  4. [erledigt] smartmeter nach update "rot"
    6.0k
6 Beiträge 2 Kommentatoren 202 Aufrufe 1 Beobachtet
  • amg_666A Offline
    amg_666A Offline
    amg_666
    schrieb am zuletzt editiert von amg_666
    Nachdem ich den smartmeter Adapter auf 3.3.1 upgedatet habe, läuft er auf Fehler:
    host.iostrom
    	2022-02-21 09:40:26.347	info	Restart adapter system.adapter.smartmeter.0 because enabled
    host.iostrom
    	2022-02-21 09:40:26.345	error	instance system.adapter.smartmeter.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.iostrom
    	2022-02-21 09:40:26.344	error	Caught by controller[1]: at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9128:26
    host.iostrom
    	2022-02-21 09:40:26.343	error	Caught by controller[1]: at Adapter.emit (domain.js:475:12)
    host.iostrom
    	2022-02-21 09:40:26.341	error	Caught by controller[1]: at Adapter.emit (events.js:400:28)
    host.iostrom
    	2022-02-21 09:40:26.340	error	Caught by controller[1]: at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.smartmeter/smartmeter.js:169:13)
    host.iostrom
    	2022-02-21 09:40:26.339	error	Caught by controller[1]: at main (/opt/iobroker/node_modules/iobroker.smartmeter/smartmeter.js:365:34)
    host.iostrom
    	2022-02-21 09:40:26.336	error	Caught by controller[1]: at Object.init (/opt/iobroker/node_modules/smartmeter-obis/index.js:72:17)
    host.iostrom
    	2022-02-21 09:40:26.335	error	Caught by controller[1]: at SerialResponseTransport.init (/opt/iobroker/node_modules/smartmeter-obis/lib/transports/SerialResponseTransport.js:45:27)
    host.iostrom
    	2022-02-21 09:40:26.334	error	Caught by controller[1]: at new SerialPort (/opt/iobroker/node_modules/serialport/dist/serialport.js:13:9)
    host.iostrom
    	2022-02-21 09:40:26.333	error	Caught by controller[1]: at new SerialPortStream (/opt/iobroker/node_modules/@serialport/stream/dist/index.js:50:19)
    host.iostrom
    	2022-02-21 09:40:26.332	error	Caught by controller[1]: TypeError: "path" is not defined: undefined
    host.iostrom
    	2022-02-21 09:40:26.330	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    smartmeter.0
    	2022-02-21 09:40:25.351	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    smartmeter.0
    	2022-02-21 09:40:25.345	info	terminating
    smartmeter auf slave (raspi3b), master und slave haben node.js 14.19.0 und iob 4.0.15
    Downgrade zurück auf 3.2.1 funktioniert.
    • amg_666A amg_666
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      smartmeter.0
      smartmeter.0
      @amg_666 sagte in smartmeter nach update "rot":
      das ist aber Beta-testing!
      github:	3.3.1
      latest:	3.3.1 for 0 days
      stable:	3.2.1 for 9 months
      iob 4.0.15
      das auch!
      Downgrade zurück auf 3.3.1 funktioniert.
      das ist doch die selbe Version!??!
      amg_666A 2 Antworten Letzte Antwort
        github:	3.3.1
        iob 4.0.15
        das auch!
        amg_666A Offline
        amg_666A Offline
        amg_666
        @homoran sagte in smartmeter nach update "rot":
        vertippt :-), habs korrigiert
          github:	3.3.1
          iob 4.0.15
          das auch!
          amg_666A Offline
          amg_666A Offline
          amg_666
          JA, aber ich wollte es trotzdem posten, dass hier was bei mir nicht funktioniert. Oder besser github issue?
          • amg_666A amg_666
            bei Beta-testing immer auf Github, damit der Entwickler das sieht
              amg_666A Offline
              amg_666A Offline
              amg_666
              @homoran github issue erstellt
