  4. Errors beim Das Wetter-Adapter
    6.3k
adaptererror log
3 Beiträge 3 Kommentatoren 710 Aufrufe 2 Beobachtet
  • O Online
    O Online
    Oli
    ich bekomme seit neusten für den Adapter "Das Wetter" folgende Fehlermeldungen im Log:
    2021-08-16 10:01:13.516	error	instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
    daswetter.0
    2021-08-16 10:01:13.476	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_4.Hour_5.pressure_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_4.Hour_5.pressure_value": Connection is closed.]
    daswetter.0
    2021-08-16 10:01:13.475	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_4.Hour_5.pressure_value": Connection is closed.
    daswetter.0
    2021-08-16 10:01:13.472	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_4.Hour_5.humidity_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_4.Hour_5.humidity_value": Connection is closed.]
    daswetter.0
    2021-08-16 10:01:13.471	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_4.Hour_5.humidity_value": Connection is closed.
    daswetter.0
    2021-08-16 10:01:13.468	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_4.Hour_5.rain_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_4.Hour_5.rain_value": Connection is closed.]
    daswetter.0
    2021-08-16 10:01:13.465	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_4.Hour_5.rain_value": Connection is closed.
    daswetter.0
    2021-08-16 10:01:13.463	error	exception in await insertIntoList [Error: DB closed]
    daswetter.0
    2021-08-16 10:01:13.461	warn	get state error: Connection is closed.
    daswetter.0
    2021-08-16 10:01:12.951	warn	Terminated (UNKNOWN_ERROR): Without reason
    daswetter.0
    2021-08-16 10:01:12.949	error	force terminate
    Datenpunkte sind vorhanden
    Instanz wurde schon mehrmals gestoppt und neu gestartet
    ioBroker wurde schon neu gestartet
    Weis jemand woran das liegen könnte?
    Oliver
    • O Oli
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      @oli sagte in Errors beim Das Wetter-Adapter:
      Lösche alle Datenpunkte von dasWetter und lasse Sie neuanlegen.
      A 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        AndreasE112
        schrieb am zuletzt editiert von AndreasE112
        @glasfaser Hallo zusammen, ich hatte das gleiche Problem und hab die Datenpunkte gelöscht. Zuerst hab ich die Instanz gestoppt.
        Nun läuft mein Admin nicht mehr und ich komm nur noch mit Putty drauf.
        Kennt jemand abhilfe ?
        Hat sich erledigt... nach 15 Minuten warten und googlen läufts wieder
