  4. [erledigt] Restore unter Docker
    1.0k
    6.1k
4 Beiträge 2 Kommentatoren 389 Aufrufe 2 Beobachtet
  • O Offline
    O Offline
    ostseeskipper
    schrieb am zuletzt editiert von ostseeskipper
    Hallo Zusammen,
    habe die Backupfiles in den /opt/iobroker gelegt und wie es aussieht wird das auch erkannt.
    Aber warum wird der nicht fertig.
    Wen nich mich anmelde sind keine Adapter und Objekte da geschweige denn Vis.
    -------------------------     2022-02-04 23:37:15      -------------------------
    -----                 Welcome to your ioBroker-container!                  -----
    -----                    Startupscript is now running.                     -----
    -----                          Please be patient!                          -----
    -----                        Debugging information                         -----
    -----                                System                                -----
    -----                    arch:                x86_64                       -----
    -----                             Docker-Image                             -----
    -----                    image:               v6.0.0                       -----
    -----                    build:               2022-02-04T17:03:34+00:00    -----
    -----                               Versions                               -----
    -----                    node:                v14.19.0                     -----
    -----                    npm:                 6.14.16                      -----
    -----                                 ENV                                  -----
    -----                    SETGID:              1000                         -----
    -----                    SETUID:              1000                         -----
    -----                  Step 1 of 5: Preparing container                   -----
    Nothing to do here.
    -----             Step 2 of 5: Detecting ioBroker installation             -----
    IoBroker backup file detected in /opt/iobroker.
    Preparing restore...
    Done.
    Restoring ioBroker...
    Done.
    !!!!!                             IMPORTANT NOTE                             !!!!!
    !!!!!        The sartup script restored iobroker from a backup file.         !!!!!
    !!!!! Check /opt/iobroker/log/restore.log to see if restore was successful.  !!!!!
    !!!!! When ioBroker now starts it will reinstall all Adapters automatically. !!!!!
    !!!!!         This might be take a looooong time! Please be patient!         !!!!!
    !!!!!  You can view installation process by taking a look at ioBroker log.   !!!!!
    -----             Step 3 of 5: Checking ioBroker installation              -----
    (Re)Setting folder permissions (This might take a while! Please be patient!)...
    Done.
    Fixing "sudo-bug" by replacing sudo in iobroker with gosu...
    Done.
    Hostname in ioBroker does not match the hostname of this container.
    Updating hostname to  iob30...
    The host for instance "system.adapter.admin.0" was changed from "buildkitsandbox" to "iob30".
    The host for instance "system.adapter.discovery.0" was changed from "buildkitsandbox" to "iob30".
    The host for instance "system.adapter.backitup.0" was changed from "buildkitsandbox" to "iob30".
    Done.
    -----                Step 4 of 5: Applying special settings                -----
    Some adapters have special requirements/ settings which can be activated by the use of environment variables.
    For more information take a look at readme.md on Github!
    -----                    Step 5 of 5: ioBroker startup                     -----
    Starting ioBroker...
    host.iob30 check instance "system.adapter.admin.0" for host "iob30"
    host.iob30 check instance "system.adapter.discovery.0" for host "iob30"
    host.iob30 check instance "system.adapter.backitup.0" for host "iob30"
    object system.meta.uuid created: 3cd06e5f-f928-45e9-975f-e2359c672c32
    ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
    hash changed or no sources cached => force download of new sources
    • O Offline
      O Offline
      ostseeskipper
      In einem anderen Thread hatte ich gelesen das der Info Adapter störteAlso den gelöscht, ein Neues Backup und noch mal versucht.
      Wenn ich dann per Web auf den iobroker gehe. kommt die komplette Neuanmeldeprozedur und auch kein einziger Adapter aus dem Backup installiert.
      Im Log sieht das an step 5 nun so aus
      object system.meta.uuid created: d85b6382-c8b4-4d95-b357-8e6fdb772192
      Das hörte sich alles so gut an Backup in den leeren Ordner legen und /opt/iobroker Mounten.
      • X Offline
        X Offline
        xDGeForcexD
        Was steht den in der Restore Log unter: /opt/iobroker/log/restore.log?
        Hab erst letzte Woche ein Backup so zurück gespielt und bei mir ging es (es war jedoch das Docker Image 5.x).
        Der Info Adapter hatte bei mir keine Probleme gemacht.
        O 1 Antwort Letzte Antwort
        • X xDGeForcexD
          O Offline
          O Offline
          ostseeskipper
          @xdgeforcexd
          das kann ich leider nicht sagen. Hab alles gelöscht und per Hand über einen Transfer Ordner gemacht.
          Eben mal den Dockercontainer auszutauschen kann ich mir wohl abschminken ohne alles neu aufzusetzen.
          Liegt wohl daran das ich einiges per Hand über die Dockerkonsole installiert habe.
          Vor einem Jahr hatte ich von ioBroker noch nich mal was gehört und entsprechend einfach drauf los gelegt.
