  2. English
  3. Scripting / Logic
  5. Enable DOM objects for javascript and typescript [gelöst]
    6.8k
javascript
8 Beiträge 3 Kommentatoren 1.4k Aufrufe 3 Beobachtet
  • E Offline
    Ethernet-Fellow
    schrieb am zuletzt editiert von Ethernet-Fellow
    The simple type- and javascript statement
    document.getElementById('xxx')
    returns a syntax error: 'document' unknown.
    On Google I found that the DOM objects are not enabled by default in typescript.
    To enable it the typescript configuration file 'tsconfig.json' file must contain the line
    "lib": ["DOM", "ES2017"],
    to enable the DOM objects for typescript (and also for javascript).
    I inserted that line in /opt/iobroker/node_modules/@iobroker/plugin-base/tsconfig.json
    without success. On my Raspi there are about 20 more such file.
    So my question, does anyone know how to enable the DOM objects for type- and javascript in iobroker.
    Thanks a lot
    • Jey CeeJ Online
      Jey CeeJ Online
      Jey Cee
      That doesn't make sense.
      DOM objects are only available on web pages, ioBroker is complete server side based and uses nodejs.
      So it useless there.
      If you wan't this feature anyway you have to include a third party module.
      Persönlicher Support
      Spenden -> paypal.me/J3YC33
      • E Offline
        Ethernet-Fellow
        Thanks Jey Cee,
        I didn't find an editable table. So I tried to implement it by Typescript.
        • E Ethernet-Fellow
          Thanks a lot
          liv-in-skyL Offline
          liv-in-skyL Offline
          liv-in-sky
          @ethernet-fellow the DOM elements are only available in the vis.
          to use it you have to write scripts in the vis editor or in the e.g. html standard widget
          do I misunderstand your question ?
          what you want to do
          • E Offline
            Ethernet-Fellow
            Hi liv-in-sky,
            I tried to make a table in VIS using HTML and typescript, but the typescript does not know DOM elements.
            • E Ethernet-Fellow
              Hi liv-in-sky,
              liv-in-skyL Offline
              liv-in-skyL Offline
              liv-in-sky
              @ethernet-fellow I only use javascript - it is working
              example: a script which builds the html und jquery - in the vis you have to use the binding for the datapoint
              https://forum.iobroker.net/topic/51217/html-tabelle-für-zigbee-devices-vis-übersicht
              or this exampleis in the script-tab in the vis-editor:
              https://forum.iobroker.net/topic/48663/howto-skripte-im-vis-editor-mit-jquery
              • E Offline
                Ethernet-Fellow
                Thanks a lot liv-in-sky,
                that's what I missed.
                • E Ethernet-Fellow
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  liv-in-sky
                  @ethernet-fellow
                  you're welcome
                  by the way - for example : fast tables for vis:
                  https://forum.iobroker.net/topic/48130/howto-schnell-erstellte-html-tabelle-für-vis
