  4. Kein Pairing bei ZIGBEE nach neu Installation möglich
    6.5k
5 Beiträge 2 Kommentatoren 532 Aufrufe 1 Beobachtet
    bullhead
    Systemdata Bitte Ausfüllen
    Hardwaresystem: PI 4B
    Arbeitsspeicher: 4GB
    Festplattenart: SSD
    Betriebssystem: Mac
    Node-Version: 12.22.1
    Nodejs-Version: 12.22.1
    NPM-Version: 6.14.12
    Installationsart: Skript und Manuell
    Image genutzt: Nein
    Ort/Name der Imagedatei: Link
    Hallo habe Iobroker neu installiert und nur den zigbee adapter, wenn ich auf pairing klicke bekomme ich diese Meldung
    Error: Failed to open the network: Error: SRSP - UTIL - ledControl after 6000ms
        at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:37:35)
        at listOnTimeout (internal/timers.js:554:17)
        at processTimers (internal/timers.js:497:7). undefined
    Pairing started
    und im LOG kommt das
    zigbee.0	2021-06-03 10:10:18.625	error	at processTimers (internal/timers.js:497:7)
    zigbee.0	2021-06-03 10:10:18.625	error	at listOnTimeout (internal/timers.js:554:17)
    zigbee.0	2021-06-03 10:10:18.625	error	at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:37:35)
    zigbee.0	2021-06-03 10:10:18.625	error	(9410) Failed to open the network: Error: SRSP - UTIL - ledControl after 6000ms
    zigbee.0	2021-06-03 10:10:12.378	info	(9410) Zigbee: allowing new devices to join.
    zigbee.0	2021-06-03 02:51:12.107	error	at processTimers (internal/timers.js:497:7)
    zigbee.0	2021-06-03 02:51:12.107	error	at listOnTimeout (internal/timers.js:554:17)
    zigbee.0	2021-06-03 02:51:12.107	error	at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:37:35)
    zigbee.0	2021-06-03 02:51:12.107	error	(9410) Failed to open the network: Error: SRSP - UTIL - ledControl after 6000ms
    zigbee.0	2021-06-03 02:51:05.851	info	(9410) Zigbee: allowing new devices to join.
    zigbee.0	2021-06-03 02:51:00.138	info	(9410) Zigbee started
    zigbee.0	2021-06-03 02:51:00.136	info	(9410) Currently no devices.
    zigbee.0	2021-06-03 02:51:00.121	info	(9410) --> transmitPower : normal
    zigbee.0	2021-06-03 02:51:00.119	info	(9410) Unable to disable LED, unsupported function.
    zigbee.0	2021-06-03 02:50:54.104	info	(9410) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20182308}}
    zigbee.0	2021-06-03 02:50:51.897	info	(9410) Installed Version: iobroker.zigbee@1.5.6
    zigbee.0	2021-06-03 02:50:51.612	info	(9410) Starting Zigbee npm ...
    zigbee.0	2021-06-03 02:50:51.517	info	(9410) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
    wo liegt da mein Problem
    Schon mal Danke
    E 1 Antwort Letzte Antwort
    • B bullhead
      Festplattenart: SSD
      Betriebssystem: Mac
      Image genutzt: Nein
      Pairing started
      Schon mal Danke
      eMd
      @bullhead
      Welchen Stick hast du?
      Master: Intel NUC 16GB/500GB
      Slave: Raspberry Pi 3 + Homematicmodul
      Shelly, Google Home, Zigbee Aqara, Sonoff
      Meine VIS: https://youtu.be/JMYr2KYlpME
      B 1 Antwort Letzte Antwort
      • E eMd
        @bullhead
        bullhead
        @emd
        oh ganz vergessen das mit rein zu schreiben denn CC2530
        • E Offline
          eMd
          Der ist auch schon älter. Ich habe die gleichen Probleme wie du, alte Geräte funktionieren, pairing nicht möglich...
          Ich warte auf ein Update...
          • E eMd
            bullhead
            schrieb am zuletzt editiert von bullhead
            Am besten einen neuen kaufen aber nur welchen
            zum aufspielen habe ich keinen cc debugger dann kauf ich mir gleich das CC26X2R1
