  4. Erledigt: TUYA Adapter ist gelb
    6.0k
3 Beiträge 2 Kommentatoren 356 Aufrufe 2 Beobachtet
    michihorn
    schrieb am zuletzt editiert von michihorn
    Hallo nach Neuinstallation wird der Tuya 3.6.14 nicht grün
    Anbei der Log:
     close	Zeit
    debug
    Meldung
    tuya.0	2022-01-15 00:20:15.872	info	(8968) Listen for encrypted local Tuya devices on port 6667
    tuya.0	2022-01-15 00:20:15.870	info	(8968) Listen for local Tuya devices on port 6666
    tuya.0	2022-01-15 00:20:15.862	info	(8968) Existing devices initialized
    tuya.0	2022-01-15 00:20:15.861	info	(8968) 53231408a4cf12cb0e66: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:15.853	info	(8968) 348587205002916279b9: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:15.850	info	(8968) bf3962297fe4816323cxzk: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:15.848	info	(8968) bf93a9466706db6685mtff: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:15.847	info	(8968) 332670202462ab3b09cc: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:15.845	info	(8968) bf248fabbc07a96606wg3e: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:15.844	info	(8968) bf1db16bd4c7cc2132mbpx: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:15.842	info	(8968) 73103057e868e768284a: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:15.839	info	(8968) bfbf68d5d56d8cf0d8ri0j: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:15.818	info	(8968) bf9397e3c0910123cbc5vo: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:15.808	info	(8968) bf3fc4ada92398abf39bay: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:15.791	info	(8968) 26504734ecfabc4b5445: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:15.789	info	(8968) 88008560d8f15bd1d73c: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:15.788	info	(8968) 11622547bcddc28ede36: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:15.786	info	(8968) bf0babf38073437b8exhto: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:15.784	info	(8968) 88008560d8f15bd168a0: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:14.867	info	(8968) starting. Version 3.6.14 in C:/iobroker/SmartHome/node_modules/iobroker.tuya, node: v14.18.2, js-controller: 3.3.22
    tuya.0	2022-01-15 00:20:05.474	info	(8880) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    tuya.0	2022-01-15 00:20:05.468	info	(8880) terminating
    tuya.0	2022-01-15 00:20:03.379	info	(8880) Got terminate signal TERMINATE_YOURSELF
    tuya.0	2022-01-15 00:20:02.911	info	(8880) Listen for encrypted local Tuya devices on port 6667
    tuya.0	2022-01-15 00:20:02.910	info	(8880) Listen for local Tuya devices on port 6666
    tuya.0	2022-01-15 00:20:02.900	info	(8880) Existing devices initialized
    tuya.0	2022-01-15 00:20:02.899	info	(8880) bf3962297fe4816323cxzk: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:02.877	info	(8880) 26504734ecfabc4b5445: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:02.875	info	(8880) 348587205002916279b9: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:02.874	info	(8880) bf93a9466706db6685mtff: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:02.872	info	(8880) bf9397e3c0910123cbc5vo: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:02.871	info	(8880) 73103057e868e768284a: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:02.869	info	(8880) 88008560d8f15bd168a0: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:02.864	info	(8880) bfbf68d5d56d8cf0d8ri0j: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:02.862	info	(8880) bf248fabbc07a96606wg3e: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:02.852	info	(8880) 53231408a4cf12cb0e66: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:02.850	info	(8880) bf3fc4ada92398abf39bay: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:02.848	info	(8880) 332670202462ab3b09cc: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:02.842	info	(8880) bf0babf38073437b8exhto: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:02.836	info	(8880) bf1db16bd4c7cc2132mbpx: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:02.830	info	(8880) 88008560d8f15bd1d73c: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:02.828	info	(8880) 11622547bcddc28ede36: None of the discovered devices matches :-(
    tuya.0	2022-01-15 00:20:02.452	info	(8880) Got terminate signal TERMINATE_YOURSELF
    tuya.0	2022-01-15 00:20:02.004	info	(8880) starting. Version 3.6.14 in C:/iobroker/SmartHome/node_modules/iobroker.tuya, node: v14.18.2, js-controller: 3.3.22
    Es sind also alle Geräte übertragen worden, wo kann ich die Listening Ports überprüfen?Ich brauche mal einen Tip
    Michael
    K 1 Antwort Letzte Antwort
    • M michihorn
      Anbei der Log:
       close	Zeit
      debug
      Meldung
      Michael
      kla960
      @michihorn was hast du denn verändert?
      • K kla960
        michihorn
        @kla960 Hat sich erledigt, die Anfrage war letzten Monat.
        Habe alle Aktoren mit Proxy neu verheiratet, danach lief es wieder
