  2. English
  3. Development
  4. VW Connect adapter not able to login
    6.1k
Geplant Angeheftet Gesperrt Verschoben Development
windowsadapter
15 Beiträge 6 Kommentatoren 3.9k Aufrufe 5 Beobachtet
  • peltsi515P Offline
    peltsi515P Offline
    peltsi515
    Today the IObroker VW Connect adapter didn't first update the values from the server and after reloading the adapter the adapter cannot connect to VW server anymore. Anyone else having this kind of problems?
    Tried rebooting the IObroker with rebooting the whole computer. Didn't work.
    Car ID3
    VW connect adapter version 0.0.30
    Platform Windows
    Architecture ia32
    CPUs 4
    Speed 1797 MHz
    Model Intel(R) Atom(TM) CPU Z2760 @ 1.80GHz
    RAM 1.96 GB
    Node.js
    v10.17.0
    • peltsi515P peltsi515
      Car ID3
      Platform Windows
      Architecture ia32
      CPUs 4
      Speed 1797 MHz
      RAM 1.96 GB
      Node.js
      v10.17.0
      @peltsi515 sagte in VW Connect adapter not able to login:
      Node.js
      v10.17.0
      Update to node12 or node14
      peltsi515P BananaJoeB 2 Antworten Letzte Antwort
        Node.js
        v10.17.0
        peltsi515P Offline
        peltsi515P Offline
        peltsi515
        @thomas-braun Thanks for the fast answer.
        Do you think that this could be the cause, because it has worked about three weeks perfectly with this version.
        Other question is that how you update the node.js version in windows install?
        Thomas BraunT V 2 Antworten Letzte Antwort
          @peltsi515 I'm running Linux, no idea about Windows.
          node10 will reach its End Of Live in a few weeks, so it is time to upgrade anyway.
          peltsi515P 1 Antwort Letzte Antwort
            peltsi515P Offline
            peltsi515P Offline
            peltsi515
            I got the node.js updated and the IObroker controller also. No help there. The connection to VW server is still out. The We Connect ID app is working so the VW server should be ok.
            Anyone able to help?
              GlasfaserG Offline
              GlasfaserG Offline
              Glasfaser
              ioBroker Log from Adapter ?
              is a 401 .. 503 in your Log or ?????
              • GlasfaserG Glasfaser
                peltsi515P Offline
                peltsi515P Offline
                peltsi515
                schrieb am zuletzt editiert von peltsi515
                @glasfaser The login information (username and password, etc.) are correct I have checked those.
                2021-03-28 22:36:56.308 - error: vw-connect.0 (5176) Login was not successful, please check your login credentials and selected type
                2021-03-28 22:36:56.310 - error: vw-connect.0 (5176) TypeError: Cannot read property 'split' of undefined
                2021-03-28 22:36:56.346 - error: vw-connect.0 (5176) TypeError: Cannot read property 'split' of undefined
                at Request._callback (C:\Program Files\PeltolaIObroker\node_modules\iobroker.vw-connect\main.js:469:105)
                at Request.self.callback (C:\Program Files\PeltolaIObroker\node_modules\iobroker.vw-connect\node_modules\request\request.js:185:22)
                at Request.emit (events.js:315:20)
                at Request.EventEmitter.emit (domain.js:467:12)
                at Request. (C:\Program Files\PeltolaIObroker\node_modules\iobroker.vw-connect\node_modules\request\request.js:1154:10)
                at IncomingMessage. (C:\Program Files\PeltolaIObroker\node_modules\iobroker.vw-connect\node_modules\request\request.js:1076:12)
                at Object.onceWrapper (events.js:421:28)
                at IncomingMessage.emit (events.js:327:22)
                2021-03-28 22:36:56.350 - error: vw-connect.0 (5176) Login Failed
                mrbungle64M 1 Antwort Letzte Antwort
                  Node.js
                  v10.17.0
                  BananaJoeB Online
                  BananaJoeB Online
                  BananaJoe
                  @thomas-braun sagte in VW Connect adapter not able to login:
                  Node.js
                  v10.17.0
                  @peltsi515
                  I would use v12
                  With v14 the Connector did not run in my enviroment
                    mrbungle64M Offline
                    mrbungle64M Offline
                    mrbungle64
                    @peltsi515 said in VW Connect adapter not able to login:
                    You have to visit the Volkswagen portal and agree to the privacy policy.
                    • mrbungle64M mrbungle64
                      peltsi515P Offline
                      peltsi515P Offline
                      peltsi515
                      @mrbungle64 Yes. Like I said the connection/adapter have worked for three weeks perfectly.
                      mrbungle64M GlasfaserG 2 Antworten Letzte Antwort
                        mrbungle64M Offline
                        mrbungle64M Offline
                        mrbungle64
                        Sounds weird but you have to do it again ;)
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Glasfaser
                          @peltsi515
                          Have you create a new Account !?
                          Passwort / User not per Drag and Drop !
                            peltsi515P Offline
                            peltsi515P Offline
                            peltsi515
                            @mrbungle64 No way. It worked. You really had to agree to them again. Thank you very much for your help!
                              V Offline
                              V Offline
                              volker-gi
                              @peltsi515 Hello, i also have no Connection to the WeConnect Adapter. he had yellow state since one Week. Before the function was ok. I was on the VW Connect site and the Access is OK. Only the Adapter has no function. I delete and reinstalled it with User and password. When i start it, it goes now directly to red state. Any idea?
                              • V volker-gi
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Glasfaser
                                @volker-gi sagte in VW Connect adapter not able to login:
                                Do you have a log from the start of the adapter
