  2. English
  3. ioBroker general
  4. adapter LOGs monitoring for errors with mail notifications
Geplant Angeheftet Gesperrt Verschoben ioBroker general
4 Beiträge 2 Kommentatoren 715 Aufrufe 2 Beobachtet
  • shaarkysS Offline
    shaarkysS Offline
    shaarkys
    I'm quite new with ioBroker and using is mostly for integrations with WeConnect, HaasSoohn, Easee, which I share then via MQTT to Homey. From time to time it may happen that one of the adapter is in error state - I tried to search but didn't find answer - is there any way how to monitor logs for errors or adapter states and send fatal errors via email ? I'm not looking for a way to script everything from scratch, rather I wonder I have overlooked some module with such functionality ?
    Can someone share some info / guidance ?
    What I have found so far is Log parser, which is mainly used for Visualisation and it's kind of overkill for the basic need...
    Much appreciated.
    Thank you.
    • shaarkysS shaarkys
      Much appreciated.
      Thank you.
      liv-in-skyL Offline
      liv-in-skyL Offline
      liv-in-sky
      @shaarkys
      I played around with this script - long ago
      maybe you can change this for your task
      if a special error or warning appears - the script sends a true to the datapoint and after 2 seconds the datapoint will be switched to false again
      const dpPrefix = "javascript."+ instance +".";
      //definition des dp's - BLOCK 1
      createState(dpPrefix + "OwnLogEntries.Meross",false, { name: 'Meross',  type: 'boolean', role:"switch", read:  true,  write: true,});
      createState(dpPrefix + "OwnLogEntries.Test",false, { name: 'Test',  type: 'boolean', role:"switch", read:  true,  write: true,});
      createState(dpPrefix + "OwnLogEntries.Warn515",false, { name: 'Test',  type: 'boolean', role:"switch", read:  true,  write: true,});
      createState(dpPrefix + "OwnLogEntries.Display7219Matrix",false, { name: 'Test',  type: 'boolean', role:"switch", read:  true,  write: true,});
      // für jeden definierten fehler der trigger - BLOCK 2
      function checkErrors(data) {
        //Alarm 1
       // hier mit regex um genauer zu filtern
          if(data.message.match(/ Error Test /g)){                               // hier angleichen fehler meldung
         setState(dpPrefix + "OwnLogEntries.Test",true);                         // hier angleichen dp
         setStateDelayed(dpPrefix + "OwnLogEntries.Test",false,2000);            // hier angleichen dp
         //Alarm2
         if(data.message.includes("instance system.adapter.meross.0 terminated with code 156")){       // hier angleichen fehler meldung
         setState(dpPrefix + "OwnLogEntries.Meross",true);                                             // hier angleichen dp
         setStateDelayed(dpPrefix + "OwnLogEntries.Meross",false,2000);                                // hier angleichen dp
      function checkWarnings(data) {
                 //Warn1
         if(data.message.includes("(515) BT already scanning!")){       // hier angleichen warning meldung
         setState(dpPrefix + "OwnLogEntries.Warn515",true);                                             // hier angleichen dp
         setStateDelayed(dpPrefix + "OwnLogEntries.Warn515",false,2000);                                // hier angleichen dp
      function checkWarnings2(data) {
            log("bin drin","warn")     //Warn1
         if(data.message.includes("7219Matrix")){       // hier angleichen warning meldung
         setState(dpPrefix + "OwnLogEntries.Display7219Matrix",true);                                             // hier angleichen dp
         setStateDelayed(dpPrefix + "OwnLogEntries.Display7219Matrix",false,2000);                                // hier angleichen dp
      onLog("error", checkErrors);
      onLog("warn", checkWarnings);
      onLog("warn", checkWarnings2);
      shaarkysS 1 Antwort Letzte Antwort
      • liv-in-skyL liv-in-sky
        @shaarkys
          //Alarm 1
           //Alarm2
                   //Warn1
        shaarkysS Offline
        shaarkysS Offline
        shaarkys
        @liv-in-sky thank you, I was worried that there is no adapter I can simply re-use. Will take a look, thank you very much for sharing!
          liv-in-skyL Offline
          liv-in-skyL Offline
          liv-in-sky
          @shaarkys
          if you have any questions - don't hesitate to ask
