  4. Could not parse value for id info.0.sysinfo.disks.fsSize.fs3
    6.7k
4 Beiträge 3 Kommentatoren 609 Aufrufe 2 Beobachtet
  • 0 Offline
    0 Offline
    0018
    habe folgendes Problem seit meinen heutigen Update diverser Adapter, leider weis ich nicht genau woher die Meldung kommt.
    javascript.0 2021-07-05 11:06:24.171	warn	at processImmediate (internal/timers.js:461:21)
    javascript.0 2021-07-05 11:06:24.170	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5697:41)
    javascript.0 2021-07-05 11:06:24.170	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:511:128)
    javascript.0 2021-07-05 11:06:24.169	warn	Could not parse value for id info.0.sysinfo.disks.fsSize.fs3.used_hist into array: Unexpected token , in JSON at position 10
    javascript.0 2021-07-05 11:06:24.168	warn	at processImmediate (internal/timers.js:461:21)
    javascript.0 2021-07-05 11:06:24.168	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5697:41)
    javascript.0 2021-07-05 11:06:24.167	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:511:79)
    javascript.0 2021-07-05 11:06:24.166	warn	Could not parse value for id info.0.sysinfo.disks.fsSize.fs3.used_hist into array: Unexpected token , in JSON at position 10
    javascript.0 2021-07-05 11:06:24.161	warn	at processImmediate (internal/timers.js:461:21)
    javascript.0 2021-07-05 11:06:24.161	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5697:41)
    javascript.0 2021-07-05 11:06:24.160	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:511:128)
    javascript.0 2021-07-05 11:06:24.159	warn	Could not parse value for id info.0.sysinfo.disks.fsSize.fs2.used_hist into array: Unexpected token , in JSON at position 7
    javascript.0 2021-07-05 11:06:24.159	warn	at processImmediate (internal/timers.js:461:21)
    javascript.0 2021-07-05 11:06:24.158	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5697:41)
    javascript.0 2021-07-05 11:06:24.158	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:511:79)
    javascript.0 2021-07-05 11:06:24.157	warn	Could not parse value for id info.0.sysinfo.disks.fsSize.fs2.used_hist into array: Unexpected token , in JSON at position 7
    javascript.0 2021-07-05 11:06:24.156	warn	at processImmediate (internal/timers.js:461:21)
    javascript.0 2021-07-05 11:06:24.155	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5697:41)
    javascript.0 2021-07-05 11:06:24.155	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:511:128)
    javascript.0 2021-07-05 11:06:24.154	warn	Could not parse value for id info.0.sysinfo.disks.fsSize.fs1.used_hist into array: Unexpected token , in JSON at position 9
    javascript.0 2021-07-05 11:06:24.153	warn	at processImmediate (internal/timers.js:461:21)
    javascript.0 2021-07-05 11:06:24.153	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5697:41)
    javascript.0 2021-07-05 11:06:24.152	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:511:79)
    javascript.0 2021-07-05 11:06:24.151	warn	Could not parse value for id info.0.sysinfo.disks.fsSize.fs1.used_hist into array: Unexpected token , in JSON at position 9
    javascript.0 2021-07-05 11:06:24.146	warn	at processImmediate (internal/timers.js:461:21)
    javascript.0 2021-07-05 11:06:24.146	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5697:41)
    javascript.0 2021-07-05 11:06:24.145	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:511:128)
    javascript.0 2021-07-05 11:06:24.134	warn	Could not parse value for id info.0.sysinfo.disks.fsSize.fs0.used_hist into array: Unexpected token , in JSON at position 10
    javascript.0 2021-07-05 11:06:24.134	warn	at processImmediate (internal/timers.js:461:21)
    javascript.0 2021-07-05 11:06:24.133	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5697:41)
    javascript.0 2021-07-05 11:06:24.133	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:511:79)
    javascript.0 2021-07-05 11:06:24.131	warn	Could not parse value for id info.0.sysinfo.disks.fsSize.fs0.used_hist into array: Unexpected token , in JSON at position 10
    javascript.0 2021-07-05 11:06:16.209	warn	at processImmediate (internal/timers.js:461:21)
    javascript.0 2021-07-05 11:06:16.208	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5697:41)
    javascript.0 2021-07-05 11:06:16.208	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:511:128)
    javascript.0 2021-07-05 11:06:16.189	warn	Could not parse value for id info.0.sysinfo.disks.fsSize.fs3.used_hist into array: Unexpected token , in JSON at position 10
    Meine Systedmdaten:
    Platform linux
    Betriebssystem linux
    Architektur x64
    CPUs 4
    Geschwindigkeit 1497 MHz
    Modell Common KVM processor
    RAM 5.83 GB
    System Betriebszeit 00:05:29
    Node.js v12.22.2
    NPM 6.14.13
    Festplatte Größe 9.1 GB
    Festplatte frei 2.33 GB
    Anzahl der Adapter 421
    Betriebszeit 00:05:23
    Aktive Instanzen 38
    location /opt/iobroker/
    Hostname BrokerNUC
    Druch ein "iobroker update all" weiß ich leider nicht mehr genau welche Adapter alles aktualisiert worden sind. Es schein aber ein Problem mit dem Objekt "info.0.sysinfo.disks.fsSize.fs0.used_hist" zu geben, kann mir aber nicht erklären wieso ?
    Mfg
    0018
    OliverIOO paul53P 2 Antworten Letzte Antwort
    • 0 0018
      Meine Systedmdaten:
      Platform linux
      Architektur x64
      CPUs 4
      RAM 5.83 GB
      Node.js v12.22.2
      NPM 6.14.13
      Aktive Instanzen 38
      Hostname BrokerNUC
      OliverIOO Offline
      OliverIOO Offline
      OliverIO
      @0018
      ich tippe auf info adapter
      Meine Adapter und Widgets
      Links im Profil
      • 0 0018
        Meine Systedmdaten:
        Platform linux
        Architektur x64
        CPUs 4
        RAM 5.83 GB
        Node.js v12.22.2
        NPM 6.14.13
        Aktive Instanzen 38
        Hostname BrokerNUC
        @0018
        Da die Warnung aus der Javascript-Instanz kommt, vermute ich, dass ein Skript auf diesen Datenpunkt zugreift und ihn per JSON.parse() in eine Array wandeln will. Der Datenpunkt enthält aber kein JSON, sondern einen Komma separierten String.
        0 1 Antwort Letzte Antwort
          @0018
          0 Offline
          0 Offline
          0018
          @paul53 ja das hattet ich auch vermutet. ich verwende nur leider kein Script welches den Datenpunkt verarbeitet. Das scheint der Info-Adapter in Verbindung mit dem Update vom Javascript Adapter auf 5.2.0 zu sein. GIT Issue, Bleibt die Frage welcher der beiden Adapter hier das Problem ist.
          Mfg
          0018
