  4. Adapter Time-Switch / Error beim Astrotimer
    6.3k
1 Beiträge 1 Kommentatoren 266 Aufrufe 1 Beobachtet
  • webwalker2001W Offline
    webwalker2001
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi4
    Arbeitsspeicher: 4GB
    Festplattenart: SSD
    Betriebssystem: Ubuntu
    Node-Version: 12.22.8
    Nodejs-Version: 12.22.8
    Admin-Version: 5.2.3
    NPM-Version: 6.14.15
    Installationsart: Skript
    ich bekomme sporatisch folgende Fehlermeldung:
    time-switch.0 2021-12-25 02:00:33.168	info	starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.time-switch, node: v12.22.8, js-controller: 3.3.22
    host.iobroker 2021-12-25 02:00:00.772	error	instance system.adapter.time-switch.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    time-switch.0 2021-12-25 02:00:00.103	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    time-switch.0 2021-12-25 02:00:00.102	info	terminating
    time-switch.0 2021-12-25 02:00:00.100	info	cleaning everything up...
    time-switch.0 2021-12-25 02:00:00.038	error	Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:0, hour=16, minute=30, weekdays=[4]} is not registered.
    time-switch.0 2021-12-25 02:00:00.037	error	Error: Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:0, hour=16, minute=30, weekdays=[4]} is not registered. at TimeTriggerScheduler.unregister (/opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/TimeTriggerScheduler.js:34:19) at /opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/AstroTriggerScheduler.js:25:73 at Array.forEach (<anonymous>) at Object.execute (/opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/AstroTriggerScheduler.js:25:32) at Job.job (/opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/TimeTriggerScheduler.js:22:33) at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:175:17) at /opt/iobroker/node_modules/node-schedule/lib/schedule.js:555:26 at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:512:7) at listOnTimeout (internal/timers.js:554:17) at processTimers (internal/timers.js:497:7)
    time-switch.0 2021-12-25 02:00:00.029	error	uncaught exception: Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:0, hour=16, minute=30, weekdays=[4]} is not registered.
    Wenn ich den Adapter neu starte kommt aber kein Fehler.
    Ist das ein Bug oder hab ich was falsch eingestellt?
    Webwalker2001
