  4. MQTT Broker/Client 2.4.0 kommunikation mit openHASP
    6.4k
1 Beiträge 1 Kommentatoren 444 Aufrufe 1 Beobachtet
  • Günter KönigsbergerG Offline
    Günter Königsberger
    schrieb am zuletzt editiert von Günter Königsberger
    If the payload is a json object containing a val property, iobroker uses the val property only as value of that object...
    This seems to be an issue of the iobroker.mqtt server: This piece of code handles the incoming messages. They parse the payload using a Fast solution, resulting in false positives. It is even mentioned in that code what the right solution is...
    Changing iobroker.mqtt\lib\server.js line 541 to ignore events fixes the issue:
                // Fast solution
                if (_message.val !== undefined && _message.event === undefined) {
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Raspberry 4
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte
    Betriebssystem: linux
    Node-Version: 10.x.x
    Nodejs-Version: 12.20.1
    NPM-Version: 6.14.10
    Installationsart: Skript
    Image genutzt: Ja
    Ort/Name der Imagedatei: Link
