  4. [fixed] Update heute WEB. Totalausfall iobroker
3 Beiträge 2 Kommentatoren 1.0k Aufrufe
  • Z Offline
    Z Offline
    Zippolighter
    Hatte heute 2 updates anstehen web und eine VIS Komponente auf meinem Raspi3. Habe Update All gemacht und nichts geht mehr.
    Auch schon neustart vom Raspi und folgendes an der Konsole
    ! ` > Using username "root".
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    Last login: Sun Nov 6 11:32:50 2016 from 192.168.33.220
    root@raspberrypi3_ioBroker:~# cd opt/iobroker
    -bash: cd: opt/iobroker: Datei oder Verzeichnis nicht gefunden
    root@raspberrypi3_ioBroker:~# cd /opt/iobroker
    root@raspberrypi3_ioBroker:/opt/iobroker# iobroker restart admin
    Adapter "admin.0 restarted.
    root@raspberrypi3_ioBroker:/opt/iobroker# iobroker start
    iobroker controller daemon already running. PID: 728
    root@raspberrypi3_ioBroker:/opt/iobroker# chmod 777 /opt/iobroker/
    root@raspberrypi3_ioBroker:/opt/iobroker# chmod 777 /opt/iobroker/* -R
    root@raspberrypi3_ioBroker:/opt/iobroker# npm install iobroker.js-controller
    npm WARN engine request@2.79.0: wanted: {"node":">= 4"} (current: {"node":"0.12.6","npm":"2.11.2"})
    ursa@0.9.4 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa
    node-gyp rebuild
    make: Entering directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa/build'
    CXX(target) Release/obj.target/ursaNative/src/ursaNative.o
    SOLINK_MODULE(target) Release/obj.target/ursaNative.node
    COPY Release/ursaNative.node
    make: Leaving directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa/build'
    npm ERR! Linux 4.4.13-v7+
    npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.js-controller"
    npm ERR! node v0.12.6
    npm ERR! npm v2.11.2
    npm ERR! code ETIMEDOUT
    npm ERR! errno ETIMEDOUT
    npm ERR! syscall read
    npm ERR! network read ETIMEDOUT
    npm ERR! network This is most likely not a problem with npm itself
    npm ERR! network and is related to network connectivity.
    npm ERR! network In most cases you are behind a proxy or have bad network settings.
    npm ERR! network
    npm ERR! network If you are behind a proxy, please make sure that the
    npm ERR! network 'proxy' config is set properly. See: 'npm help config'
    npm ERR! network
    npm ERR! network
    npm ERR! network
    npm ERR! network
    npm ERR! network
    npm ERR! network
    npm ERR! network
    npm ERR! network
    npm ERR! network
    npm ERR! network
    npm ERR! network
    npm ERR! network
    npm ERR! network
    npm ERR! network
    npm ERR! network
    npm ERR! network
    npm ERR! network
    npm ERR! network
    npm ERR! network
    npm ERR! network
    npm ERR! network
    npm ERR! network
    npm ERR! network 'proxy' config is set properly. See: 'npm help config' `
    Jemand noch Ideen.
    • apollon77A Offline
      versuchs nochmal. Es gab heute nen GitHub oder NPM Ausfall glaube ich …
      Passierts immer noch?
      • Z Offline
        Z Offline
        Zippolighter
        nach erneutem geht wieder alles
