  4. [Gelöst] Eusec: Fehlermeldung(en)
    6.0k
eusec
3 Beiträge 2 Kommentatoren 271 Aufrufe 1 Beobachtet
  • qqolliQ Offline
    qqolliQ Offline
    qqolli
    schrieb am zuletzt editiert von qqolli
    bekomme seit ein paar Tagen die folgende Fehlermeldung (Adapter: 0.8.5). Die in dem Adapter eingetragenen Zugangsdaten stimmen und ich kann mich auch auf der Webseite anmelden:
    eusec.0
    2022-03-04 09:33:34.830	info	Push notification connection closed
    eusec.0
    2022-03-04 09:33:34.829	error	Status return code not 200 [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:33:34.827	error	Status return code 401, invalidate token [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:33:34.740	error	Status return code not 200 [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:33:34.739	error	Status return code 401, invalidate token [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:33:29.661	info	Push notification connection closed
    eusec.0
    2022-03-04 09:33:29.659	error	Status return code not 200 [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:33:29.656	error	Status return code 401, invalidate token [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:33:29.579	error	Status return code not 200 [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:33:29.578	error	Status return code 401, invalidate token [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:33:29.517	info	Push notification connection closed
    eusec.0
    2022-03-04 09:33:29.275	info	No devices found.
    eusec.0
    2022-03-04 09:33:29.275	error	Status return code not 200 [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:33:29.273	error	Status return code 401, invalidate token [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:33:29.198	info	No stations found.
    eusec.0
    2022-03-04 09:33:29.197	error	Status return code not 200 [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:33:29.195	error	Status return code 401, invalidate token [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:33:29.072	info	No houses found.
    eusec.0
    2022-03-04 09:33:29.071	error	Status return code not 200 [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:33:29.070	error	Status return code 401, invalidate token [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:33:28.996	error	Status return code not 200 [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:33:28.994	error	Status return code 401, invalidate token [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:33:28.916	error	Status return code not 200 [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:33:28.915	error	Status return code 401, invalidate token [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:33:28.762	error	Status return code not 200 [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:33:28.760	error	Status return code 401, invalidate token [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:33:28.679	error	Status return code not 200 [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:33:28.676	error	Status return code 401, invalidate token [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:33:26.284	info	starting. Version 0.8.5 in /opt/iobroker/node_modules/iobroker.eusec, node: v14.19.0, js-controller: 4.0.15
    eusec.0
    2022-03-04 09:33:14.931	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    eusec.0
    2022-03-04 09:33:14.929	info	terminating
    eusec.0
    2022-03-04 09:33:14.928	info	Push notification connection closed
    eusec.0
    2022-03-04 09:33:14.921	info	Got terminate signal TERMINATE_YOURSELF
    eusec.0
    2022-03-04 09:28:05.645	info	No devices found.
    eusec.0
    2022-03-04 09:28:05.644	error	Status return code not 200 [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:28:05.643	error	Status return code 401, invalidate token [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:28:05.570	info	No stations found.
    eusec.0
    2022-03-04 09:28:05.569	error	Status return code not 200 [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:28:05.567	error	Status return code 401, invalidate token [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:28:05.497	info	No houses found.
    eusec.0
    2022-03-04 09:28:05.497	error	Status return code not 200 [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:28:05.496	error	Status return code 401, invalidate token [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:28:05.424	error	Status return code not 200 [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:28:05.423	error	Status return code 401, invalidate token [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:28:05.351	error	Status return code not 200 [{"status":401,"statusText":"Unauthorized"}]
    eusec.0
    2022-03-04 09:28:05.350	error	Status return code 401, invalidate token [{"status":401,"statusText":"Unauthorized"}]
    JohGreJ 1 Antwort Letzte Antwort
    • qqolliQ qqolli
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      eusec.0
      JohGreJ Offline
      JohGreJ Offline
      JohGre
      @qqolli Hatte ich auch, hab dann die instanz gelöscht und wieder angelegt, dann funkts wieder.
      nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
      qqolliQ 1 Antwort Letzte Antwort
      • JohGreJ JohGre
        qqolliQ Offline
        qqolliQ Offline
        qqolli
        @johgre
        danke für den Tipp. Hat funktioniert :-)
