  4. (gelöst)Zigbee-Adapter bleibt Gelb Error herdsman Start
    5.8k
41 Beiträge 6 Kommentatoren 12.8k Aufrufe 4 Beobachtet
    arnold
    schrieb am zuletzt editiert von arnold
    laufende System von vor 2 Wochen .img auf die SD geschrieben
    zigbee.0
    2021-11-25 21:23:23.864 error Error herdsman start
    zigbee.0
    2021-11-25 21:23:23.863 error Failed to start Zigbee
    zigbee.0
    2021-11-25 21:23:23.862 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0
    2021-11-25 21:23:15.787 error getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
    zigbee.0
    2021-11-25 21:23:08.554 error Error herdsman start
    zigbee.0
    2021-11-25 21:23:08.554 error Failed to start Zigbee
    zigbee.0
    2021-11-25 21:23:08.553 error Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    zigbee.0
    2021-11-25 21:22:27.648 error Serial port not selected! Go to settings page.
    host.raspberrypi4-iob
    2021-11-25 21:22:24.434 error instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2021-11-25 21:21:54.006 error instance system.adapter.zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    zigbee.0
    2021-11-25 21:21:52.932 error zigbee.0 already running
    zigbee.0
    2021-11-25 21:15:11.119 error Error herdsman start
    zigbee.0
    2021-11-25 21:15:11.119 error Failed to start Zigbee
    zigbee.0
    2021-11-25 21:15:11.118 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    stockmarket.0
    2021-11-25 21:15:02.381 error JSON Object is wrong
    stockmarket.0
    2021-11-25 21:15:02.344 error JSON Object is wrong
    stockmarket.0
    2021-11-25 21:15:02.163 error JSON Object is wrong
    stockmarket.0
    2021-11-25 21:15:02.152 error JSON Object is wrong
    zigbee.0
    2021-11-25 21:14:55.630 error Error herdsman start
    zigbee.0
    2021-11-25 21:14:55.630 error Failed to start Zigbee
    zigbee.0
    2021-11-25 21:14:55.629 error Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    • A arnold
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      stockmarket.0
      stockmarket.0
      stockmarket.0
      stockmarket.0
      zigbee.0
      zigbee.0
      zigbee.0
      @arnold
      A 1 Antwort Letzte Antwort
        @arnold
        arnold
        @thomas-braun said in Zigbee-Adapter bleibt Gelb Error herdsman start:
        was ich nicht verstehe es ist 'sichere -img von vor 2 wochen . (hat alles funktioniert )
        • A arnold
          @arnold
          Keine Ahnung warum man ein Image sichert. Jedenfalls fehlt der Eintrag zum com-port.
            @arnold
            arnold
            COM-Anschlussname wahr bei mir immer Leer
            (früher hatte ich da stehen ;
            /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001936DCEE-if00 )
            pi@raspberrypi4-iob:~ $ ls -la /dev/serial/by-id
            insgesamt 0
            drwxr-xr-x 2 root root 60 Nov 25 21:32 .
            drwxr-xr-x 4 root root 80 Nov 25 21:32 ..
            lrwxrwxrwx 1 root root 13 Nov 25 21:32 usb-Texas_Instruments_TI_CC2531_USB_CDC__        _0X00124B001936DCEE-if00 -> ../../ttyACM0
            • A arnold
              insgesamt 0
              @arnold
              Dann trag den Link auf das Gerät wieder ein. Woher soll die Instanz denn sonst wissen wo die Daten herkommen?
                @arnold
                arnold
                in der com- Anschlussname habe ich wieder eingefügt
                adapter neu gestartet
                sudo reboot
                keine Besserung
                • A arnold
                  sudo reboot
                  keine Besserung
                  @arnold
                  Doch, die Meldung
                  dürfte jetzt weg sein. Das ist doch eine Verbesserung.
                  Zum Rest kann man mangels Informationen nix sagen. Log File nochmal posten.
                    @arnold
                    Doch, die Meldung
                    arnold
                    2021-11-25 23:34:45.895  - error: zigbee.0 (10417) zigbee.0 already running
                    2021-11-25 23:34:45.898  - warn: zigbee.0 (10417) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2021-11-25 23:34:46.724  - error: host.raspberrypi4-iob instance system.adapter.zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2021-11-25 23:34:46.725  - info: host.raspberrypi4-iob Restart adapter system.adapter.zigbee.0 because enabled
                    • A arnold
                      @arnold
                      Der läuft offenbar ja schon.
                        @arnold
                        arnold
                        ja eben
                        aber immer noch gelb
                        und keine geräte , wenn ich pairing starte
                        2021-11-25 23:35:16.758  - info: host.raspberrypi4-iob instance system.adapter.z        igbee.0 started with pid 11387
                        2021-11-25 23:35:18.165  - error: host.raspberrypi4-iob instance system.adapter.        zigbee.0 terminated by request of the instance itself and will not be restarted,        before user restarts it.
                        2021-11-25 23:35:18.166  - info: host.raspberrypi4-iob Do not restart adapter sy        stem.adapter.zigbee.0 because desired by instance
                        2021-11-25 23:35:20.147  - info: zigbee.0 (11387) starting. Version 1.6.3 in /op        t/iobroker/node_modules/iobroker.zigbee, node: v12.22.7, js-controller: 3.3.20
                        2021-11-25 23:35:20.261  - info: zigbee.0 (11387) Starting Zigbee  npm ...
                        2021-11-25 23:35:20.716  - info: zigbee.0 (11387) Installed Version: iobroker.zi        gbee@1.6.3
                        • A arnold
                          ja eben
                          @arnold
                          Ist der Port wieder weg?
                            @arnold
                            arnold
                            nein
                            • A arnold
                              nein
                              @arnold
                              Die erweiterte PAN-Id würde ich auch auf eine 16stellige Hex-Zahl ändern.
                                tom_33
                                Hallo Miteinander!
                                Ich kämpfe seit einer Woche mit demselben Problem. (Serial Port). Die Screenshots von arnold gleichen sich dem meinen. Ich bin mit meinem Raspi 4 8GB sogar von Buster auf Bullseye (raspios-bullseye-armhf-lite) gewechselt und habe über den Backup Adapter alles wiederherstellen können. Nodejs, Node (14.8.2) und npm (6.14.15) Versionen sind alle so wie sie sein müssen. Der ZigbeeDongle hat die Firmware vom Juni 2019 (CC2531). Zur Zeit ist die Adapterversion 1.5.6 installiert.
                                Weiters habe ich den Tipp von arteck (https://forum.iobroker.net/topic/49874/zigbee-startet-nicht-mehr/12?_=1639222982592) versucht.
                                Nun möchte ich bei Thomas Braun nachfragen, welche 16 stellige PAN-Id einzurichten ist?
                                Muss die Firmware vom Dongle mit einem Update versorgt werden?
                                Was man bei arnold nicht sieht, ist der Transportschlüssel. Spielt dieser eine Rolle?
                                Ich habe vom frisch aufgesetztem IOBroker ein Image gemacht, mit welchem ich immer wieder an den Start gehen kann.
                                Für eure Hilfe immer dankbar
                                tom
                                • T tom_33
                                  Hallo Miteinander!
                                  tom
                                  @tom_33 sagte in Zigbee-Adapter bleibt Gelb Error herdsman start:
                                  Die steht ggf. im Log drin.
                                  Ansonsten eine ausdenken oder generieren lassen:
                                  https://www.browserling.com/tools/random-hex
                                  Im Log stehen evtl. auch noch andere Dinge drin. Solltest du mal reinschauen.
                                    tom_33
                                    Ein 16-stelliger HexCode wurde eingefügt und ein Update auf 1.6.6 gestartet.
                                    Leider bleibt die Instanz auf Gelb. Anbei der Log dazu, welcher mit "errors" und "warns" gespickt ist, aber mir leider nichts sagt. Da steh ich da wie der Ochs vorm Berg.
                                    2021-12-11 04:06:16.897 - info: host.raspberrypi instance system.adapter.broadlink2.0 scheduled normal terminated and will be restarted on schedule.
                                    2021-12-11 04:06:16.918 - info: host.raspberrypi Restart adapter system.adapter.broadlink2.0 because enabled
                                    2021-12-11 04:06:17.969 - info: host.raspberrypi instance system.adapter.broadlink2.0 started with pid 19993
                                    2021-12-11 07:55:58.599 - info: admin.0 (568) Adapter rating updated
                                    2021-12-11 07:56:39.099 - info: info.0 (998) Reading/updating systemdata.
                                    2021-12-11 07:56:39.658 - info: info.0 (998) cpu Temp res = {"main":62.809,"cores":[],"max":62.809,"socket":[],"chipset":null}
                                    2021-12-11 08:49:42.693 - warn: sonoff.0 (876) Old client BA_Markise_E with secret 1639119391107_4251 sends pingreq. Ignore! Actual secret is 1639208981764_4191
                                    2021-12-11 12:40:07.364 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                    2021-12-11 13:16:31.207 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                                    2021-12-11 13:16:31.233 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                                    2021-12-11 13:16:31.229 - info: zigbee.0 (1958) Got terminate signal TERMINATE_YOURSELF
                                    2021-12-11 13:16:31.251 - info: zigbee.0 (1958) cleaned everything up...
                                    2021-12-11 13:16:31.256 - info: zigbee.0 (1958) Zigbee: disabling joining new devices.
                                    2021-12-11 13:16:31.631 - info: zigbee.0 (1958) terminating
                                    2021-12-11 13:16:31.632 - info: zigbee.0 (1958) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2021-12-11 13:16:32.331 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2021-12-11 13:16:34.306 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 11231
                                    2021-12-11 13:16:36.839 - info: zigbee.0 (11231) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.18.2, js-controller: 3.3.21
                                    2021-12-11 13:16:36.950 - info: zigbee.0 (11231) Starting Zigbee npm ...
                                    2021-12-11 13:16:37.206 - info: zigbee.0 (11231) Installed Version: iobroker.zigbee@1.5.6
                                    2021-12-11 13:16:45.216 - info: zigbee.0 (11231) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":0,"maintrel":0,"revision":""}}
                                    2021-12-11 13:16:45.222 - info: zigbee.0 (11231) Disable LED
                                    2021-12-11 13:16:45.228 - info: zigbee.0 (11231) --> transmitPower : high
                                    2021-12-11 13:16:45.237 - info: zigbee.0 (11231) Currently 23 devices are joined:
                                    2021-12-11 13:16:45.308 - info: zigbee.0 (11231) 0x00158d0004a07b41 (addr 17157): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                                    2021-12-11 13:16:45.312 - info: zigbee.0 (11231) 0x00158d00024e2f3a (addr 47768): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                    2021-12-11 13:16:45.313 - info: zigbee.0 (11231) 0x00158d000252be01 (addr 40408): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                    2021-12-11 13:16:45.316 - info: zigbee.0 (11231) 0x000b57fffe915c30 (addr 12211): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
                                    2021-12-11 13:16:45.317 - info: zigbee.0 (11231) 0x04cf8cdf3c7c87f9 (addr 20559): WXCJKG12LM - Xiaomi Aqara Opple switch 2 bands (EndDevice)
                                    2021-12-11 13:16:45.319 - info: zigbee.0 (11231) 0x086bd7fffe2e72fc (addr 35850): E1603/E1702 - IKEA TRADFRI control outlet (Router)
                                    2021-12-11 13:16:45.320 - info: zigbee.0 (11231) 0x00158d00025d8c22 (addr 13309): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                    2021-12-11 13:16:45.321 - info: zigbee.0 (11231) 0x00158d00025ed89f (addr 19230): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                    2021-12-11 13:16:45.323 - info: zigbee.0 (11231) 0x00158d0002e6b62d (addr 16784): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                    2021-12-11 13:16:45.324 - info: zigbee.0 (11231) 0x00158d0002e9e490 (addr 51157): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                    2021-12-11 13:16:45.325 - info: zigbee.0 (11231) 0x00158d000215a945 (addr 22209): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
                                    2021-12-11 13:16:45.326 - info: zigbee.0 (11231) 0x00158d000205977d (addr 43801): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
                                    2021-12-11 13:16:45.327 - info: zigbee.0 (11231) 0x086bd7fffecba104 (addr 6243): RH3040 - TuYa PIR sensor (EndDevice)
                                    2021-12-11 13:16:45.328 - info: zigbee.0 (11231) 0x00158d0002c8f313 (addr 3758): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                    2021-12-11 13:16:45.330 - info: zigbee.0 (11231) 0x680ae2fffe3fca6c (addr 64757): E1603/E1702 - IKEA TRADFRI control outlet (Router)
                                    2021-12-11 13:16:45.331 - info: zigbee.0 (11231) 0x84182600000ef4a4 (addr 13408): AB3257001NJ - OSRAM Smart+ plug (Router)
                                    2021-12-11 13:16:45.332 - info: zigbee.0 (11231) 0x00158d0002041225 (addr 54978): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
                                    2021-12-11 13:16:45.333 - info: zigbee.0 (11231) 0x00158d0002b56d7c (addr 1273): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                    2021-12-11 13:16:45.334 - info: zigbee.0 (11231) 0x00158d0002e20b9f (addr 13014): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                    2021-12-11 13:16:45.335 - info: zigbee.0 (11231) 0x00158d0002d46629 (addr 61601): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                    2021-12-11 13:16:45.337 - info: zigbee.0 (11231) 0x000d6ffffec25343 (addr 9341): E1603/E1702 - IKEA TRADFRI control outlet (Router)
                                    2021-12-11 13:16:45.338 - info: zigbee.0 (11231) 0x7cb03eaa00ad39d5 (addr 19720): AB3257001NJ - OSRAM Smart+ plug (Router)
                                    2021-12-11 13:16:45.339 - info: zigbee.0 (11231) 0x00158d000424150c (addr 24225): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
                                    2021-12-11 13:16:45.340 - info: zigbee.0 (11231) Zigbee started
                                    2021-12-11 13:17:23.677 - info: host.raspberrypi iobroker upgrade zigbee@1.6.6
                                    2021-12-11 13:17:25.917 - info: host.raspberrypi iobroker Update zigbee from @1.5.6 to @1.6.6
                                    2021-12-11 13:17:25.930 - info: host.raspberrypi iobroker host.raspberrypi Adapter "system.adapter.zigbee.0" is stopped.
                                    2021-12-11 13:17:25.952 - info: host.raspberrypi "system.adapter.zigbee.0" disabled
                                    2021-12-11 13:17:25.953 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                                    2021-12-11 13:17:25.958 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                                    2021-12-11 13:17:25.959 - info: zigbee.0 (11231) Got terminate signal TERMINATE_YOURSELF
                                    2021-12-11 13:17:25.960 - info: zigbee.0 (11231) cleaned everything up...
                                    2021-12-11 13:17:25.964 - info: zigbee.0 (11231) Zigbee: disabling joining new devices.
                                    2021-12-11 13:17:26.369 - info: zigbee.0 (11231) terminating
                                    2021-12-11 13:17:26.370 - info: zigbee.0 (11231) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2021-12-11 13:17:26.601 - info: host.raspberrypi iobroker NPM version: 6.14.15
                                    2021-12-11 13:17:26.603 - info: host.raspberrypi iobroker npm install iobroker.zigbee@1.6.6 --loglevel error --prefix "/opt/iobroker" (System call)
                                    2021-12-11 13:17:26.950 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2021-12-11 13:19:17.840 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    2021-12-11 13:19:17.842 - info: host.raspberrypi iobroker ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 78 | uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                    2021-12-11 13:19:17.848 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    2021-12-11 13:19:17.850 - info: host.raspberrypi iobroker ../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 135 | uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                    2021-12-11 13:19:17.854 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    2021-12-11 13:19:17.856 - info: host.raspberrypi iobroker ../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 175 | uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                    2021-12-11 13:19:17.860 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    2021-12-11 13:19:17.862 - info: host.raspberrypi iobroker ../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 215 | uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                    2021-12-11 13:19:17.867 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    2021-12-11 13:19:17.869 - info: host.raspberrypi iobroker ../src/serialport.cpp:271:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 271 | uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                    2021-12-11 13:19:17.874 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    2021-12-11 13:19:17.875 - info: host.raspberrypi iobroker ../src/serialport.cpp:316:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 316 | uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                    2021-12-11 13:19:17.882 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    2021-12-11 13:19:17.883 - info: host.raspberrypi iobroker ../src/serialport.cpp:366:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 366 | uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                    2021-12-11 13:19:17.888 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    2021-12-11 13:19:17.890 - info: host.raspberrypi iobroker ../src/serialport.cpp:412:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 412 | uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                    2021-12-11 13:19:17.892 - info: host.raspberrypi iobroker ../src/serialport.cpp: At global scope:../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] 433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local& v8str)) { | ^
                                    2021-12-11 13:19:17.894 - info: host.raspberrypi iobroker ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] 452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) { | ^
                                    2021-12-11 13:19:17.897 - info: host.raspberrypi iobroker In file included from ../../../nan/nan.h:58,
                                    2021-12-11 13:19:17.898 - info: host.raspberrypi iobroker from ../src/./serialport.h:13, from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:787:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type] 787 | (node::addon_register_func) (regfunc), \ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:821:3: note: in expansion of macro ‘NODE_MODULE_X’ 821 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) | ^~~~~~~~~~~~~../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’ 486 | NODE_MODULE(serialport, init); | ^~~~~~~~~~~
                                    2021-12-11 13:19:21.872 - info: host.raspberrypi iobroker ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
                                    2021-12-11 13:19:21.874 - info: host.raspberrypi iobroker ../src/serialport_unix.cpp:179:82: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=] 179 | snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); | ^~../src/serialport_unix.cpp:179:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024 179 | snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); | ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                    2021-12-11 13:19:21.910 - info: host.raspberrypi iobroker ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
                                    2021-12-11 13:19:21.911 - info: host.raspberrypi iobroker ../src/serialport_unix.cpp:89:84: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=] 89 | snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); | ^~../src/serialport_unix.cpp:89:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024 89 | snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); | ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                    2021-12-11 13:19:28.823 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    2021-12-11 13:19:28.824 - info: host.raspberrypi iobroker ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 78 | uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                    2021-12-11 13:19:28.831 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    2021-12-11 13:19:28.832 - info: host.raspberrypi iobroker ../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 135 | uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                    2021-12-11 13:19:28.836 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    2021-12-11 13:19:28.837 - info: host.raspberrypi iobroker ../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 175 | uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                    2021-12-11 13:19:28.840 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    2021-12-11 13:19:28.842 - info: host.raspberrypi iobroker ../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 215 | uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                    2021-12-11 13:19:28.846 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    2021-12-11 13:19:28.848 - info: host.raspberrypi iobroker ../src/serialport.cpp:271:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 271 | uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                    2021-12-11 13:19:28.851 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    2021-12-11 13:19:28.853 - info: host.raspberrypi iobroker ../src/serialport.cpp:316:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 316 | uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                    2021-12-11 13:19:28.859 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    2021-12-11 13:19:28.861 - info: host.raspberrypi iobroker ../src/serialport.cpp:366:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 366 | uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                    2021-12-11 13:19:28.866 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    2021-12-11 13:19:28.868 - info: host.raspberrypi iobroker ../src/serialport.cpp:412:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 412 | uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                    2021-12-11 13:19:28.869 - info: host.raspberrypi iobroker ../src/serialport.cpp: At global scope:../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] 433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local& v8str)) { | ^
                                    2021-12-11 13:19:28.872 - info: host.raspberrypi iobroker ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
                                    2021-12-11 13:19:28.873 - info: host.raspberrypi iobroker 452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) { | ^
                                    2021-12-11 13:19:28.876 - info: host.raspberrypi iobroker In file included from ../../../nan/nan.h:58,
                                    2021-12-11 13:19:28.877 - info: host.raspberrypi iobroker from ../src/./serialport.h:13, from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:787:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type] 787 | (node::addon_register_func) (regfunc), \ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:821:3: note: in expansion of macro ‘NODE_MODULE_X’ 821 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) | ^~~~~~~~~~~~~../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’ 486 | NODE_MODULE(serialport, init); | ^~~~~~~~~~~
                                    2021-12-11 13:19:32.464 - info: host.raspberrypi iobroker ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
                                    2021-12-11 13:19:32.465 - info: host.raspberrypi iobroker ../src/serialport_unix.cpp:179:82: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=] 179 | snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); | ^~../src/serialport_unix.cpp:179:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024 179 | snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); | ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                    2021-12-11 13:19:32.502 - info: host.raspberrypi iobroker ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
                                    2021-12-11 13:19:32.503 - info: host.raspberrypi iobroker ../src/serialport_unix.cpp:89:84: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=] 89 | snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); | ^~../src/serialport_unix.cpp:89:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024 89 | snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); | ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                    2021-12-11 13:19:52.739 - info: host.raspberrypi iobroker Update "system.adapter.zigbee.0"
                                    2021-12-11 13:19:53.082 - info: host.raspberrypi iobroker upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
                                    2021-12-11 13:19:56.405 - info: host.raspberrypi iobroker upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_ht.png img/sensor_ht.png image/png
                                    2021-12-11 13:19:59.728 - info: host.raspberrypi iobroker upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/paulmann_rgbw_globe.png img/paulmann_rgbw_globe.png image/png
                                    2021-12-11 13:20:03.004 - info: host.raspberrypi iobroker upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lamp_01.png img/lamp_01.png image/png
                                    2021-12-11 13:20:06.170 - info: host.raspberrypi iobroker upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/group_6.png img/group_6.png image/png
                                    2021-12-11 13:20:06.852 - info: host.raspberrypi iobroker upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gledopto_gu10.png img/gledopto_gu10.png image/png
                                    2021-12-11 13:20:07.502 - info: host.raspberrypi iobroker upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/flair_viyu_e14_candle.png img/flair_viyu_e14_candle.png image/png
                                    2021-12-11 13:20:08.223 - info: host.raspberrypi iobroker upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/diy.png img/diy.png image/png
                                    2021-12-11 13:20:08.816 - info: host.raspberrypi iobroker upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/crts0111.PNG img/crts0111.PNG image/png
                                    2021-12-11 13:20:09.424 - info: host.raspberrypi iobroker upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/battery_v.png img/battery_v.png image/png
                                    2021-12-11 13:20:10.046 - info: host.raspberrypi iobroker upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZHS15.png img/ZHS15.png image/png
                                    2021-12-11 13:20:10.683 - info: host.raspberrypi iobroker upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Paulmann_50067.png img/Paulmann_50067.png image/png
                                    2021-12-11 13:20:11.333 - info: host.raspberrypi iobroker upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06104A.png img/HG06104A.png image/png
                                    2021-12-11 13:20:11.393 - info: host.raspberrypi iobroker upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
                                    2021-12-11 13:20:11.454 - info: host.raspberrypi iobroker upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
                                    2021-12-11 13:20:11.519 - info: host.raspberrypi iobroker upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_R8_8.png img/DIYRuZ_R8_8.png image/png
                                    2021-12-11 13:20:11.584 - info: host.raspberrypi iobroker upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Geiger.png img/DIYRuZ_Geiger.png image/png
                                    2021-12-11 13:20:11.648 - info: host.raspberrypi iobroker upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad_LeTV_8.png img/DIYRuZ_FreePad_LeTV_8.png image/png
                                    2021-12-11 13:20:11.714 - info: host.raspberrypi iobroker upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad.png img/DIYRuZ_FreePad.png image/png
                                    2021-12-11 13:20:11.783 - info: host.raspberrypi iobroker upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Flower.png img/DIYRuZ_Flower.png image/png
                                    2021-12-11 13:20:11.846 - info: host.raspberrypi iobroker upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_CO2.png img/DIYRuZ_CO2.png image/png
                                    2021-12-11 13:20:11.915 - info: host.raspberrypi iobroker upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
                                    2021-12-11 13:20:11.984 - info: host.raspberrypi iobroker upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
                                    2021-12-11 13:20:12.051 - info: host.raspberrypi iobroker upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
                                    2021-12-11 13:20:12.114 - info: host.raspberrypi iobroker upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS5.png img/BW-IS5.png image/png
                                    2021-12-11 13:20:12.179 - info: host.raspberrypi iobroker upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS3.png img/BW-IS3.png image/png
                                    2021-12-11 13:20:12.244 - info: host.raspberrypi iobroker upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
                                    2021-12-11 13:20:12.308 - info: host.raspberrypi iobroker upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
                                    2021-12-11 13:20:12.375 - info: host.raspberrypi iobroker upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
                                    2021-12-11 13:20:12.473 - info: host.raspberrypi iobroker upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
                                    2021-12-11 13:20:12.532 - info: host.raspberrypi iobroker upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/14147206L.png img/14147206L.png image/png
                                    2021-12-11 13:20:12.591 - info: host.raspberrypi iobroker upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
                                    2021-12-11 13:20:12.650 - info: host.raspberrypi iobroker upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                                    2021-12-11 13:20:12.708 - info: host.raspberrypi iobroker Adapter "zigbee" updated
                                    2021-12-11 13:20:12.713 - info: host.raspberrypi iobroker host.raspberrypi Adapter "system.adapter.zigbee.0" is started
                                    2021-12-11 13:20:12.730 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
                                    2021-12-11 13:20:12.804 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 17105
                                    2021-12-11 13:20:13.758 - info: host.raspberrypi iobroker exit 0
                                    2021-12-11 13:20:15.849 - info: zigbee.0 (17105) starting. Version 1.6.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.18.2, js-controller: 3.3.21
                                    2021-12-11 13:20:15.945 - info: zigbee.0 (17105) Starting Zigbee npm ...
                                    2021-12-11 13:20:16.370 - info: zigbee.0 (17105) Installed Version: iobroker.zigbee@1.6.6
                                    2021-12-11 13:20:28.630 - error: zigbee.0 (17105) Starting zigbee-herdsman problem : "SRSP - SYS - version after 6000ms"
                                    2021-12-11 13:20:28.632 - error: zigbee.0 (17105) Failed to start Zigbee
                                    2021-12-11 13:20:28.634 - error: zigbee.0 (17105) Error herdsman start
                                    2021-12-11 13:20:38.638 - info: zigbee.0 (17105) Try to reconnect. 1 attempts left
                                    2021-12-11 13:20:38.640 - info: zigbee.0 (17105) Starting Zigbee npm ...
                                    2021-12-11 13:20:38.692 - info: zigbee.0 (17105) Installed Version: iobroker.zigbee@1.6.6
                                    2021-12-11 13:20:38.906 - error: zigbee.0 (17105) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                    2021-12-11 13:20:38.906 - error: zigbee.0 (17105) Failed to start Zigbee
                                    2021-12-11 13:20:38.907 - error: zigbee.0 (17105) Error herdsman start
                                    IOBroker gestoppt und mit einem reboot gestartet.
                                    zigbee.0
                                    	2021-12-11 13:29:39.686	error	Error herdsman start
                                    zigbee.0
                                    	2021-12-11 13:29:39.686	error	Failed to start Zigbee
                                    zigbee.0
                                    	2021-12-11 13:29:39.685	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                    • T tom_33
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      @tom_33
                                      Das richtige Gerät über den dev-link aus /dev/serial/by-id angelegt?
                                      könnte aber auch ein Firmware-Thema sein. Welche ist da drauf?
                                        tom_33
                                        habe ich nie geändert
                                          @tom_33
                                          tom_33
                                          @thomas-braun sagte in Zigbee-Adapter bleibt Gelb Error herdsman start:
                                          @tom_33
                                          Ich habe ihn fix und fertig gekauft. Juni 2019
