  4. RPC Adapter 1.14.27 logeinträge für CUXD RPC Instanz
    6.7k
rpccuxderrorupgrade
1 Beiträge 1 Kommentatoren 117 Aufrufe 1 Beobachtet
  • wendy2702W Offline
    wendy2702W Offline
    wendy2702
    habe gerade mal den RPC Adapter auf Version 1.14.27 gebracht.
    Jetzt macht die RPC Instanz für CUXD ständig einen neustart und im log kommen diese Einträge:
    2021-01-10 13:25:31.476  - info: host.iobroker instance system.adapter.hm-rpc.1 started with pid 23406
    2021-01-10 13:25:32.249  - info: hm-rpc.1 (23406) starting. Version 1.14.27 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v12.19.0, js-controller: 3.1.6
    2021-01-10 13:25:32.330  - info: hm-rpc.1 (23406) binrpc server is trying to listen on 192.168.178.18:8701
    2021-01-10 13:25:32.331  - info: hm-rpc.1 (23406) binrpc client is trying to connect to 192.168.178.8:8701/ with ["xmlrpc_bin://192.168.178.18:8701","iobroker:hm-rpc.1"]
    2021-01-10 13:25:32.376  - info: hm-rpc.1 (23406) binrpc -> listDevices 18
    2021-01-10 13:25:32.417  - info: hm-rpc.1 (23406) new CUxD devices/channels after filter: 0
    2021-01-10 13:25:32.417  - info: hm-rpc.1 (23406) Connected
    2021-01-10 13:27:02.430  - error: hm-rpc.1 (23406) uncaught exception: argument 'obj' must be type number, string, boolean or object
    2021-01-10 13:27:02.431  - error: hm-rpc.1 (23406) TypeError: argument 'obj' must be type number, string, boolean or object
        at Object.encodeData (/opt/iobroker/node_modules/binrpc/lib/protocol.js:69:19)
        at Object.encodeArray (/opt/iobroker/node_modules/binrpc/lib/protocol.js:156:44)
        at Object.encodeData (/opt/iobroker/node_modules/binrpc/lib/protocol.js:90:32)
        at Object.encodeResponse (/opt/iobroker/node_modules/binrpc/lib/protocol.js:52:25)
        at /opt/iobroker/node_modules/binrpc/lib/server.js:83:41
        at Server.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rpc/main.js:924:9)
        at Server.emit (events.js:314:20)
        at Server.handleCall (/opt/iobroker/node_modules/binrpc/lib/server.js:82:24)
        at Socket.<anonymous> (/opt/iobroker/node_modules/binrpc/lib/server.js:59:22)
        at Socket.emit (events.js:314:20)
    2021-01-10 13:27:02.432  - info: hm-rpc.1 (23406) binrpc -> 192.168.178.8:8701/ init ["xmlrpc_bin://192.168.178.18:8701",""]
    2021-01-10 13:27:02.435  - info: hm-rpc.1 (23406) Disconnected
    2021-01-10 13:27:02.441  - info: hm-rpc.1 (23406) terminating
    2021-01-10 13:27:02.442  - info: hm-rpc.1 (23406) Terminated (NO_ERROR): Without reason
    2021-01-10 13:27:02.964  - info: host.iobroker instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
    Liegt das an meiner Config oder ist das ein Bug im Adapter?
    EDIT: Gibt auch schon ein issue von einem anderen User dazu: Issue
