  4. iobroker KNX Adapter -> KNX MDT IP Interface
    1.0k
    6.1k
1 Beiträge 1 Kommentatoren 339 Aufrufe 1 Beobachtet
  • H Offline
    hpgo
    ich habe mir unter OMV 5 einen iobroker Docker Container installiert leider hat dieser anscheinen d ein Problem mit dem KNX IP Interface zu kommunizieren.
    hier mein log:
    2021-09-01 20:40:45.238 - info: host.b56d08283ac5 "system.adapter.knx.0" disabled
    2021-09-01 20:40:45.239 - info: host.b56d08283ac5 stopInstance system.adapter.knx.0 (force=false, process=true)
    2021-09-01 20:40:45.252 - info: host.b56d08283ac5 stopInstance system.adapter.knx.0 send kill signal
    2021-09-01 20:40:45.253 - info: knx.0 (1897) Got terminate signal TERMINATE_YOURSELF
    2021-09-01 20:40:45.265 - info: knx.0 (1897) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_TUNNELLING_REQUEST(13) to STATE_NOT_CONNECTED(0).
    2021-09-01 20:40:45.269 - info: knx.0 (1897) terminating
    2021-09-01 20:40:45.271 - info: knx.0 (1897) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-09-01 20:40:45.280 - info: knx.0 (1897) STATE_NOT_CONNECTED : Stop connection : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-09-01 20:40:45.810 - info: host.b56d08283ac5 instance system.adapter.knx.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-09-01 20:40:46.386 - info: host.b56d08283ac5 "system.adapter.knx.0" enabled
    2021-09-01 20:40:46.425 - info: host.b56d08283ac5 instance system.adapter.knx.0 started with pid 1938
    2021-09-01 20:40:48.317 - info: knx.0 (1938) starting. Version 1.0.45 in /opt/iobroker/node_modules/iobroker.knx, node: v12.22.5, js-controller: 3.3.15
    2021-09-01 20:40:48.622 - info: knx.0 (1938) knx license is OK.
    2021-09-01 20:40:48.625 - info: knx.0 (1938) Connecting to knx GW: 192.168.178.21:3671 with phy. Adr: 1.0.251
    2021-09-01 20:40:48.636 - info: knx.0 (1938) Debuglevel: 1 2
    2021-09-01 20:40:48.642 - info: knx.0 (1938) Event : UDP - listening
    2021-09-01 20:40:48.648 - info: knx.0 (1938) Connected - local UDP Server listening on 172.17.0.6:35769
    2021-09-01 20:40:50.654 - info: knx.0 (1938) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_CONNECT_REQUEST(3) to STATE_NOT_CONNECTED(0).
    2021-09-01 20:40:52.654 - info: knx.0 (1938) Using UDP with local IP: 172.17.0.6
    2021-09-01 20:40:52.657 - info: knx.0 (1938) Event : UDP - listening
    2021-09-01 20:40:52.660 - info: knx.0 (1938) Connected - local UDP Server listening on 172.17.0.6:57868
    2021-09-01 20:40:54.665 - info: knx.0 (1938) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_CONNECT_REQUEST(3) to STATE_NOT_CONNECTED(0).
    2021-09-01 20:40:56.665 - info: knx.0 (1938) Using UDP with local IP: 172.17.0.6
    2021-09-01 20:40:56.668 - info: knx.0 (1938) Event : UDP - listening
    2021-09-01 20:40:56.670 - info: knx.0 (1938) Connected - local UDP Server listening on 172.17.0.6:40733
    2021-09-01 20:40:56.722 - info: knx.0 (1938) Value received on unknown GA : 2/4/4
    2021-09-01 20:40:56.726 - info: knx.0 (1938) Value received on unknown GA : 2/4/4
    2021-09-01 20:40:56.729 - info: knx.0 (1938) Value received on unknown GA : 2/4/4
    2021-09-01 20:40:57.602 - info: knx.0 (1938) Value received on unknown GA : 2/4/4
    2021-09-01 20:40:57.606 - info: knx.0 (1938) Value received on unknown GA : 2/4/4
    2021-09-01 20:40:57.609 - info: knx.0 (1938) Value received on unknown GA : 2/4/4
    Könnte mit dem Problem, welches auf dieser Seite beschrieben wird zusammenhängen.
    Ich bekomme den Container aber mit --net=host nicht gebaut, hat dazu wer eine Lösung?
    Lg Hp
