await once(socketClient, "connect");
        // Send the message
        socketClient.write(message);
        // Listen for the response
        const data = await once(socketClient, "data");
        //const response = JSON.parse(data).result;
    Das Skript steuert den AV Receiver via TCP Befehlen. Das klappt soweit seit Monaten bestens. Seit einigen Tagen erhalte ich im Log diese Fehler:
    2022-03-13 19:33:30.286  - info: javascript.0 (135) script.js.common.Lyngdorf.Fernbedienung: getState(id=fakeroku.0.lyngdorf.keys.Down, timerId=undefined) => {"val":true,"ack":true,"ts":1647196410285,"q":0,"from":"system.adapter.fakeroku.0","user":"system.user.admin","lc":1647196410285}
    2022-03-13 19:33:30.287  - error: javascript.0 (135) script.js.common.Lyngdorf.Fernbedienung: TypeError: Converting circular structure to JSON
    2022-03-13 19:33:30.287  - error: javascript.0 (135)     --> starting at object with constructor 'Socket'
    2022-03-13 19:33:30.287  - error: javascript.0 (135)     |     property '_writableState' -> object with constructor 'WritableState'
    2022-03-13 19:33:30.287  - error: javascript.0 (135)     |     property 'afterWriteTickInfo' -> object with constructor 'Object'
    2022-03-13 19:33:30.287  - error: javascript.0 (135)     --- property 'stream' closes the circle
    2022-03-13 19:33:30.288  - error: javascript.0 (135)     at JSON.stringify (<anonymous>)
    2022-03-13 19:33:30.288  - error: javascript.0 (135)     at Object.subscribe (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1109:65)
    2022-03-13 19:33:30.288  - error: javascript.0 (135)     at _once (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1191:46)
    2022-03-13 19:33:30.288  - error: javascript.0 (135)     at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1199:47
    2022-03-13 19:33:30.288  - error: javascript.0 (135)     at new Promise (<anonymous>)
    2022-03-13 19:33:30.288  - error: javascript.0 (135)     at once (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1199:24)
    2022-03-13 19:33:30.288  - error: javascript.0 (135)     at Send_mesage_via_TCP (script.js.common.Lyngdorf.Fernbedienung:155:24)
    2022-03-13 19:33:30.288  - error: javascript.0 (135)     at Object.<anonymous> (script.js.common.Lyngdorf.Fernbedienung:39:11)
    2022-03-13 19:33:30.288  - error: javascript.0 (135)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1082:38)
    2022-03-13 19:33:30.288  - error: javascript.0 (135)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
    2022-03-13 19:33:30.288  - error: javascript.0 (135)     at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5909:56)
    2022-03-13 19:33:30.288  - error: javascript.0 (135)     at processImmediate (internal/timers.js:464:21)
    Ich kann es nicht mit Gewissheit sagen. Ich denke aber, dass Fehler erstmalig mit dem Update auf js-controller 4 aufgetreten ist. Sicher bin ich aber nicht.
    Der Fehler im Log wird mit jedem Lauf des Skripts geschrieben. Hat jemand eine Idee?
    Ergänzung: Ich habe noch etwas getestet und festgestellt, dass die Fehlermeldung mit der "verbose" Option im Skript Editor im Zusammenhang steht. Ist diese aktiviert, erscheinen die Fehler im Protokoll.
    Danke und Grüße
    Michael
    SokomotoS OliverIOO 2 Antworten Letzte Antwort
    • A abcklaus
      Hardwaresystem: NUC
      Festplattenart: HDD
      Image genutzt: Nein
      let socketClient;
      port = 84;
      // PowerON
      // PowerOFF
      // Vol+
      // Vol-
              // On disconnect
          // Send the message
      Danke und Grüße
      Michael
      SokomotoS Offline
      SokomotoS Offline
      Sokomoto
      @abcklaus sagte in Skript: TypeError: Converting circular structure to JSON:
      Die Option verbose, erweitert nur die Log Ausgabe. Ich denke der meckert über die doppelte VAR Deklaration.
      Einmal am Anfang:
      var host, port, message;  // Die VAR message ist hier überflüssig
      und bei :
      Das sind unterschiedliche Variablen auch wenn sie gleich heißen.
      Du kannst das auch so schreiben:
      'use strict';
      let socketClient;
      let host = '10.10.21.14';
      let port = 84;
      // PowerON
      on({id: 'fakeroku.0.lyngdorf.keys.Select', val: true}, async function (obj) {
          await Send_mesage_via_TCP('!POWERONMAIN\r');
      // PowerOFF
      on({id: 'fakeroku.0.lyngdorf.keys.Home', val: true}, async function (obj) {
          await Send_mesage_via_TCP('!POWEROFFMAIN\r');
      // Vol+
      on({id: 'fakeroku.0.lyngdorf.keys.Up', val: true}, async function (obj) {
          await Send_mesage_via_TCP('!VOL+\r!VOL+\r');
      // Vol-
      on({id: 'fakeroku.0.lyngdorf.keys.Down', val: true}, async function (obj) {
          await Send_mesage_via_TCP('!VOL-\r!VOL-\r');
      async function Send_mesage_via_TCP(message) {
              const net = require('net');
              // On disconnect
          // Send the message
      tschuess
      • A abcklaus
        Hardwaresystem: NUC
        Festplattenart: HDD
        Image genutzt: Nein
        let socketClient;
        port = 84;
        // PowerON
        // PowerOFF
        // Vol+
        // Vol-
                // On disconnect
            // Send the message
        Danke und Grüße
        Michael
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        Also meiner Meinung nach liegt es nicht an dem was @Sokomoto schreibt.
        Gemäß Stack trace passiert der Fehler bei der Verarbeitung der Rückmeldung per once (Zeile 12 des logs).
        Die Rückmeldung wird dann per JSON.stringify (Zeile 7) versucht in einen String umzuwandeln.
        Allerdings scheint das ein Objekt zu sein, welches auf sich selber verweist und daher nicht umgewandelt werden kann.
        Interessant wäre es, was da enthalten ist.
        Evtl könntest du die Rückmeldung mal in einen Buffer speichern und da mal reinschauen. Buffer sind meist ein Array mit 8bit Werten, die den jeweiligen zeichencode darstellen. etwas aufpassen muss man bei utf8 kodierten Zeichenketten
        die net-Bibliothek kann die daten als string und als Buffer zurückgeben
        https://nodejs.org/api/buffer.html
        Meine Adapter und Widgets
        Links im Profil
