  4. [gelöst] Synology Adapter startet nicht mehr
    5.9k
3 Beiträge 2 Kommentatoren 536 Aufrufe 2 Beobachtet
  • Holger EtzelH Online
    Holger Etzel
    schrieb am zuletzt editiert von Holger Etzel
    der Synology-Adapter ist die ganze Zeit gelaufen.
    IObroker läuft in einer VM auf der Synology.
    Nach dem letzten Update von 0.1.20 auf 1.0.0 startet der Adapter nicht mehr und bleibt gelb.
    Im Log stehen dann folgende Fehlermeldungen
    synology.1	2021-04-28 19:53:59.600	warn	(1710020) get state error: Connection is closed.
    synology.1	2021-04-28 19:53:59.599	warn	(1710020) Could not check object existence of state synology.1.info.connection: Cannot check object existence of "synology.1.info.connection": Connection is closed.
    synology.1	2021-04-28 19:53:59.599	error	(1710020) Cannot check object existence of "synology.1.info.connection": Connection is closed.
    synology.1	2021-04-28 19:53:59.597	warn	(1710020) redis get synology.1.info.connection, error - Connection is closed.
    synology.1	2021-04-28 19:53:59.596	debug	(1710020) * Get info from (firstPoll) api: DSM method: getPollingData params: {}
    synology.1	2021-04-28 19:53:59.596	debug	(1710020) * sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getPollingData","params":{}}
    synology.1	2021-04-28 19:53:59.596	debug	(1710020) -----------------------------------------------------------------------------------------------------
    synology.1	2021-04-28 19:53:59.596	debug	(1710020) Error: Reconnection after 10s
    synology.1	2021-04-28 19:53:59.596	debug	(1710020) *** ERROR : src: sendPolling syno[dsm][getPollingData] To use the adapter, the user must be in the Administrators group! code: 400 message: No such account or incorrect password
    synology.1	2021-04-28 19:53:59.595	debug	(1710020) * No response, read next.
    synology.1	2021-04-28 19:53:59.510	warn	(1710020) get state error: Connection is closed.
    synology.1	2021-04-28 19:53:59.509	warn	(1710020) Could not check object existence of state synology.1.info.connection: Cannot check object existence of "synology.1.info.connection": Connection is closed.
    synology.1	2021-04-28 19:53:59.508	error	(1710020) Cannot check object existence of "synology.1.info.connection": Connection is closed.
    synology.1	2021-04-28 19:53:59.505	warn	(1710020) redis get synology.1.info.connection, error - Connection is closed.
    synology.1	2021-04-28 19:53:59.505	debug	(1710020) * Get info from (firstPoll) api: DSM method: getPollingData params: {}
    synology.1	2021-04-28 19:53:59.505	debug	(1710020) * sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getPollingData","params":{}}
    synology.1	2021-04-28 19:53:59.505	debug	(1710020) -----------------------------------------------------------------------------------------------------
    synology.1	2021-04-28 19:53:59.504	debug	(1710020) Error: Reconnection after 10s
    synology.1	2021-04-28 19:53:59.504	debug	(1710020) *** ERROR : src: sendPolling syno[dsm][getPollingData] To use the adapter, the user must be in the Administrators group! code: 400 message: No such account or incorrect password
    synology.1	2021-04-28 19:53:59.504	debug	(1710020) * No response, read next.
    synology.1	2021-04-28 19:53:59.475	warn	(1710020) get state error: Connection is closed.
    synology.1	2021-04-28 19:53:59.429	warn	(1710020) get state error: Connection is closed.
    synology.1	2021-04-28 19:53:59.428	warn	(1710020) get state error: Connection is closed.
    synology.1	2021-04-28 19:53:59.400	warn	(1710020) redis get synology.1.info.connection, error - Connection is closed.
    synology.1	2021-04-28 19:53:59.399	debug	(1710020) * Get info from (firstPoll) api: DSM method: getPollingData params: {}
    synology.1	2021-04-28 19:53:59.399	debug	(1710020) * sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getPollingData","params":{}}
    synology.1	2021-04-28 19:53:59.399	debug	(1710020) -----------------------------------------------------------------------------------------------------
    synology.1	2021-04-28 19:53:59.399	debug	(1710020) Error: Reconnection after 10s
    synology.1	2021-04-28 19:53:59.399	debug	(1710020) *** ERROR : src: sendPolling syno[dsm][getPollingData] To use the adapter, the user must be in the Administrators group! code: 400 message: No such account or incorrect password
    synology.1	2021-04-28 19:53:59.398	debug	(1710020) * No response, read next.
    synology.1	2021-04-28 19:53:59.373	warn	(1710020) redis get synology.1.info.connection, error - DB closed
    synology.1	2021-04-28 19:53:59.372	warn	(1710020) redis get synology.1.info.connection, error - Connection is closed.
    Die Datenpunkte scheinen aber da zu sein. Mit meiner zweiten Synology läuft der Adapter.
    finde es komisch, da der Adapter vor dem Update gelaufen ist. User und PW habe ich nicht geändert und auch schon neu eingegeben.
    Auf die Synology komme ich mit den Anmeldedaten.
    Hat jemand eine Idee
    Holger
    • GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      @holger-etzel sagte in Synology Adapter startet nicht mehr:
      ... und auch schon neu eingegeben.
      Eventuell blockiert .
      https://forum.iobroker.net/topic/44484/gelöst-synology-ist-nicht-erreichbar/2
      https://forum.iobroker.net/topic/44260/synology-adapter-keine-verbindung-mehr-gelb/4
      Sonst sind hier viele Beiträge und Lösungen zu :
      https://forum.iobroker.net/topic/33224/iobroker-synology-adapter
      Holger EtzelH 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        Holger Etzel
        @glasfaser
        danke, der Tip war richtig.
        IP war blockiert.
        Danke für die schnelle hilfe
