  4. Aktuelle Warn und Fehlermeldungen bei Installation
    5.6k
1 Beiträge 1 Kommentatoren 726 Aufrufe
    Hallo Bluefox,
    ich habe gerade nochmal eine neue Installation auf einem Cubietruck auf der HDD aufgesetzt. Mal wieder mit nodejs v6.
    Folgendes stand alles im Log:
    ! npm install iobroker.js-controller --production --prefix /opt/iobroker npm WARN deprecated letsencrypt@2.1.8: letsencrypt has been renamed to greenlock. Please find it at npm greenlock npm WARN deprecated localhost.daplie.com-certificates@1.2.5: Moved to localhost.daplie.me-certificates (node:1110) DeprecationWarning: crypto.pbkdf2 without specifying a digest is deprecated. Please specify a digest npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json' npm WARN iobroker No description npm WARN iobroker No repository field. npm WARN iobroker No README data npm WARN iobroker No license field. npm install iobroker.admin --production --prefix /opt/iobroker Write "./iobroker start" to start the ioBroker Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start iobroker is started. Go to "http://ip-addr:8081" to open the admin UI. /opt/iobroker └─┬ iobroker@0.7.1 └─┬ yargs@4.8.1 ├─┬ cliui@3.2.0 │ ├─┬ strip-ansi@3.0.1 │ │ └── ansi-regex@2.1.1 │ └── wrap-ansi@2.1.0 ├── decamelize@1.2.0 ├── get-caller-file@1.0.2 ├── lodash.assign@4.2.0 ├─┬ os-locale@1.4.0 │ └─┬ lcid@1.0.0 │ └── invert-kv@1.0.0 ├─┬ read-pkg-up@1.0.1 │ ├─┬ find-up@1.1.2 │ │ ├── path-exists@2.1.0 │ │ └─┬ pinkie-promise@2.0.1 │ │ └── pinkie@2.0.4 │ └─┬ read-pkg@1.1.0 │ ├─┬ load-json-file@1.1.0 │ │ ├── graceful-fs@4.1.11 │ │ ├─┬ parse-json@2.2.0 │ │ │ └─┬ error-ex@1.3.0 │ │ │ └── is-arrayish@0.2.1 │ │ ├── pify@2.3.0 │ │ └─┬ strip-bom@2.0.0 │ │ └── is-utf8@0.2.1 │ ├─┬ normalize-package-data@2.3.5 │ │ ├── hosted-git-info@2.2.0 │ │ ├─┬ is-builtin-module@1.0.0 │ │ │ └── builtin-modules@1.1.1 │ │ ├── semver@5.3.0 │ │ └─┬ validate-npm-package-license@3.0.1 │ │ ├─┬ spdx-correct@1.0.2 │ │ │ └── spdx-license-ids@1.2.2 │ │ └── spdx-expression-parse@1.0.4 │ └── path-type@1.1.0 ├── require-directory@2.1.1 ├── require-main-filename@1.0.1 ├── set-blocking@2.0.0 ├─┬ string-width@1.0.2 │ ├── code-point-at@1.1.0 │ └─┬ is-fullwidth-code-point@1.0.0 │ └── number-is-nan@1.0.1 ├── which-module@1.0.0 ├── window-size@0.2.0 ├── y18n@3.2.1 └─┬ yargs-parser@2.4.1 └── camelcase@3.0.0 ! npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json' npm WARN iobroker No description npm WARN iobroker No repository field. npm WARN iobroker No README data npm WARN iobroker No license field. !
    Kann / Muss man was gegen die beiden WARN zu Anfang machen?
    und mich stört besonders:
    Einmal vor dem Tree und einmal danach.
    Rainer
