  4. Javascript rot Error loader.js nach ioBroker Neustart
    6.4k
4 Beiträge 2 Kommentatoren 414 Aufrufe 2 Beobachtet
    TorbenNW
    Node.js
    v12.22.4 (Es gibt eine neuere Version: v12.22.6)
    NPM
    6.14.14
    Host
    Proxmox - Debian LXC
    Hallo Zusammen,
    nachdem ich mein ioBroker versehentlich in Proxmox heruntergefahren und neugestartet habe bekomme ich folgenden Fehler ausgeworfen. Vorher hat alles funktioniert. Eine neue Instanz bringt den gleichen Fehler.
    Kann mir evtl. jemand helfen das ganze wieder zu fixen?
    host.ioBrokerCT
    2021-09-09 22:29:56.479	error	Caught by controller[0]: }
    host.ioBrokerCT
    2021-09-09 22:29:56.479	error	Caught by controller[0]: ]
    host.ioBrokerCT
    2021-09-09 22:29:56.479	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
    host.ioBrokerCT
    2021-09-09 22:29:56.479	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/index.js',
    host.ioBrokerCT
    2021-09-09 22:29:56.478	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/server.js',
    host.ioBrokerCT
    2021-09-09 22:29:56.478	error	Caught by controller[0]: requireStack: [
    host.ioBrokerCT
    2021-09-09 22:29:56.478	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.ioBrokerCT
    2021-09-09 22:29:56.478	error	Caught by controller[0]: {
    host.ioBrokerCT
    2021-09-09 22:29:56.478	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
    host.ioBrokerCT
    2021-09-09 22:29:56.477	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
    host.ioBrokerCT
    2021-09-09 22:29:56.477	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.ioBrokerCT
    2021-09-09 22:29:56.477	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.ioBrokerCT
    2021-09-09 22:29:56.477	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.ioBrokerCT
    2021-09-09 22:29:56.477	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.ioBrokerCT
    2021-09-09 22:29:56.476	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
    host.ioBrokerCT
    2021-09-09 22:29:56.476	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.ioBrokerCT
    2021-09-09 22:29:56.476	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.ioBrokerCT
    2021-09-09 22:29:56.476	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.ioBrokerCT
    2021-09-09 22:29:56.475	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.ioBrokerCT
    2021-09-09 22:29:56.475	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.ioBrokerCT
    2021-09-09 22:29:56.475	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.ioBrokerCT
    2021-09-09 22:29:56.475	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:8:16)
    host.ioBrokerCT
    2021-09-09 22:29:56.475	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.ioBrokerCT
    2021-09-09 22:29:56.475	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.ioBrokerCT
    2021-09-09 22:29:56.474	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.ioBrokerCT
    2021-09-09 22:29:56.474	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.ioBrokerCT
    2021-09-09 22:29:56.474	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.ioBrokerCT
    2021-09-09 22:29:56.474	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.ioBrokerCT
    2021-09-09 22:29:56.474	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/server.js:4:10)
    host.ioBrokerCT
    2021-09-09 22:29:56.473	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.ioBrokerCT
    2021-09-09 22:29:56.473	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.ioBrokerCT
    2021-09-09 22:29:56.473	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
    host.ioBrokerCT
    2021-09-09 22:29:56.473	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
    host.ioBrokerCT
    2021-09-09 22:29:56.472	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
    host.ioBrokerCT
    2021-09-09 22:29:56.472	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/index.js
    host.ioBrokerCT
    2021-09-09 22:29:56.472	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/server.js
    host.ioBrokerCT
    2021-09-09 22:29:56.472	error	Caught by controller[0]: Require stack:
    host.ioBrokerCT
    2021-09-09 22:29:56.471	error	Caught by controller[0]: Error: Cannot find module 'typescript'
    host.ioBrokerCT
    2021-09-09 22:29:56.471	error	Caught by controller[0]: ^
    host.ioBrokerCT
    2021-09-09 22:29:56.469	error	Caught by controller[0]: throw err;
    host.ioBrokerCT
    2021-09-09 22:29:56.468	error	Caught by controller[0]: internal/modules/cjs/loader.js:818
    host.ioBrokerCT
    2021-09-09 22:29:56.208	info	instance system.adapter.javascript.0 started with pid 5920
    • T TorbenNW
      Node.js
      NPM
      6.14.14
      Host
      Hallo Zusammen,
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      host.ioBrokerCT
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      @torbennw sagte in Javascript rot Error loader.js nach ioBroker Neustart:
      https://forum.iobroker.net/topic/46983/gelöst-javascript-startet-nicht-mehr-nach-update/5?_=1631220370459
      • GlasfaserG Glasfaser
        TorbenNW
        @glasfaser
        Danke dir, google hat bei iobroker javascript typescript leider deinen verlinkten Thread nicht ausgespuckt.
        Thema kann geschlossen werden.
        • T TorbenNW
          @glasfaser
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          google hat bei iobroker ...... leider deinen verlinkten Thread nicht ausgespuckt.
          Warum Google , die Forumssuche funktioniert besser als Google ,
          inkl. der Suche innerhalb des Threads !
          Suche innerhalb des Threads :
          In User Einstellung aktivieren :
          STRG + F
          Das mußt du schon machen ...
          Den Titel ändern mit [gelöst]
          Im Startbeitrag gehen und bei den 3 Punkten kannst du es ändern
