  4. SQL-History Adapter Update failed (1.3.2 auf 1.4.0)
    5.6k
46 Beiträge 7 Kommentatoren 7.4k Aufrufe
  • etvE Offline
    etvE Offline
    etv
    Liebe Leute,
    habe gerade versucht den Adapter auf 1.4.0 hochzuziehen und bin leider gescheitert ;-)
    Das ist der Errorlog des Updates:
    ! $ ./iobroker upgrade sql
    ! host.etv-nas-1 Adapter "system.adapter.sql.0" is stopped.
    ! npm install iobroker.sql –production --prefix "/volume1/iobroker" (System call)
    ! npm
    ! WARN deprecated node-uuid@1.4.7: use uuid module instead
    ! gyp
    ! ERR! build error
    ! gyp
    ! ERR! stack Error: not found: make
    ! gyp ERR! stack at F (/usr/local/lib/node_modules/npm/node_modules/which/which.js:63:19)
    ! gyp ERR! stack at E (/usr/local/lib/node_modules/npm/node_modules/which/which.js:72:29)gyp ERR! stack at /usr/local/lib/node_modules/npm/node_modules/which/which.js:81:16
    ! gyp ERR! stack at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
    ! gyp ERR! stack at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
    ! gyp ERR! stack at FSReqWrap.oncomplete (fs.js:82:15)
    ! gyp ERR! System Linux 3.10.77
    ! gyp ERR! command "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    ! gyp ERR! cwd /volume1/iobroker/node_modules/iobroker.sql/node_modules/sql-client/node_modules/inote-util/node_modules/mmmagic
    ! gyp ERR! node -v v4.4.2
    ! gyp ERR! node-gyp -v v3.3.1
    ! gyp ERR! not ok
    ! node-pre-gyp
    ! ERR! Tried to download(403): https://mapbox-node-binary.s3.amazonaws ... arm.tar.gz node-pre-gyp
    ! ERR! Pre-built binaries not found for sqlite3@3.1.8 and node@4.4.2 (node-v46 ABI) (falling back to source compile with node-gyp)
    ! gyp
    ! ERR! build error
    ! gyp
    ! ERR! stack Error: not found: makegyp ERR! stack
    ! at F (/volume1/@appstore/Node.js_v4/usr/local/lib/node_modules/npm/node_modules/which/which.js:63:19)
    ! gyp
    ! ERR! stack at E (/volume1/@appstore/Node.js_v4/usr/local/lib/node_modules/npm/node_modules/which/which.js:72:29)gyp ERR! stack at /volume1/@appstore/Node.js_v4/usr/local/lib/node_modules/npm/node_modules/which/which.js:81:16
    ! gyp ERR! stack at /volume1/@appstore/Node.js_v4/usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5gyp ERR!
    ! stack at /volume1/@appstore/Node.js_v4/usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5gyp ERR! stack at FSReqWrap.oncomplete (fs.js:82:15)
    ! gyp ERR! command "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/volume1/@appstore/Node.js_v4/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/volume1/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/lib/binding/node-v46-linux-arm/node_sqlite3.node" "--module_name=node_sqlite3" "--module_path=/volume1/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/lib/binding/node-v46-linux-arm"gyp
    ! ERR! cwd /volume1/iobroker/node_modules/iobroker.sql/node_modules/sqlite3gyp ERR! node -v v4.4.2
    ! gyp ERR! not ok
    ! node-pre-gyp ERR! build error
    ! node-pre-gyp ERR! stack Error: Failed to execute '/volume1/@appstore/Node.js_v4/usr/local/bin/node /volume1/@appstore/Node.js_v4/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/volume1/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/lib/binding/node-v46-linux-arm/node_sqlite3.node --module_name=node_sqlite3 --module_path=/volume1/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/lib/binding/node-v46-linux-arm' (1)node-pre-gyp ERR!
    ! stack at ChildProcess. <anonymous>(/volume1/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack at emitTwo (events.js:87:13)
    ! node-pre-gyp ERR! stack at ChildProcess.emit (events.js:172:7)
    ! node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:827:16)
    ! node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)node-pre-gyp ERR! System Linux 3.10.77
    ! node-pre-gyp ERR! command "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/volume1/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    ! node-pre-gyp ERR! cwd /volume1/iobroker/node_modules/iobroker.sql/node_modules/sqlite3
    ! node-pre-gyp ERR! node -v v4.4.2
    ! node-pre-gyp ERR! node-pre-gyp -v v0.6.31
    ! node-pre-gyp ERR! not ok
    ! npm WARN optional dep failed, continuing sqlite3@3.1.8
    ! npm
    ! ERR! Linux 3.10.77npm ERR! argv "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.sql" "--production" "--prefix" "/volume1/iobroker"
    ! npm ERR! node v4.4.2npm ERR! npm v2.15.0
    ! npm ERR! code ELIFECYCLE
    ! npm ERR! mmmagic@0.4.5 install: node-gyp rebuild
    ! npm ERR! Exit status 1
    ! npm ERR!
    ! npm ERR! Failed at the mmmagic@0.4.5 install script 'node-gyp rebuild'.
    ! npm
    ! ERR! This is most likely a problem with the mmmagic package,npm ERR! not with npm itself.
    ! npm ERR! Tell the author that this fails on your system:
    ! npm ERR! node-gyp rebuild
    ! npm ERR!
    ! You can get information on how to open an issue for this project with:npm ERR!
    ! npm bugs mmmagicnpm ERR! Or if that isn't available, you can get their info via:
    ! npm ERR!
    ! npm ERR! npm owner ls mmmagic
    ! npm ERR! There is likely additional logging output above.
    ! npm ERR! Please include the following file with any support request:npm ERR! /volume1/npm-debug.log
    ! ERROR: host.etv-nas-1 Cannot install iobroker.sql: 1
    ! ERROR: process exited with code 25</anonymous>
    Sollte ich mir Sorgen machen :?:
    Schöne Grüße
    tom
    EDIT: History is nun tot…..er meint zwar die 1.4.0 zu haben, startet aber nicht....hab dann den Adapter gelöscht in der Hoffnung den alten (1.3.2) installieren zu können, im Admin ist aber die Option mit der Versionswahl leider ausgegraut..... :?
    EDIT: Thread Title angepasst.....
    …ist schon sehr lange begeisterter ioBroker Nutzer! 1x zu Hause und 1x auf der Alm. ioBroker ist das 'Hirn' des Smarthome und steuert HomeMatic und Shellys, loggt was so passiert, zeigt es auf Tabletts schön an und ermöglicht mir via Cloud Adapter den Fernzugriff...
    • apollon77A Online
      apollon77A Online
      In der 1.3.3 ist die verwendete "sql-client" library geupgraded worden. Scheinbar ist da dann eine Abhängigkeit zu mmagic drin als Abhängigkeit. Die ist zickig …
      Für die tests hat es gereicht "libmagic" zu installieren (wie auch immer auf Synology) oder einen G++4.8 COmpiler verfügbar zu haben.
      Hm, sieht nach ner Synology aus, korrekt? Welche denn genau?
      Wenn Du auf der Kommandozeile "gcc -v" und "g++ -v" ausführst was kommt da?
      • apollon77A Online
        apollon77A Online
        Zum Update im Admin: Du brauchst auch das ganz aktuellste js-controller =0.14 glaub ich) … erst dann tut das.
        • etvE Offline
          etvE Offline
          etv
          @apollon77:
          Zum Update im Admin: Du brauchst auch das ganz aktuellste js-controller =0.14 glaub ich) … erst dann tut das. `
          …danke für deine Hilfe. Sobald ich "am Gerät bin" probier ich das alles aus und berichte dann hier!
          Liebe Grüße
          tom
            BlueEssi
            ist hier die Rede vom SQL History-Adapter? Ich habe nämlich das gleiche Problem unter Windows.
              akamia
              Dito, bin wieder auf der 1.3.2.
              NUC6i3 / ProxMox / HM/FHEM/WifiLight/HUE/Tradfri/KM200/InfluxDB/RFlink/Plex/Smartmeter
              piVCCU, Arduinos, X4000, Z2000, Solo4K, SAMSUNG C & H, NAS OMV4/Win10Pro (JRMC/JRemote), 4x4 HDMImatrix, ...
              • apollon77A Online
                apollon77A Online
                Dann bitte mal die gleichen Fragen beantworten wie oben gestellt:
                • Euer System?
                • gcc -v
                • g++ -v
                • Wie sind die genauen Ausgaben. Bitte posten!
                Unter Linux bitte mal versuchen ob es nach
                apt-get install build-essential
                tut. (keine ahnung wie man das bei Synology machen muss …)
                Wenn nicht (oder wenn schon installiert dann mal bitte
                apt-get install g++-4.8
                und vor der installation ggf noch
                export CXX=g++-4.8; export CC=gcc-4.8;
                versuchen
                versuchen. Alternativ wäre noch
                apt-get install libmagic1
                eine Idee (so klappts auf mac zumindestens besser)
                Unter Windows bitte mal
                npm install --global windows-build-tools
                versuchen ob es danach tut.
                Bei mir unter Ubuntu 16.04 auf Cubietruck tut alles.
                @Homoran: Kannst Du vllt mal deinen Hardware-Zoo darauf ansetzen? :-)
                Alle Infos helfen, dann kann ich die Adapter README updaten. Eure Unterstützung wäre super!
                Ingo F
                  @apollon77:
                  @Homoran: Kannst Du vllt mal deinen Hardware-Zoo darauf ansetzen? :-) `
                  gerne, aber worauf soll ich da achten?
                  Ich meine gestern ohne Probleme den pine64 auf 1.4.0 upgedated zu haben - hatte ich jedoch spät abends vom tablet gemacht und dann war ich da im timeout. Fehler im Log waren anschließend nicht drin.
                  Muss heute abend nochmal über den PC nachsehen. bin jetzt im Büro
                  Vorab:
                  @apollon77:
                  tut. `
                  sollte in allen meinen Installationen drin und aktuell sein.
                  Mac und Windows hab ich nicht
                  Rainer
                  • apollon77A Online
                    apollon77A Online
                    Ich denke das "aktuelle OSe" kein so großes Problem darstellen. Auf dem Pine ist ein Debian Jessie?
                    Raspi wäre denke ich interessant und naja Synology ist ein Spezialfall der immer wieder Probleme machen wird es sei denn man kann wirklich eigene Pakete nachinstallieren
                      @apollon77:
                      Auf dem Pine ist ein Debian Jessie? `
                      Ja, aktuelle (Beta-) Version vom Armbian (ich meine Kernel 4.xx)
                      Rainer
                      • apollon77A Online
                        apollon77A Online
                        Naja mal schauen was die weiteren Problemkandidaten (neben der Synology) sind. Ältere OS (Raspbian Wheezy glaube ich) haben halt den g++4,8 nicht dabei und damit wird immer mehr schwierig
                          Mit so etwas antiken beschäftige ich mich doch gar nicht :D
                          Aber im Ernst: ich glaube da war etwas in der Richtung (mit g++), was es schwierig machte unter Wheezy auf node 4.xx zu wechseln.
                          Rainer
                          • apollon77A Online
                            apollon77A Online
                            Ne dfas war die libc version …
                            Naja mal schauen was die anderen betroffenen Nutzer oben zu Ihren Systemen schreiben
                              Habe gerade mal nachgesehen.
                              Seid ihr sicher, dass ihr vom History-Adapter redet?
                              Da habe ich die v1.5.0 :shock:
                              admin 1.6.8
                              controller 0.14.0
                              Rainer
                              • apollon77A Online
                                apollon77A Online
                                Es geht um den SQL-History-Adapter :-) ääähm ja, der Thread Tittel ist misleading :-)
                                Kannste mal "ioBroker.sql" updaten/installieren ? :-)
                                  @apollon77:
                                  Kannste mal "ioBroker.sql" updaten/installieren ? `
                                  läuft, dauert aber anscheinend Stunden.
                                  Die ersten Meldungen:
                                  gyp
                                   WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/4.6.1"
                                  gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.sql/node_modules/sql-client/node_modules/inote-util/node_modules/mmmagic/.node-gyp"
                                  haben mich wieder daran erinnert, dass es sich hier um meine Installation mittels sudo handelt.
                                  Mal sehen was dabei rauskommt :(
                                  EDIT:
                                  Sowas kommt dabei raus:
                                  $ ./iobroker add sql
                                  npm install iobroker.sql --production --prefix "/opt/iobroker" (System call)
                                  npm
                                  gyp
                                  ../deps/libmagic/pcre/pcre_jit_compile.c:65:2: error: #error Unsupported architecture #error Unsupported architecture
                                  ! make: *** [Release/obj.target/libpcre/deps/libmagic/pcre/pcre_jit_compile.o] Error 1
                                  gyp
                                  ERR! build error
                                  gyp
                                  ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                                  ! gyp ERR! stack at emitTwo (events.js:87:13)gyp ERR! stack at ChildProcess.emit (events.js:172:7)
                                  gyp
                                  ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
                                  gyp ERR! System Linux 3.10.104-pine64gyp
                                  ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.sql/node_modules/sql-client/node_modules/inote-util/node_modules/mmmagic
                                  gyp ERR! node -v v4.6.1
                                  gyp ERR! node-gyp -v v3.4.0
                                  gyp ERR! not ok
                                  ! node-pre-gyp
                                  ERR! Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v3.1.8/node-v46-linux-arm64.tar.gz node-pre-gyp
                                  ERR! Pre-built binaries not found for sqlite3@3.1.8 and node@4.6.1 (node-v46 ABI) (falling back to source compile with node-gyp)
                                  gyp
                                  WARN
                                  gyp
                                  WARN EACCES
                                  attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/.node-gyp"
                                  make: *** No rule to make target '../.node-gyp/4.6.1/include/node/common.gypi', needed by 'Makefile'. Stop.
                                  gyp
                                  ERR! build error
                                  gyp ERR! stack Error: make failed with exit code: 2gyp ERR!
                                  stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp ERR! stack
                                  gyp ERR! stack at ChildProcess.emit (events.js:172:7)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
                                  ! gyp
                                  ERR! System Linux 3.10.104-pine64gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/lib/binding/node-v46-linux-arm64/node_sqlite3.node" "--module_name=node_sqlite3" "--module_path=/opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/lib/binding/node-v46-linux-arm64"
                                  ! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3gyp ERR! node -v v4.6.1
                                  gyp ERR! not ok
                                  ! node-pre-gyp
                                  ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/lib/binding/node-v46-linux-arm64/node_sqlite3.node --module_name=node_sqlite3 --module_path=/opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/lib/binding/node-v46-linux-arm64' (1)node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                  node-pre-gyp
                                  ERR! stack at ChildProcess.emit (events.js:172:7)node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:829:16)
                                  node-pre-gyp ERR! System Linux 3.10.104-pine64
                                  ! node-pre-gyp ERR! command "/usr/local/bin/node" "/opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3
                                  node-pre-gyp ERR! node -v v4.6.1
                                  ! npm
                                  npm
                                  ERR! Linux 3.10.104-pine64
                                  npm ERR!
                                  argv
                                  "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.sql" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.6.1
                                  npm ERR! npm v2.15.9
                                  npm
                                  ERR! Exit status 1npm ERR!
                                  npm ERR! This is most likely a problem with the mmmagic package,
                                  npm ERR! You can get information on how to open an issue for this project with:
                                  npm ERR! npm bugs mmmagic
                                  npm ERR!
                                  ! npm
                                  ERR! /opt/npm-debug.log
                                  ERROR: host.ioBroker_Pine64 Cannot install iobroker.sql: 1
                                  Rainer
                                    bin jetzt mit putty als root drauf:
                                    root@ioBroker_Pine64:~# chmod -R 777 /opt/iobroker
                                    root@ioBroker_Pine64:~# cd /opt/iobroker
                                    root@ioBroker_Pine64:/opt/iobroker# iobroker del sql
                                    host.ioBroker_Pine64 no instances of adapter sql found
                                    kann ich verstehen, denn unter /opt/iobroker/node_modules ist kein Ordner iobroker.sql
                                    Werde jetzt von der Konsole iobroker add sql ausführen
                                    Auch hier ein EDIT:
                                    Ich habe natürlich keine SQL Installation auf dem Pine64!
                                    Rainer
                                      und nochmal.
                                      Hier das log:
                                      ! root@ioBroker_Pine64:/opt/iobroker# iobroker add sql npm install iobroker.sql --production --prefix "/opt/iobroker" (System call) npm WARN deprecated node-uuid@1.4.7: use uuid module instead ../deps/libmagic/pcre/pcre_jit_compile.c:65:2: error: #error Unsupported architecture #error Unsupported architecture ^ make: *** [Release/obj.target/libpcre/deps/libmagic/pcre/pcre_jit_compile.o] Error 1 gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2 gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23) gyp ERR! stack at emitTwo (events.js:87:13) gyp ERR! stack at ChildProcess.emit (events.js:172:7) gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12) gyp ERR! System Linux 3.10.104-pine64 gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" gyp ERR! cwd /opt/iobroker/node_modules/iobroker.sql/node_modules/sql-client/node_modules/inote-util/node_modules/mmmagic gyp ERR! node -v v4.6.1 gyp ERR! node-gyp -v v3.4.0 gyp ERR! not ok node-pre-gyp ERR! Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v3.1.8/node-v46-linux-arm64.tar.gz node-pre-gyp ERR! Pre-built binaries not found for sqlite3@3.1.8 and node@4.6.1 (node-v46 ABI) (falling back to source compile with node-gyp) ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginOpen(node_sqlite3::Database::Baton*)’: ../src/database.cc:144:9: warning: unused variable ‘status’ [-Wunused-variable] int status = uv_queue_work(uv_default_loop(), ^ ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginClose(node_sqlite3::Database::Baton*)’: ../src/database.cc:230:9: warning: unused variable ‘status’ [-Wunused-variable] int status = uv_queue_work(uv_default_loop(), ^ ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginExec(node_sqlite3::Database::Baton*)’: ../src/database.cc:525:9: warning: unused variable ‘status’ [-Wunused-variable] int status = uv_queue_work(uv_default_loop(), ^ ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginLoadExtension(node_sqlite3::Database::Baton*)’: ../src/database.cc:625:9: warning: unused variable ‘status’ [-Wunused-variable] int status = uv_queue_work(uv_default_loop(), ^ ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginPrepare(node_sqlite3::Database::Baton*)’: ../src/statement.cc:118:9: warning: unused variable ‘status’ [-Wunused-variable] int status = uv_queue_work(uv_default_loop(), ^ In file included from ../src/statement.cc:6:0: ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginBind(node_sqlite3::Statement::Baton*)’: ../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable] int status = uv_queue_work(uv_default_loop(), \ ^ ../src/statement.cc:322:5: note: in expansion of macro ‘STATEMENT_BEGIN’ STATEMENT_BEGIN(Bind); ^ ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginGet(node_sqlite3::Statement::Baton*)’: ../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable] int status = uv_queue_work(uv_default_loop(), \ ^ ../src/statement.cc:370:5: note: in expansion of macro ‘STATEMENT_BEGIN’ STATEMENT_BEGIN(Get); ^ ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginRun(node_sqlite3::Statement::Baton*)’: ../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable] int status = uv_queue_work(uv_default_loop(), \ ^ ../src/statement.cc:438:5: note: in expansion of macro ‘STATEMENT_BEGIN’ STATEMENT_BEGIN(Run); ^ ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginAll(node_sqlite3::Statement::Baton*)’: ../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable] int status = uv_queue_work(uv_default_loop(), \ ^ ../src/statement.cc:504:5: note: in expansion of macro ‘STATEMENT_BEGIN’ STATEMENT_BEGIN(All); ^ ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginEach(node_sqlite3::Statement::Baton*)’: ../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable] int status = uv_queue_work(uv_default_loop(), \ ^ ../src/statement.cc:601:5: note: in expansion of macro ‘STATEMENT_BEGIN’ STATEMENT_BEGIN(Each); ^ ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginReset(node_sqlite3::Statement::Baton*)’: ../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable] int status = uv_queue_work(uv_default_loop(), \ ^ ../src/statement.cc:724:5: note: in expansion of macro ‘STATEMENT_BEGIN’ STATEMENT_BEGIN(Reset); ^ npm ERR! Linux 3.10.104-pine64 npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.sql" "--production" "--prefix" "/opt/iobroker" npm ERR! node v4.6.1 npm ERR! npm v2.15.9 npm ERR! code ELIFECYCLE ! npm ERR! mmmagic@0.4.5 install: `node-gyp rebuild` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the mmmagic@0.4.5 install script 'node-gyp rebuild'. npm ERR! This is most likely a problem with the mmmagic package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! node-gyp rebuild npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs mmmagic npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm ERR! npm owner ls mmmagic npm ERR! There is likely additional logging output above. ! npm ERR! Please include the following file with any support request: npm ERR! /opt/iobroker/npm-debug.log host.ioBroker_Pine64 Cannot install iobroker.sql: 1 root@ioBroker_Pine64:/opt/iobroker# !
                                      Was mir direkt ins Auge sprang:
                                      Rainer
                                        Nachdem es hier so ruhig bleibt ;-) habe ich mich durchj Internet gequält.
                                        Dann habe ich festgestellt, dass mit mmmagic wahrscheinlich https://www.npmjs.com/package/mmmagic gemeint ist.
                                        Habe versucht das zu installieren, aber….
                                        root@ioBroker_Pine64:/opt/iobroker# npm install mmmagic
                                        mmmagic@0.4.5 install /opt/iobroker/node_modules/mmmagic
                                        node-gyp rebuild
                                        ! make: Entering directory '/opt/iobroker/node_modules/mmmagic/build'
                                        CC(target) Release/obj.target/libmagic/deps/libmagic/src/apprentice.o
                                        CC(target) Release/obj.target/libmagic/deps/libmagic/src/apptype.o
                                        CC(target) Release/obj.target/libmagic/deps/libmagic/src/ascmagic.o
                                        CC(target) Release/obj.target/libmagic/deps/libmagic/src/cdf.o
                                        CC(target) Release/obj.target/libmagic/deps/libmagic/src/cdf_time.o
                                        CC(target) Release/obj.target/libmagic/deps/libmagic/src/compress.o
                                        CC(target) Release/obj.target/libmagic/deps/libmagic/src/der.o
                                        CC(target) Release/obj.target/libmagic/deps/libmagic/src/encoding.o
                                        CC(target) Release/obj.target/libmagic/deps/libmagic/src/fsmagic.o
                                        CC(target) Release/obj.target/libmagic/deps/libmagic/src/funcs.o
                                        CC(target) Release/obj.target/libmagic/deps/libmagic/src/is_tar.o
                                        CC(target) Release/obj.target/libmagic/deps/libmagic/src/magic.o
                                        CC(target) Release/obj.target/libmagic/deps/libmagic/src/print.o
                                        CC(target) Release/obj.target/libmagic/deps/libmagic/src/readcdf.o
                                        CC(target) Release/obj.target/libmagic/deps/libmagic/src/readelf.o
                                        CC(target) Release/obj.target/libmagic/deps/libmagic/src/softmagic.o
                                        CC(target) Release/obj.target/libmagic/deps/libmagic/src/fmtcheck.o
                                        CC(target) Release/obj.target/libmagic/deps/libmagic/src/strlcat.o
                                        CC(target) Release/obj.target/libmagic/deps/libmagic/src/strlcpy.o
                                        AR(target) Release/obj.target/deps/libmagic/magic.a
                                        COPY Release/magic.a
                                        CC(target) Release/obj.target/libpcre/deps/libmagic/pcre/pcre_byte_order.o
                                        CC(target) Release/obj.target/libpcre/deps/libmagic/pcre/pcre_chartables.o
                                        CC(target) Release/obj.target/libpcre/deps/libmagic/pcre/pcre_compile.o
                                        CC(target) Release/obj.target/libpcre/deps/libmagic/pcre/pcre_config.o
                                        CC(target) Release/obj.target/libpcre/deps/libmagic/pcre/pcre_dfa_exec.o
                                        CC(target) Release/obj.target/libpcre/deps/libmagic/pcre/pcre_exec.o
                                        CC(target) Release/obj.target/libpcre/deps/libmagic/pcre/pcre_fullinfo.o
                                        CC(target) Release/obj.target/libpcre/deps/libmagic/pcre/pcre_get.o
                                        CC(target) Release/obj.target/libpcre/deps/libmagic/pcre/pcre_globals.o
                                        CC(target) Release/obj.target/libpcre/deps/libmagic/pcre/pcre_jit_compile.o
                                        deps/libmagic/pcre/libpcre.target.mk:129: recipe for target 'Release/obj.target/libpcre/deps/libmagic/pcre/pcre_jit_compile.o' failed
                                        make: Leaving directory '/opt/iobroker/node_modules/mmmagic/build'
                                        gyp ERR! cwd /opt/iobroker/node_modules/mmmagic
                                        gyp ERR! not ok
                                        npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "mmmagic"
                                        npm ERR!
                                        npm ERR!
                                        kann natürlich wieder an meiner 64Bit Umgebung auf dem Pine64 liegen.
                                        Werde da jetzt auch erst mal nicht weitermachen, da es meine Produktivumgebung ist.
                                        Wie bekomme ich es da jetzt wieder runter?
                                        So jedenfalls nicht:
                                        root@ioBroker_Pine64:/opt/iobroker# npm uninstall mmmagic
                                        npm WARN uninstall not installed in /opt/iobroker/node_modules: "mmmagic"
                                        oder heisst das, dass da wirklich nichts hängengeblieben ist?
                                        Mache jetzt auf dem Cubie weiter.
                                        Rainer
                                          So: Monolog die fünfte ;-)
                                          Auf dem Cubie läuft der Adapter.
                                          Installation im Admin hatte leider ein paar Hindernisse.
                                          Ich Depp habe das Installationsfenster geschlossen, daher habe ich keine durchgehende Doku über die Meldungen.
                                          Habe mal versucht dies aus dem Log noch zu extrahieren, hoffentlich nicht zuviel gelöscht:
                                          sql.0 2016-12-21 19:02:25.092 info Connected to sqlite
                                          sql.0 2016-12-21 19:02:22.724 info starting. Version 1.4.0 in /opt/iobroker/node_modules/iobroker.sql, node: v6.9.2
                                          host. 2016-12-21 19:02:22.466 info States connected to redis 127.0.0.1:6379
                                          iobroker 2016-12-21 19:02:13.079 info exit 0
                                          iobroker 2016-12-21 19:02:12.909 info host.ioBroker_Cubie object system.adapter.sql.0 created
                                          host.ioBroker_Cubie 2016-12-21 19:02:12.862 info instance system.adapter.sql.0 started with pid 13487
                                          host.ioBroker_Cubie 2016-12-21 19:02:12.736 info object change system.adapter.sql.0
                                          iobroker 2016-12-21 19:02:12.681 info host.ioBroker_Cubie object system.adapter.sql.0.alive created
                                          iobroker 2016-12-21 19:02:12.639 info host.ioBroker_Cubie object system.adapter.sql.0.connected created
                                          iobroker 2016-12-21 19:02:12.595 info host.ioBroker_Cubie object system.adapter.sql.0.memHeapUsed created
                                          iobroker 2016-12-21 19:02:12.552 info host.ioBroker_Cubie object system.adapter.sql.0.memHeapTotal created
                                          iobroker 2016-12-21 19:02:12.508 info host.ioBroker_Cubie object system.adapter.sql.0.memRss created
                                          iobroker 2016-12-21 19:02:12.462 info host.ioBroker_Cubie object system.adapter.sql.0.uptime created
                                          iobroker 2016-12-21 19:02:12.426 info host.ioBroker_Cubie create instance sql
                                          iobroker 2016-12-21 19:02:12.251 info host.ioBroker_Cubie object _design/custom created
                                          iobroker 2016-12-21 19:02:12.182 info host.ioBroker_Cubie object system.adapter.sql created
                                          iobroker 2016-12-21 19:02:11.672 info upload [0] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/custom.html custom.html text/html
                                          iobroker 2016-12-21 19:02:11.444 info upload [1] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index.html index.html text/html
                                          iobroker 2016-12-21 19:02:11.162 info upload [2] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/sql.png sql.png image/png
                                          iobroker 2016-12-21 19:02:11.122 info got /opt/iobroker/node_modules/iobroker.sql/admin
                                          iobroker 2016-12-21 19:01:37.459 info ^
                                          iobroker 2016-12-21 19:01:37.459 info STATEMENT_BEGIN(Reset);
                                          iobroker 2016-12-21 19:01:37.459 info ../src/statement.cc:724:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                          iobroker 2016-12-21 19:01:37.459 info int status = uv_queue_work(uv_default_loop(),
                                          iobroker 2016-12-21 19:01:37.459 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginReset(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
                                          iobroker 2016-12-21 19:01:37.379 info ^
                                          iobroker 2016-12-21 19:01:37.379 info STATEMENT_BEGIN(Each);
                                          iobroker 2016-12-21 19:01:37.379 info ../src/statement.cc:601:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                          iobroker 2016-12-21 19:01:37.379 info int status = uv_queue_work(uv_default_loop(),
                                          iobroker 2016-12-21 19:01:37.379 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginEach(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
                                          iobroker 2016-12-21 19:01:37.305 info ^
                                          iobroker 2016-12-21 19:01:37.305 info STATEMENT_BEGIN(All);
                                          iobroker 2016-12-21 19:01:37.305 info ../src/statement.cc:504:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                          iobroker 2016-12-21 19:01:37.305 info int status = uv_queue_work(uv_default_loop(),
                                          iobroker 2016-12-21 19:01:37.305 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginAll(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
                                          iobroker 2016-12-21 19:01:37.219 info ^
                                          iobroker 2016-12-21 19:01:37.219 info STATEMENT_BEGIN(Run);
                                          iobroker 2016-12-21 19:01:37.219 info ../src/statement.cc:438:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                          iobroker 2016-12-21 19:01:37.219 info int status = uv_queue_work(uv_default_loop(),
                                          iobroker 2016-12-21 19:01:37.219 info ../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
                                          iobroker 2016-12-21 19:01:37.219 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginRun(node_sqlite3::Statement::Baton*)’:
                                          iobroker 2016-12-21 19:01:37.219 info STATEMENT_BEGIN(Get);
                                          iobroker 2016-12-21 19:01:37.219 info ../src/statement.cc:370:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                          iobroker 2016-12-21 19:01:37.219 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginGet(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
                                          iobroker 2016-12-21 19:01:37.193 info ^
                                          iobroker 2016-12-21 19:01:37.193 info STATEMENT_BEGIN(Bind);
                                          iobroker 2016-12-21 19:01:37.193 info ../src/statement.cc:322:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                          iobroker 2016-12-21 19:01:37.193 info int status = uv_queue_work(uv_default_loop(),
                                          iobroker 2016-12-21 19:01:37.193 info ../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
                                          iobroker 2016-12-21 19:01:37.193 info In file included from ../src/statement.cc:6:0:../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginBind(node_sqlite3::Statement::Baton*)’:
                                          iobroker 2016-12-21 19:01:37.132 info ^
                                          iobroker 2016-12-21 19:01:37.132 info int status = uv_queue_work(uv_default_loop(),
                                          iobroker 2016-12-21 19:01:37.132 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginPrepare(node_sqlite3::Database::Baton*)’:../src/statement.cc:118:9: warning: unused variable ‘status’ [-Wunused-variable]
                                          iobroker 2016-12-21 19:01:37.106 info ^
                                          iobroker 2016-12-21 19:01:37.106 info info.This()->ForceSet(Nan::New('sql').ToLocalChecked(), sql, ReadOnly);
                                          iobroker 2016-12-21 19:01:37.106 info ../src/statement.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE node_sqlite3::Statement::New(Nan::NAN_METHOD_ARGS_TYPE)’:../src/statement.cc:103:74: warning: ‘bool v8::Object::ForceSet(v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated (declared at /root/.node-gyp/6.9.2/include/node/v8.h:2694): Use CreateDataProperty / DefineOwnProperty [-Wdeprecated-declarations]
                                          iobroker 2016-12-21 19:01:07.102 info ^
                                          iobroker 2016-12-21 19:01:07.102 info int status = uv_queue_work(uv_default_loop(),
                                          iobroker 2016-12-21 19:01:07.102 info ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginLoadExtension(node_sqlite3::Database::Baton*)’:../src/database.cc:625:9: warning: unused variable ‘status’ [-Wunused-variable]
                                          iobroker 2016-12-21 19:01:07.060 info ^
                                          iobroker 2016-12-21 19:01:07.060 info int status = uv_queue_work(uv_default_loop(),
                                          iobroker 2016-12-21 19:01:07.060 info ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginExec(node_sqlite3::Database::Baton*)’:../src/database.cc:525:9: warning: unused variable ‘status’ [-Wunused-variable]
                                          iobroker 2016-12-21 19:01:06.805 info ^
                                          iobroker 2016-12-21 19:01:06.805 info int status = uv_queue_work(uv_default_loop(),
                                          iobroker 2016-12-21 19:01:06.805 info ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginClose(node_sqlite3::Database::Baton*)’:../src/database.cc:230:9: warning: unused variable ‘status’ [-Wunused-variable]
                                          iobroker 2016-12-21 19:01:06.761 info ^
                                          iobroker 2016-12-21 19:01:06.761 info int status = uv_queue_work(uv_default_loop(),
                                          iobroker 2016-12-21 19:01:06.761 info ../src/database.cc:144:9: warning: unused variable ‘status’ [-Wunused-variable]
                                          iobroker 2016-12-21 19:01:06.761 info ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginOpen(node_sqlite3::Database::Baton*)’:
                                          iobroker 2016-12-21 19:01:06.761 info ../src/database.cc:134:86: warning: ‘bool v8::Object::ForceSet(v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated (declared at /root/.node-gyp/6.9.2/include/node/v8.h:2694): Use CreateDataProperty / DefineOwnProperty [-Wdeprecated-declarations] info.This()->ForceSet(Nan::New('mode').ToLocalChecked(), Nan::New(mode), ReadOnly);
                                          iobroker 2016-12-21 19:01:06.745 info ^
                                          iobroker 2016-12-21 19:01:06.745 info info.This()->ForceSet(Nan::New('filename').ToLocalChecked(), info[0].As(), ReadOnly);
                                          iobroker 2016-12-21 19:01:06.745 info ../src/database.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE node_sqlite3::Database::New(Nan::NAN_METHOD_ARGS_TYPE)’:../src/database.cc:133:96: warning: ‘bool v8::Object::ForceSet(v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated (declared at /root/.node-gyp/6.9.2/include/node/v8.h:2694): Use CreateDataProperty / DefineOwnProperty [-Wdeprecated-declarations]
                                          iobroker 2016-12-21 18:52:16.538 info ERR! Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v3.1.8/node-v48-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for sqlite3@3.1.8 and node@6.9.2 (node-v48 ABI) (falling back to source compile with node-gyp)
                                          iobroker 2016-12-21 18:52:16.527 info node-pre-gyp
                                          iobroker 2016-12-21 18:50:50.883 info ^
                                          iobroker 2016-12-21 18:50:50.883 info static sljit_si getput_arg(struct sljit_compiler compiler, sljit_si flags, sljit_si reg, sljit_si arg, sljit_sw argw, sljit_si next_arg, sljit_sw next_argw)
                                          iobroker 2016-12-21 18:50:50.883 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:1019:148: warning: parameter ‘next_argw’ set but not used [-Wunused-but-set-parameter]
                                          iobroker 2016-12-21 18:50:50.883 info sljit_si tmp_r;
                                          iobroker 2016-12-21 18:50:50.883 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c: In function ‘getput_arg’:../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:1021:11: warning: variable ‘tmp_r’ set but not used [-Wunused-but-set-variable]
                                          iobroker 2016-12-21 18:50:50.867 info ^
                                          iobroker 2016-12-21 18:50:50.867 info if (value != INVALID_IMM)
                                          iobroker 2016-12-21 18:50:50.867 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:905:13: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                          iobroker 2016-12-21 18:50:50.867 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:897:13: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                          iobroker 2016-12-21 18:50:50.867 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c: In function ‘emit_set_delta’:
                                          iobroker 2016-12-21 18:50:50.867 info if (dst == arg1 && !(flags & KEEP_FLAGS) && IS_2_LO_REGS(dst, arg2))
                                          iobroker 2016-12-21 18:50:50.867 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:800:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                          iobroker 2016-12-21 18:50:50.867 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:796:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                          iobroker 2016-12-21 18:50:50.867 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:792:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if (dst == arg1 && !(flags & KEEP_FLAGS) && IS_2_LO_REGS(dst, arg2))
                                          iobroker 2016-12-21 18:50:50.833 info ^
                                          iobroker 2016-12-21 18:50:50.833 info if (dst == arg1 && !(flags & KEEP_FLAGS) && IS_2_LO_REGS(dst, arg2))
                                          iobroker 2016-12-21 18:50:50.833 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:788:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                          iobroker 2016-12-21 18:50:50.833 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:784:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                          iobroker 2016-12-21 18:50:50.833 info if (dst == arg1 && IS_2_LO_REGS(dst, arg2))
                                          iobroker 2016-12-21 18:50:50.833 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:777:12: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                          iobroker 2016-12-21 18:50:50.833 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:765:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                          iobroker 2016-12-21 18:50:50.833 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:757:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                          iobroker 2016-12-21 18:50:50.833 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:753:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if (dst == arg1 && !(flags & SET_FLAGS))
                                          iobroker 2016-12-21 18:50:50.815 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c: In function ‘emit_op_imm’:
                                          iobroker 2016-12-21 18:50:50.815 info In file included from ../deps/libmagic/pcre/sljit/sljitLir.c:1333:0, from ../deps/libmagic/pcre/pcre_jit_compile.c:62:
                                          iobroker 2016-12-21 18:43:46.296 info node-uuid@1.4.7: use uuid module instead
                                          iobroker 2016-12-21 18:43:46.290 info npm WARN deprecated
                                          iobroker 2016-12-21 18:42:35.521 info host.ioBroker_Cubie install adapter sqlnpm install --production --prefix '/opt/iobroker/node_modules/iobroker.sql' (System call)
                                          iobroker 2016-12-21 18:41:27.018 info ^
                                          iobroker 2016-12-21 18:41:27.018 info STATEMENT_BEGIN(Reset);
                                          iobroker 2016-12-21 18:41:27.018 info ../src/statement.cc:724:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                          iobroker 2016-12-21 18:41:27.018 info int status = uv_queue_work(uv_default_loop(),
                                          iobroker 2016-12-21 18:41:27.018 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginReset(node_sqlite3::Statement::Baton
                                          iobroker 2016-12-21 18:41:26.925 info ^
                                          iobroker 2016-12-21 18:41:26.925 info STATEMENT_BEGIN(Each);
                                          iobroker 2016-12-21 18:41:26.925 info ../src/statement.cc:601:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                          iobroker 2016-12-21 18:41:26.925 info int status = uv_queue_work(uv_default_loop(),
                                          iobroker 2016-12-21 18:41:26.925 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginEach(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
                                          iobroker 2016-12-21 18:41:26.853 info ^
                                          iobroker 2016-12-21 18:41:26.853 info STATEMENT_BEGIN(All);
                                          iobroker 2016-12-21 18:41:26.853 info ../src/statement.cc:504:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                          iobroker 2016-12-21 18:41:26.853 info int status = uv_queue_work(uv_default_loop(),
                                          iobroker 2016-12-21 18:41:26.853 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginAll(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
                                          iobroker 2016-12-21 18:41:26.810 info ^
                                          iobroker 2016-12-21 18:41:26.810 info STATEMENT_BEGIN(Run);
                                          iobroker 2016-12-21 18:41:26.810 info ../src/statement.cc:438:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                          iobroker 2016-12-21 18:41:26.810 info int status = uv_queue_work(uv_default_loop(),
                                          iobroker 2016-12-21 18:41:26.810 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginRun(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
                                          iobroker 2016-12-21 18:41:26.774 info ^
                                          iobroker 2016-12-21 18:41:26.774 info STATEMENT_BEGIN(Get);
                                          iobroker 2016-12-21 18:41:26.774 info ../src/statement.cc:370:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                          iobroker 2016-12-21 18:41:26.774 info int status = uv_queue_work(uv_default_loop(),
                                          iobroker 2016-12-21 18:41:26.774 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginGet(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
                                          iobroker 2016-12-21 18:41:26.752 info ^
                                          iobroker 2016-12-21 18:41:26.752 info STATEMENT_BEGIN(Bind);
                                          iobroker 2016-12-21 18:41:26.752 info ../src/statement.cc:322:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                          iobroker 2016-12-21 18:41:26.752 info int status = uv_queue_work(uv_default_loop(),
                                          iobroker 2016-12-21 18:41:26.752 info ../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
                                          iobroker 2016-12-21 18:41:26.752 info In file included from ../src/statement.cc:6:0:../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginBind(node_sqlite3::Statement::Baton*)’:
                                          iobroker 2016-12-21 18:41:26.699 info ^
                                          iobroker 2016-12-21 18:41:26.699 info int status = uv_queue_work(uv_default_loop(),
                                          iobroker 2016-12-21 18:41:26.699 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginPrepare(node_sqlite3::Database::Baton*)’:../src/statement.cc:118:9: warning: unused variable ‘status’ [-Wunused-variable]
                                          iobroker 2016-12-21 18:41:26.665 info ^
                                          iobroker 2016-12-21 18:41:26.665 info info.This()->ForceSet(Nan::New('sql').ToLocalChecked(), sql, ReadOnly);
                                          iobroker 2016-12-21 18:41:26.665 info ../src/statement.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE node_sqlite3::Statement::New(Nan::NAN_METHOD_ARGS_TYPE)’:../src/statement.cc:103:74: warning: ‘bool v8::Object::ForceSet(v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated (declared at /root/.node-gyp/6.9.2/include/node/v8.h:2694): Use CreateDataProperty / DefineOwnProperty [-Wdeprecated-declarations]
                                          iobroker 2016-12-21 18:40:56.740 info ^
                                          iobroker 2016-12-21 18:40:56.740 info int status = uv_queue_work(uv_default_loop(),
                                          iobroker 2016-12-21 18:40:56.740 info ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginLoadExtension(node_sqlite3::Database::Baton*)’:../src/database.cc:625:9: warning: unused variable ‘status’ [-Wunused-variable]
                                          iobroker 2016-12-21 18:40:56.694 info ^
                                          iobroker 2016-12-21 18:40:56.694 info int status = uv_queue_work(uv_default_loop(),
                                          iobroker 2016-12-21 18:40:56.694 info ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginExec(node_sqlite3::Database::Baton*)’:../src/database.cc:525:9: warning: unused variable ‘status’ [-Wunused-variable]
                                          iobroker 2016-12-21 18:40:56.424 info ^
                                          iobroker 2016-12-21 18:40:56.424 info int status = uv_queue_work(uv_default_loop(),
                                          iobroker 2016-12-21 18:40:56.424 info ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginClose(node_sqlite3::Database::Baton*)’:../src/database.cc:230:9: warning: unused variable ‘status’ [-Wunused-variable]
                                          iobroker 2016-12-21 18:40:56.381 info ^
                                          iobroker 2016-12-21 18:40:56.381 info int status = uv_queue_work(uv_default_loop(),
                                          iobroker 2016-12-21 18:40:56.381 info ../src/database.cc:144:9: warning: unused variable ‘status’ [-Wunused-variable]
                                          iobroker 2016-12-21 18:40:56.381 info ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginOpen(node_sqlite3::Database::Baton*)’:
                                          iobroker 2016-12-21 18:40:56.381 info ../src/database.cc:134:86: warning: ‘bool v8::Object::ForceSet(v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated (declared at /root/.node-gyp/6.9.2/include/node/v8.h:2694): Use CreateDataProperty / DefineOwnProperty [-Wdeprecated-declarations] info.This()->ForceSet(Nan::New('mode').ToLocalChecked(), Nan::New(mode), ReadOnly);
                                          iobroker 2016-12-21 18:40:56.368 info ^
                                          iobroker 2016-12-21 18:40:56.368 info info.This()->ForceSet(Nan::New('filename').ToLocalChecked(), info[0].As(), ReadOnly);
                                          iobroker 2016-12-21 18:40:56.368 info ../src/database.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE node_sqlite3::Database::New(Nan::NAN_METHOD_ARGS_TYPE)’:../src/database.cc:133:96: warning: ‘bool v8::Object::ForceSet(v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated (declared at /root/.node-gyp/6.9.2/include/node/v8.h:2694): Use CreateDataProperty / DefineOwnProperty [-Wdeprecated-declarations]
                                          iobroker 2016-12-21 18:32:05.398 info Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v3.1.8/node-v48-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for sqlite3@3.1.8 and node@6.9.2 (node-v48 ABI) (falling back to source compile with node-gyp)
                                          iobroker 2016-12-21 18:32:05.379 info ERR!
                                          iobroker 2016-12-21 18:32:05.368 info node-pre-gyp
                                          iobroker 2016-12-21 18:30:40.378 info ^
                                          iobroker 2016-12-21 18:30:40.378 info static sljit_si getput_arg(struct sljit_compiler *compiler, sljit_si flags, sljit_si reg, sljit_si arg, sljit_sw argw, sljit_si next_arg, sljit_sw next_argw)
                                          iobroker 2016-12-21 18:30:40.378 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:1019:148: warning: parameter ‘next_argw’ set but not used [-Wunused-but-set-parameter]
                                          iobroker 2016-12-21 18:30:40.378 info sljit_si tmp_r;
                                          iobroker 2016-12-21 18:30:40.378 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c: In function ‘getput_arg’:../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:1021:11: warning: variable ‘tmp_r’ set but not used [-Wunused-but-set-variable]
                                          iobroker 2016-12-21 18:30:40.346 info ^
                                          iobroker 2016-12-21 18:30:40.346 info if (value != INVALID_IMM)
                                          iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:905:13: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                          iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:897:13: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                          iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c: In function ‘emit_set_delta’:
                                          iobroker 2016-12-21 18:30:40.346 info if (dst == arg1 && !(flags & KEEP_FLAGS) && IS_2_LO_REGS(dst, arg2))
                                          iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:800:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                          iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:796:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                          iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:792:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                          iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:788:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                          iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:784:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                          iobroker 2016-12-21 18:30:40.346 info if (dst == arg1 && IS_2_LO_REGS(dst, arg2))
                                          iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:777:12: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                          iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:765:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                          iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:757:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                          iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:753:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if (dst == arg1 && !(flags & SET_FLAGS))
                                          iobroker 2016-12-21 18:30:40.256 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c: In function ‘emit_op_imm’:
                                          iobroker 2016-12-21 18:30:40.256 info In file included from ../deps/libmagic/pcre/sljit/sljitLir.c:1333:0, from ../deps/libmagic/pcre/pcre_jit_compile.c:62:
                                          …und natürlich rückwärts.
                                          Weiterhin habe ich nichts vorher auf den neuesten Stand gebracht, vielleicht ist das aber von Vorteil:
                                          Controller: 0.13.2
                                          Admin: 1.6.7
                                          Cubietruck mit Ambian auf jessie mit Kernel 4.8.4
                                            ` > ____ _ _ _ _
                                          > / ___| _| |__ (_) ___| |_ _ __ _ _ ___| | __
                                          > | | | | | | '_ \| |/ _ \ __| '__| | | |/ __| |/ /
                                          > | |__| |_| | |_) | | __/ |_| | | |_| | (__| <
                                          > \____\__,_|_.__/|_|\___|\__|_| \__,_|\___|_|\_\
                                          > Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 4.8.4-sunxi
                                          > System load: 0.13 Up time: 16 days
                                          > Memory usage: 27 % of 2006Mb IP: 192.168.xxx.yyy
                                          > CPU temp: 38°C HDD temp: 40°C
                                          > Usage of /: 14% of 15G `
                                          Rainer
