  4. [Gelöst]javascripte laufen nicht mehr
    6.3k
19 Beiträge 3 Kommentatoren 1.8k Aufrufe 1 Beobachtet
  • L Offline
    Lollo
    schrieb am zuletzt editiert von Lollo
    Servus,
    seit gestern laufen meine Skripte nicht mehr.
    Im LOG ist folgendes abgelegt.
    Kann jemand helfen?
    javascript.0	2021-01-31 08:59:05.858	info	(26359) Start javascript script.js.common.Badfensterüberwachung
    javascript.0	2021-01-31 08:59:05.844	error	(26359) at processTicksAndRejections (internal/process/task_queues.js:97:5)
    javascript.0	2021-01-31 08:59:05.837	error	(26359) at runMicrotasks (<anonymous>)
    javascript.0	2021-01-31 08:59:05.830	error	(26359) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
    javascript.0	2021-01-31 08:59:05.826	error	(26359) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    javascript.0	2021-01-31 08:59:05.812	error	(26359) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
    javascript.0	2021-01-31 08:59:05.811	error	(26359) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
    javascript.0	2021-01-31 08:59:05.800	error	(26359) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
    javascript.0	2021-01-31 08:59:05.793	error	(26359) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
    javascript.0	2021-01-31 08:59:05.793	error	(26359) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
    javascript.0	2021-01-31 08:59:05.783	error	(26359) at Object.createScript (vm.js:261:10)
    javascript.0	2021-01-31 08:59:05.779	error	(26359) at new Script (vm.js:88:7)
    javascript.0	2021-01-31 08:59:05.773	error	(26359) SyntaxError: Unexpected token '='
    javascript.0	2021-01-31 08:59:05.762	error	(26359) ^
    javascript.0	2021-01-31 08:59:05.755	error	(26359) var = {};
    javascript.0	2021-01-31 08:59:05.755	error	(26359) script.js.common.Anwesenheit.Jörg compile failed: at script.js.common.Anwesenheit.Jörg:1
    MOD-Edit: Code in code-tags gesetzt!
    Platform
    linux
    Betriebssystem
        linux
    Architektur
        x64
    CPUs
    Geschwindigkeit
        1649 MHz
    Modell
        AMD G-T56N Processor
    RAM
        3.91 GB
    System Betriebszeit
        31 T. 19:54:37
    Node.js
        v12.20.1
    NPM
        6.14.10
    Festplatte Größe
        7.81 GB
    Festplatte frei
        3.28 GB
    • L Lollo
      Servus,
      Kann jemand helfen?
      Platform
      linux
      Betriebssystem
          linux
      Architektur
          x64
      CPUs
      Geschwindigkeit
          1649 MHz
      Modell
      RAM
          3.91 GB
      System Betriebszeit
          31 T. 19:54:37
      Node.js
          v12.20.1
      NPM
          6.14.10
      Festplatte Größe
          7.81 GB
      Festplatte frei
          3.28 GB
      @lollo sagte in javascripte laufen nicht mehr:
      die Zeile ist unvollständig.
      die Ursache steht erst kurz danach
      L 1 Antwort Letzte Antwort
        Lollo
        @homoran hab jetzt den kompletten Eintrag nach Adapterneustart angepinnt.
        javascript.0	2021-01-31 09:30:42.906	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.906	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.906	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.905	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.905	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17
        javascript.0	2021-01-31 09:30:42.905	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.905	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.904	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.904	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.904	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.903	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.903	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.903	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.886	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.886	error	(27175) script.js.common.Licht.Johanna_Licht_und_Alexa_aus compile failed: at script.js.common.Licht.Johanna_Licht_und_Alexa_aus:1
        javascript.0	2021-01-31 09:30:42.884	info	(27175) Start javascript script.js.common.Licht.Johanna_Licht_und_Alexa_aus
        javascript.0	2021-01-31 09:30:42.883	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.882	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.882	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.882	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.882	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.881	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.881	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.881	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.880	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.880	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.880	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.879	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.862	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.862	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.861	error	(27175) script.js.common.Weihnachtsbeleuchtung.Weihnachtsbeleuchtung_innen compile failed: at script.js.common.Weihnachtsbeleuchtung.Weihnachtsbeleuchtung_innen:1
        javascript.0	2021-01-31 09:30:42.859	info	(27175) Start javascript script.js.common.Weihnachtsbeleuchtung.Weihnachtsbeleuchtung_innen
        javascript.0	2021-01-31 09:30:42.858	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.858	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.858	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.857	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.857	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.857	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.857	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.856	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.856	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.856	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.855	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.855	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.855	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.854	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.854	error	(27175) script.js.common.Weihnachtsbeleuchtung.Weihnachtsbeleuchtung_außen compile failed: at script.js.common.Weihnachtsbeleuchtung.Weihnachtsbeleuchtung_außen:1
        javascript.0	2021-01-31 09:30:42.832	info	(27175) Start javascript script.js.common.Weihnachtsbeleuchtung.Weihnachtsbeleuchtung_außen
        javascript.0	2021-01-31 09:30:42.831	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.830	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.830	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.830	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.830	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.829	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.829	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.829	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.828	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.828	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.828	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.828	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.827	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.827	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.826	error	(27175) script.js.common.Weihnachtsbeleuchtung.Weihnachtsbeleuchtung_Cronjob_Kopieren compile failed: at script.js.common.Weihnachtsbeleuchtung.Weihnachtsbeleuchtung_Cronjob_Kopieren:1
        javascript.0	2021-01-31 09:30:42.814	info	(27175) Start javascript script.js.common.Weihnachtsbeleuchtung.Weihnachtsbeleuchtung_Cronjob_Kopieren
        javascript.0	2021-01-31 09:30:42.813	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.813	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.812	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.812	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.812	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.811	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.811	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.811	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.811	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.810	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.810	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.810	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.809	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.809	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.790	error	(27175) script.js.common.Türklingel compile failed: at script.js.common.Türklingel:1
        javascript.0	2021-01-31 09:30:42.788	info	(27175) Start javascript script.js.common.Türklingel
        javascript.0	2021-01-31 09:30:42.787	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.787	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.787	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.786	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.786	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.786	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.786	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.785	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.785	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.785	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.784	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.784	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.784	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.783	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.783	error	(27175) script.js.common.Steckdosen.Waschmaschine compile failed: at script.js.common.Steckdosen.Waschmaschine:1
        javascript.0	2021-01-31 09:30:42.772	info	(27175) Start javascript script.js.common.Steckdosen.Waschmaschine
        javascript.0	2021-01-31 09:30:42.770	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.750	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.750	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.750	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.750	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.749	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.749	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.749	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.748	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.748	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.748	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.748	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.747	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.747	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.746	error	(27175) script.js.common.Steckdosen.Untertsichgerät compile failed: at script.js.common.Steckdosen.Untertsichgerät:1
        javascript.0	2021-01-31 09:30:42.744	info	(27175) Start javascript script.js.common.Steckdosen.Untertsichgerät
        javascript.0	2021-01-31 09:30:42.744	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.743	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.743	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.743	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.742	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.742	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.742	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.741	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.718	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.718	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.718	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.717	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.717	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.717	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.716	error	(27175) script.js.common.Steckdosen.Trockner compile failed: at script.js.common.Steckdosen.Trockner:1
        javascript.0	2021-01-31 09:30:42.714	info	(27175) Start javascript script.js.common.Steckdosen.Trockner
        javascript.0	2021-01-31 09:30:42.713	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.713	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.712	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.712	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.712	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.712	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.711	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.711	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.711	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.710	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.710	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.710	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.709	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.709	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.690	error	(27175) script.js.common.Steckdosen.Akkulader compile failed: at script.js.common.Steckdosen.Akkulader:1
        javascript.0	2021-01-31 09:30:42.688	info	(27175) Start javascript script.js.common.Steckdosen.Akkulader
        javascript.0	2021-01-31 09:30:42.687	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.687	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.686	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.686	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.686	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.685	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.685	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.685	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.685	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.684	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.684	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.684	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.683	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.683	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.682	error	(27175) script.js.common.Steckdosen.3D_Drucker compile failed: at script.js.common.Steckdosen.3D_Drucker:1
        javascript.0	2021-01-31 09:30:42.661	info	(27175) Start javascript script.js.common.Steckdosen.3D_Drucker
        javascript.0	2021-01-31 09:30:42.660	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.660	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.660	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.659	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.659	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.659	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.658	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.658	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.658	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.658	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.657	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.657	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.657	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.656	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.656	error	(27175) script.js.common.Sensorüberwachung.Sensorstörung_melden compile failed: at script.js.common.Sensorüberwachung.Sensorstörung_melden:1
        javascript.0	2021-01-31 09:30:42.637	info	(27175) Start javascript script.js.common.Sensorüberwachung.Sensorstörung_melden
        javascript.0	2021-01-31 09:30:42.636	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.636	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.636	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.636	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.635	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.635	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.635	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.634	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.634	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.634	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.633	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.633	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.633	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.632	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.632	error	(27175) script.js.common.Sensorüberwachung.Sensorstatusüberwachung compile failed: at script.js.common.Sensorüberwachung.Sensorstatusüberwachung:1
        javascript.0	2021-01-31 09:30:42.613	info	(27175) Start javascript script.js.common.Sensorüberwachung.Sensorstatusüberwachung
        javascript.0	2021-01-31 09:30:42.612	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.612	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.611	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.611	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.611	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.610	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.610	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.598	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.598	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.598	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.598	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.597	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.597	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.597	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.596	error	(27175) script.js.common.Licht.Kellertür_Licht_AN_AUS_Türsensor compile failed: at script.js.common.Licht.Kellertür_Licht_AN_AUS_Türsensor:1
        javascript.0	2021-01-31 09:30:42.594	info	(27175) Start javascript script.js.common.Licht.Kellertür_Licht_AN_AUS_Türsensor
        javascript.0	2021-01-31 09:30:42.590	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.590	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.590	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.589	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.589	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.588	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.570	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.570	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.570	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.569	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.569	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.569	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.569	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.568	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.568	error	(27175) script.js.common.Licht.Gäste_WC_Licht_nach_30_min_aus compile failed: at script.js.common.Licht.Gäste_WC_Licht_nach_30_min_aus:1
        javascript.0	2021-01-31 09:30:42.565	info	(27175) Start javascript script.js.common.Licht.Gäste_WC_Licht_nach_30_min_aus
        javascript.0	2021-01-31 09:30:42.564	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.564	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.564	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.564	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.563	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.563	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.563	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.562	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.546	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.546	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.546	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.546	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.545	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.545	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.544	error	(27175) script.js.common.Licht.Flur_OG_Licht_AN_AUS_BWM compile failed: at script.js.common.Licht.Flur_OG_Licht_AN_AUS_BWM:1
        javascript.0	2021-01-31 09:30:42.542	info	(27175) Start javascript script.js.common.Licht.Flur_OG_Licht_AN_AUS_BWM
        javascript.0	2021-01-31 09:30:42.541	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.518	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.518	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.518	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.517	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.517	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.517	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.517	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.516	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.516	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.516	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.515	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.515	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.515	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.514	error	(27175) script.js.common.Licht.FlurOGHellDunkel compile failed: at script.js.common.Licht.FlurOGHellDunkel:1
        javascript.0	2021-01-31 09:30:42.512	info	(27175) Start javascript script.js.common.Licht.FlurOGHellDunkel
        javascript.0	2021-01-31 09:30:42.511	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.510	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.510	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.510	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.509	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.490	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.490	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.490	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.490	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.489	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.489	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.489	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.488	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.488	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.487	error	(27175) script.js.common.Licht.Aqara_Würfel_Scenen_Wohnzimmer compile failed: at script.js.common.Licht.Aqara_Würfel_Scenen_Wohnzimmer:1
        javascript.0	2021-01-31 09:30:42.485	info	(27175) Start javascript script.js.common.Licht.Aqara_Würfel_Scenen_Wohnzimmer
        javascript.0	2021-01-31 09:30:42.484	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.484	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.484	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.483	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.483	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.482	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.482	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.472	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.472	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.472	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.471	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.471	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.470	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.470	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.469	error	(27175) script.js.common.Dunstabzug compile failed: at script.js.common.Dunstabzug:1
        javascript.0	2021-01-31 09:30:42.449	info	(27175) Start javascript script.js.common.Dunstabzug
        javascript.0	2021-01-31 09:30:42.449	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.448	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.448	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.448	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.447	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.447	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.447	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.446	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.446	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.446	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.445	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.445	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.445	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.444	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.444	error	(27175) script.js.common.Datenpunkte.Alle_Lichter_aus compile failed: at script.js.common.Datenpunkte.Alle_Lichter_aus:1
        javascript.0	2021-01-31 09:30:42.427	info	(27175) Start javascript script.js.common.Datenpunkte.Alle_Lichter_aus
        javascript.0	2021-01-31 09:30:42.426	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.426	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.425	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.425	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.425	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.424	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.424	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.424	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.423	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.423	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.423	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.422	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.422	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.422	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.419	error	(27175) script.js.common.Datenpunkte.Alle_Fenster_zu compile failed: at script.js.common.Datenpunkte.Alle_Fenster_zu:1
        javascript.0	2021-01-31 09:30:42.404	info	(27175) Start javascript script.js.common.Datenpunkte.Alle_Fenster_zu
        javascript.0	2021-01-31 09:30:42.404	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.403	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.403	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.403	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.402	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.402	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.402	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.401	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.401	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.401	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.400	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.362	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.362	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.362	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.361	error	(27175) script.js.common.Badfensterüberwachung compile failed: at script.js.common.Badfensterüberwachung:1
        javascript.0	2021-01-31 09:30:42.359	info	(27175) Start javascript script.js.common.Badfensterüberwachung
        javascript.0	2021-01-31 09:30:42.358	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.357	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.357	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.357	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.356	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.356	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.356	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.356	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.355	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.330	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.330	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.330	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.329	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.329	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.328	error	(27175) script.js.common.Anwesenheit.Jörg compile failed: at script.js.common.Anwesenheit.Jörg:1
        javascript.0	2021-01-31 09:30:42.326	info	(27175) Start javascript script.js.common.Anwesenheit.Jörg
        javascript.0	2021-01-31 09:30:42.325	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.325	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.324	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.324	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.324	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.321	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.320	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.320	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.304	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.304	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.304	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.303	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.303	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.303	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.302	error	(27175) script.js.common.Anwesenheit.Jana compile failed: at script.js.common.Anwesenheit.Jana:1
        javascript.0	2021-01-31 09:30:42.281	info	(27175) Start javascript script.js.common.Anwesenheit.Jana
        javascript.0	2021-01-31 09:30:42.280	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.279	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.279	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.248	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.248	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.220	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.219	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.219	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.218	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.218	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.218	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.217	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.217	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.216	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.216	error	(27175) script.js.common.Alexa_Lautstärkereset compile failed: at script.js.common.Alexa_Lautstärkereset:1
        javascript.0	2021-01-31 09:30:42.201	info	(27175) Start javascript script.js.common.Alexa_Lautstärkereset
        javascript.0	2021-01-31 09:30:42.200	error	(27175) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 09:30:42.200	error	(27175) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 09:30:42.199	error	(27175) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 09:30:42.199	error	(27175) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 09:30:42.199	error	(27175) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2021-01-31 09:30:42.198	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 09:30:42.198	error	(27175) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 09:30:42.197	error	(27175) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 09:30:42.197	error	(27175) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 09:30:42.197	error	(27175) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 09:30:42.196	error	(27175) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 09:30:42.174	error	(27175) SyntaxError: Unexpected token '='
        javascript.0	2021-01-31 09:30:42.174	error	(27175) ^
        javascript.0	2021-01-31 09:30:42.173	error	(27175) var = {};
        javascript.0	2021-01-31 09:30:42.172	error	(27175) script.js.common.Alarm.Hüllschutz_aus_Anwesenheit compile failed: at script.js.common.Alarm.Hüllschutz_aus_Anwesenheit:1
        javascript.0	2021-01-31 09:30:42.129	info	(27175) Start javascript script.js.common.Alarm.Hüllschutz_aus_Anwesenheit
        javascript.0	2021-01-31 09:29:54.538	info	(27175) received all states
        javascript.0	2021-01-31 09:29:53.211	info	(27175) received all objects
        javascript.0	2021-01-31 09:29:48.945	info	(27175) requesting all objects
        javascript.0	2021-01-31 09:29:48.941	info	(27175) requesting all states
        javascript.0	2021-01-31 09:29:48.939	debug	(27175) Loaded TypeScript definitions for : []
        javascript.0	2021-01-31 09:29:48.936	debug	(27175) Loaded TypeScript definitions for request: ["node_modules/@types/request/package.json","node_modules/@types/request/index.d.ts"]
        javascript.0	2021-01-31 09:29:48.862	debug	(27175) Loaded TypeScript definitions for node: ["node_modules/@types/node/package.json","node_modules/@types/node/index.d.ts","node_modules/@types/node/base.d.ts","node_modules/@types/node/ts3.6/bas
        javascript.0	2021-01-31 09:29:48.677	info	(27175) starting. Version 4.8.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.20.1, js-controller: 3.1.6
        javascript.0	2021-01-31 09:29:48.375	debug	(27175) Plugin sentry Initialize Plugin (enabled=true)
        javascript.0	2021-01-31 09:29:47.086	debug	(27175) statesDB connected
        javascript.0	2021-01-31 09:29:47.083	debug	(27175) States connected to redis: 127.0.0.1:9000
        javascript.0	2021-01-31 09:29:46.919	debug	(27175) States create System PubSub Client
        javascript.0	2021-01-31 09:29:46.912	debug	(27175) States create User PubSub Client
        javascript.0	2021-01-31 09:29:46.888	debug	(27175) Redis States: Use Redis connection: 127.0.0.1:9000
        javascript.0	2021-01-31 09:29:46.882	debug	(27175) objectDB connected
        javascript.0	2021-01-31 09:29:46.856	debug	(27175) Objects connected to redis: 127.0.0.1:9001
        javascript.0	2021-01-31 09:29:46.662	debug	(27175) Objects client initialize lua scripts
        javascript.0	2021-01-31 09:29:46.658	debug	(27175) Objects create User PubSub Client
        javascript.0	2021-01-31 09:29:46.654	debug	(27175) Objects create System PubSub Client
        javascript.0	2021-01-31 09:29:46.583	debug	(27175) Objects client ready ... initialize now
        javascript.0	2021-01-31 09:29:46.342	debug	(27175) Redis Objects: Use Redis connection: 127.0.0.1:9001
        javascript.0	2021-01-31 09:28:16.540	info	(26359) Terminated (NO_ERROR): Without reason
        javascript.0	2021-01-31 09:28:16.539	debug	(26359) Plugin sentry destroyed
        javascript.0	2021-01-31 09:28:16.537	info	(26359) terminating
        javascript.0	2021-01-31 09:28:16.295	info	(26359) Got terminate signal TERMINATE_YOURSELF
        javascript.0	2021-01-31 09:28:16.255	info	(26359) Stop script script.js.common.Licht.Johanna_Licht_und_Alexa_aus
        javascript.0	2021-01-31 09:28:16.234	info	(26359) Stop script script.js.common.Weihnachtsbeleuchtung.Weihnachtsbeleuchtung_innen
        javascript.0	2021-01-31 09:28:16.233	info	(26359) Stop script script.js.common.Weihnachtsbeleuchtung.Weihnachtsbeleuchtung_außen
        javascript.0	2021-01-31 09:28:16.232	info	(26359) Stop script script.js.common.Weihnachtsbeleuchtung.Weihnachtsbeleuchtung_Cronjob_Kopieren
        javascript.0	2021-01-31 09:28:16.232	info	(26359) Stop script script.js.common.Türklingel
        javascript.0	2021-01-31 09:28:16.231	info	(26359) Stop script script.js.common.Steckdosen.Waschmaschine
        javascript.0	2021-01-31 09:28:16.230	info	(26359) Stop script script.js.common.Steckdosen.Untertsichgerät
        javascript.0	2021-01-31 09:28:16.230	info	(26359) Stop script script.js.common.Steckdosen.Trockner
        javascript.0	2021-01-31 09:28:16.229	info	(26359) Stop script script.js.common.Steckdosen.Akkulader
        javascript.0	2021-01-31 09:28:16.228	info	(26359) Stop script script.js.common.Steckdosen.3D_Drucker
        javascript.0	2021-01-31 09:28:16.196	info	(26359) Stop script script.js.common.Sensorüberwachung.Sensorstörung_melden
        javascript.0	2021-01-31 09:28:16.196	info	(26359) Stop script script.js.common.Sensorüberwachung.Sensorstatusüberwachung
        javascript.0	2021-01-31 09:28:16.195	info	(26359) Stop script script.js.common.Licht.Kellertür_Licht_AN_AUS_Türsensor
        javascript.0	2021-01-31 09:28:16.194	info	(26359) Stop script script.js.common.Licht.Gäste_WC_Licht_nach_30_min_aus
        javascript.0	2021-01-31 09:28:16.193	info	(26359) Stop script script.js.common.Licht.Flur_OG_Licht_AN_AUS_BWM
        javascript.0	2021-01-31 09:28:16.193	info	(26359) Stop script script.js.common.Licht.FlurOGHellDunkel
        javascript.0	2021-01-31 09:28:16.192	info	(26359) Stop script script.js.common.Licht.Aqara_Würfel_Scenen_Wohnzimmer
        javascript.0	2021-01-31 09:28:16.191	info	(26359) Stop script script.js.common.Dunstabzug
        javascript.0	2021-01-31 09:28:16.188	info	(26359) Stop script script.js.common.Datenpunkte.Alle_Lichter_aus
        javascript.0	2021-01-31 09:28:16.178	info	(26359) Stop script script.js.common.Datenpunkte.Alle_Fenster_zu
        javascript.0	2021-01-31 09:28:16.178	info	(26359) Stop script script.js.common.Badfensterüberwachung
        javascript.0	2021-01-31 09:28:16.177	info	(26359) Stop script script.js.common.Anwesenheit.Jörg
        javascript.0	2021-01-31 09:28:16.175	info	(26359) Stop script script.js.common.Anwesenheit.Jana
        javascript.0	2021-01-31 09:28:16.174	info	(26359) Stop script script.js.common.Alexa_Lautstärkereset
        javascript.0	2021-01-31 09:28:16.173	info	(26359) Stop script script.js.common.Alarm.Hüllschutz_aus_Anwesenheit
        javascript.0	2021-01-31 09:28:16.162	info	(26359) Adapter is disabled => stop
        MOD-Edit: Code in code-tags und Spoiler gesetzt!
        • L Lollo
          @lollo
          Bitte in code-tags setzen!
            @lollo
            Lollo
            @homoran sorry, bin Anfänger. Was meinst Du ?
            • L Lollo
              liv-in-skyL Offline
              liv-in-skyL Offline
              liv-in-sky
              @Lollo
              @Homoran meint das https://forum.iobroker.net/post/394912
              • liv-in-skyL liv-in-sky
                @Lollo
                Lollo
                @Homoran
                @liv-in-sky
                wieder was gelernt ;)
                Hoffe so passt es.
                • L Lollo
                  @Homoran
                  @liv-in-sky
                  Hoffe so passt es.
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  liv-in-sky
                  @lollo bitte auch die oberen nachbessern - danke
                    Lollo
                    @liv-in-sky die "oberen" sind doch in den "unteren" enthalten und waren nicht vollständig.
                    • L Lollo
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      liv-in-sky
                      @lollo weißt du wie nervig das ist - bis an diesen punkt hier zu scrollen - da verlieren die leute die lust, den thread zu lesen
                      hast du zufällig unter global ein script liegen ? du musst expertenmodus aktivieren !
                      • L Lollo
                        Was steht in diesem Script in Zeile 1?
                        Da es anscheinend bei allen Skripts die Zeile 1 ist, ist die Frage von @liv-in-sky mehr als berechtigt
                          Lollo
                          @liv-in-sky
                          du hast Recht... ich habe den linkeddevices Adapter testweise ausprobiert und dann wieder gelöscht, da ich den manage devices Adapter nutze.
                          im global Ordner ist nun folgendes skript:
                          var  = {};
                          .getId = function() {return "linkeddevices.0"};
                          .Johanna_Stehlampe = {};
                          .Johanna_Stehlampe.getId = function() {return "linkeddevices.0.Johanna_Stehlampe"};
                          .Johanna_Stehlampe.on = {};
                          .Johanna_Stehlampe.on.getId = function () { let obj = getObject("linkeddevices.0.Johanna_Stehlampe.on"); if (obj && obj.common && obj.common.custom && obj.common.custom["linkeddevices.0"] && obj.common.custom["linkeddevices.0"].isLinked === false) console.warn("object 'linkeddevices.0.Johanna_Stehlampe.on' is not linked anymore!"); return "linkeddevices.0.Johanna_Stehlampe.on"; };
                          .Johanna_Stehlampe.on.getState = function () { let obj = getObject("linkeddevices.0.Johanna_Stehlampe.on"); if (obj && obj.common && obj.common.custom && obj.common.custom["linkeddevices.0"] && obj.common.custom["linkeddevices.0"].isLinked === false) console.warn("object 'linkeddevices.0.Johanna_Stehlampe.on' is not linked anymore!"); return getState("linkeddevices.0.Johanna_Stehlampe.on"); };
                          .Johanna_Stehlampe.on.setState = function (val, ack=false) { let obj = getObject("linkeddevices.0.Johanna_Stehlampe.on"); if (obj && obj.common && obj.common.custom && obj.common.custom["linkeddevices.0"] && obj.common.custom["linkeddevices.0"].isLinked === false) console.warn("object 'linkeddevices.0.Johanna_Stehlampe.on' is not linked anymore!"); setState("linkeddevices.0.Johanna_Stehlampe.on", val, ack); };
                          .Johanna_Stehlampe.on.setStateDelayed = function (val, delay, ack=false) { let obj = getObject("linkeddevices.0.Johanna_Stehlampe.on"); if (obj && obj.common && obj.common.custom && obj.common.custom["linkeddevices.0"] && obj.common.custom["linkeddevices.0"].isLinked === false) console.warn("object 'linkeddevices.0.Johanna_Stehlampe.on' is not linked anymore!"); setStateDelayed("linkeddevices.0.Johanna_Stehlampe.on", val, ack, delay); };
                          .Johanna_Stehlampe.on.getObject = function () { let obj = getObject("linkeddevices.0.Johanna_Stehlampe.on"); if (obj && obj.common && obj.common.custom && obj.common.custom["linkeddevices.0"] && obj.common.custom["linkeddevices.0"].isLinked === false) console.warn("object 'linkeddevices.0.Johanna_Stehlampe.on' is not linked anymore!"); return getObject("linkeddevices.0.Johanna_Stehlampe.on"); };
                          .Johanna_Stehlampe.on.getParentId = function () { let obj = getObject("linkeddevices.0.Johanna_Stehlampe.on"); if (obj && obj.common && obj.common.custom && obj.common.custom["linkeddevices.0"] && obj.common.custom["linkeddevices.0"].isLinked === false) console.warn("object 'linkeddevices.0.Johanna_Stehlampe.on' is not linked anymore!"); return getObject("linkeddevices.0.Johanna_Stehlampe.on").common.custom["linkeddevices.0"].parentId; };
                          @Homoran
                          das ist das script welches Du meintest:
                          on({id: 'deconz.0.Sensors.24.buttonevent', change: "ne"}, function (obj) {
                            var value = obj.state.val;
                            if (getState("deconz.0.Sensors.24.buttonevent").val == 1002) {
                              setState("hue.0.Johanna.on"/*Johanna.on*/, true);
                            } else if (getState("deconz.0.Sensors.24.buttonevent").val == 2002) {
                              setState("hue.0.Johanna.on"/*Johanna.on*/, false);
                          liv-in-skyL HomoranH 3 Antworten Letzte Antwort
                          • L Lollo
                            @liv-in-sky
                            var  = {};
                            @Homoran
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            liv-in-sky
                            ja -da ist der fehler drin var={}
                            also stoppe das script - am besten kopiere es und lösche es dann
                            • L Lollo
                              @liv-in-sky
                              var  = {};
                              @Homoran
                              und das wird jetzt vor jedem anderen Skript ausgeführt, ob es passt oder nicht
                              • L Lollo
                                @liv-in-sky
                                var  = {};
                                @Homoran
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                liv-in-sky
                                @lollo
                                wie @Homoran sagt
                                ein script unter global wird an jedes andere script dazukopiert (damit es global erreichbar wird) - nutzen nur profis, weil damit genau solche fehler passieren können -
                                  @lollo
                                  wie @Homoran sagt
                                  Lollo
                                  @liv-in-sky
                                  @Homoran
                                  dann kann ich das skript unter global doch einfach löschen, da ich es doch eh nicht brauche., oder ?
                                  • L Lollo
                                    @liv-in-sky
                                    @Homoran
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    liv-in-sky
                                    @lollo denke schon, wenn du nicht weißt, was es macht - daher kopiere es in einen editor und lösche es - dann hast du es zur not
                                    HomoranH L 2 Antworten Letzte Antwort
                                      @liv-in-sky sagte in javascripte laufen nicht mehr:
                                      😂 Löschen im Editor bringt aber nichts 😂
                                        Lollo
                                        @liv-in-sky
                                        @Homoran
                                        vielen Dank an euch beiden. Ihr seid Spitze... und ich hab wieder was gelernt. So macht iobroker erst richtig spaß.
