  4. [gelöst] Javascript Adapter startet nicht mehr nach Update
    6.6k
3 Beiträge 2 Kommentatoren 348 Aufrufe 2 Beobachtet
  • X Offline
    X Offline
    Xyolyp
    schrieb am zuletzt editiert von Xyolyp
    Ich habe den Octopi und den trashschedule Adapter aktualisiert und seitdem startet der Javascript-Adapter mit dem untenstehenden Log nicht mehr.
    Javascript: 4.10.8
    JS-Controller: 3.1.6
    npm -v 7.5.3
    node -v v12.20.2
    nodejs -v v12.20.2
    host.iobroker	2021-02-10 23:58:06.045	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker	2021-02-10 23:58:06.045	error	Caught by controller[0]: }
    host.iobroker	2021-02-10 23:58:06.045	error	Caught by controller[0]: requestPath: 'typescript'
    host.iobroker	2021-02-10 23:58:06.045	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/package.json',
    host.iobroker	2021-02-10 23:58:06.044	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.iobroker	2021-02-10 23:58:06.044	error	Caught by controller[0]: {
    host.iobroker	2021-02-10 23:58:06.044	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
    host.iobroker	2021-02-10 23:58:06.044	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
    host.iobroker	2021-02-10 23:58:06.044	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.iobroker	2021-02-10 23:58:06.043	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.iobroker	2021-02-10 23:58:06.043	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.iobroker	2021-02-10 23:58:06.043	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.iobroker	2021-02-10 23:58:06.043	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
    host.iobroker	2021-02-10 23:58:06.043	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.iobroker	2021-02-10 23:58:06.042	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.iobroker	2021-02-10 23:58:06.042	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.iobroker	2021-02-10 23:58:06.042	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.iobroker	2021-02-10 23:58:06.042	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.iobroker	2021-02-10 23:58:06.042	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.iobroker	2021-02-10 23:58:06.041	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc/build/index.js:8:16)
    host.iobroker	2021-02-10 23:58:06.041	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.iobroker	2021-02-10 23:58:06.041	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.iobroker	2021-02-10 23:58:06.041	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.iobroker	2021-02-10 23:58:06.041	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.iobroker	2021-02-10 23:58:06.040	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.iobroker	2021-02-10 23:58:06.040	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.iobroker	2021-02-10 23:58:06.040	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc/build/server.js:4:10)
    host.iobroker	2021-02-10 23:58:06.040	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.iobroker	2021-02-10 23:58:06.039	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.iobroker	2021-02-10 23:58:06.039	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
    host.iobroker	2021-02-10 23:58:06.039	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:802:27)
    host.iobroker	2021-02-10 23:58:06.038	error	Caught by controller[0]: at Function.Module._findPath (internal/modules/cjs/loader.js:508:18)
    host.iobroker	2021-02-10 23:58:06.038	error	Caught by controller[0]: at tryPackage (internal/modules/cjs/loader.js:295:19)
    host.iobroker	2021-02-10 23:58:06.038	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js'. Please verify that the package.json has a valid "main" en
    host.iobroker	2021-02-10 23:58:06.037	error	Caught by controller[0]: ^
    host.iobroker	2021-02-10 23:58:06.037	error	Caught by controller[0]: throw err;
    host.iobroker	2021-02-10 23:58:06.036	error	Caught by controller[0]: internal/modules/cjs/loader.js:303
    • X Xyolyp
      Javascript: 4.10.8
      npm -v 7.5.3
      node -v v12.20.2
      nodejs -v v12.20.2
      MCU
      @xyolyp Dann versuch mal den trashschedule - Adapter zurückzusetzen auf die Version davor. Vermutlich hast du eigene Script mit den Daten aus dem trashschedule Adapter gemacht?
      Adapter /Expertenmodus einschalten:
      Version auswählen:
      X 1 Antwort Letzte Antwort
      • M MCU
        Version auswählen:
        X Offline
        X Offline
        Xyolyp
        @mcu nein, ich habe keine Scripte, die den Trashschedule Adapter nutzen. Den hatte ich nur mal installiert, um ihn mir anzugucken und vergessen zu deinstallieren. Auch nach einer Deinstallation vom Trash-Schedule bestand das Problem noch.
        Einmal npm install --production im Ordner /opt/iobroker/node_modules/iobroker.javascript hat das Problem inzwischen gelöst.
