  4. JeeLink flashen?
    5.6k
JeeLink flashen?
3 Beiträge 3 Kommentatoren 1.5k Aufrufe 1 Beobachtet
    Marcolotti
    habe heute meinen JeeLink 868 erhalten. Muss man den vorher noch flashen? Irgendwas hab ich mit F H E M gelesen.
    Im Log steht seit 5 Stunden:
    jeelink.0	2017-03-03 17:20:11.100	info	data received: A i1 g210 @ 868 MHz q1
    jeelink.0	2017-03-03 17:20:11.097	info	data received: Current configuration:
    jeelink.0	2017-03-03 17:20:11.090	info	data received: 123z - total power down, needs a reset to start up again
    jeelink.0	2017-03-03 17:20:11.079	info	data received: - 1: hex, 3: hex+ascii)
    jeelink.0	2017-03-03 17:20:11.073	info	data received: x - set reporting format (0: decimal, 2: decimal+ascii
    jeelink.0	2017-03-03 17:20:11.063	info	data received: q - set quiet mode (1 = don't report bad packets)
    jeelink.0	2017-03-03 17:20:11.052	info	data received: sent with its next ack. Group number becomes sticky
    jeelink.0	2017-03-03 17:20:11.040	info	data received: ,,p post semaphore for node , group to be
    jeelink.0	2017-03-03 17:20:11.029	info	data received: ...,m - add message string to ram, see p command
    jeelink.0	2017-03-03 17:20:11.019	info	data received: l - turn activity LED on PB1 on or off
    jeelink.0	2017-03-03 17:20:11.011	info	data received: n - set group as sticky. Group 0 only, see p command
    jeelink.0	2017-03-03 17:20:11.000	info	data received: ,n - remove group/node index number entry from eeprom
    jeelink.0	2017-03-03 17:20:10.988	info	data received: ... - Space character is a valid delimiter
    jeelink.0	2017-03-03 17:20:10.979	info	data received: ...,s - send data packet to node , no ack
    jeelink.0	2017-03-03 17:20:10.971	info	data received: if using group 0 then sticky group number is used
    jeelink.0	2017-03-03 17:20:10.961	info	data received: ...,a - send data packet to node , request ack
    jeelink.0	2017-03-03 17:20:10.949	info	data received: t - broadcast max-size test packet, request ack
    jeelink.0	2017-03-03 17:20:10.939	info	data received: c - set collect mode (advanced, normally 0)
    jeelink.0	2017-03-03 17:20:10.930	info	data received: g - set network group (RFM12 only allows 212, 0 = any)
    jeelink.0	2017-03-03 17:20:10.919	info	data received: 96..3903 is the range supported by the RFM12B
    jeelink.0	2017-03-03 17:20:10.913	info	data received: o - change frequency offset within the band (default 1600)
    jeelink.0	2017-03-03 17:20:10.908	info	data received: b - set MHz band (4 = 433, 8 = 868, 9 = 915)
    jeelink.0	2017-03-03 17:20:10.894	info	data received: i - set node ID (standard node ids are 1..30)
    jeelink.0	2017-03-03 17:20:10.894	info	data received: Available commands:
    jeelink.0	2017-03-03 17:20:10.892	info	data received:
    jeelink.0	2017-03-03 17:20:10.874	info	data received: [RF12demo.13] A i1 g210 @ 868 MHz q1
    jeelink.0	2017-03-03 17:20:10.858	info	data received:
    jeelink.0	2017-03-03 17:20:09.321	info	open
    jeelink.0	2017-03-03 17:20:09.282	info	RFM12B setting up object = LaCrosse 2
    jeelink.0	2017-03-03 17:20:09.280	info	RFM12B setting up object = emonTH1
    jeelink.0	2017-03-03 17:20:09.270	info	entered ready
    jeelink.0	2017-03-03 17:20:09.253	info	starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.jeelink, node: v6.10.0
    Gruß Marco
    CCU2-CuxD&Cul868MHz, 44xHM Geräte, 20xMAX Fenstersensoren.Acer Revo mit IoBroker, Tablet Captiva 9,7 SFHD. SMA SB2.5,STP7000TL20,SMA Energy Meter, Echo, Harmony, JeeLink868, Arduino 433MHz, MaxtoxCUL868,MilightEasyLED,Hue
      photographix
      Hallo Marcolotti,
      ja du musst den Jeelink vorher mit einer Software betanken. Aktuell ist nur ein Demo Sketch drauf. Wenn du Technoline DTH Sensoren abfragen willst musst du im Netz mal nach Lacrosse Sketch suchen. Im Homematic Forum gibt es auch Links zum Download (Link gerade nicht zur Hand). Je nach System brauchst du dann noch eine Software zum flashen des Jeelinks. Ich habe für den Mac die IDE für Arduino im Einsatz. Damit geht dies problemlos.
      ioBroker in Docker auf Raspberry PI 4 / 4GB
      CCU2 mit Strommessung, JeeLink v3c für TX29DHT-ITs, Maxtox's RF-Link 868 Mhz Arduino, Tradfri Lampen, Shellys
        simpixo
        Also ich habe meine von hier
        https://sourceforge.net/p/fhem/code/HEA … Reader.zip
        Einfach das ZIP Downloaden/ entpacken und auf den Jeelink draufpacken
        Adrian
